Metalian Maxi super thread - Page 135
Page 135 of 154 FirstFirst ... 35 85 110 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 ... LastLast
Results 2,681 to 2,700 of 3062
  1. #2681
    Bothasig
    Thanked: 14
    Default Re: Metalian Maxi super thread
    Are 'Steadies' the rear corner supports/levellers?
    Mine are stored length-wise in the nose-cone and they just about fit although I do find them quite bulky - not that packing space is a problem
ID:	484881   Click image for larger version.
    '02 Patrol 3.0Di GL
  2. #2682
    Thanked: 180
    yip its the corner supports
    Hilux 2700i s/c 4X4 with a few extras ...............
  3. #2683
    Melkbosstrand
    Quote Originally Posted by ismail View Post
    i think now that school has started again, nice project for me to think about.....
    Ismail, I might be wrong (my wife tells me that a lot) but if I am not mistaken someone on this thread found a way to mount/ clamp them to the wheel carrier.
    (Henk, was it not you??)
    I'll see if i can find the post.
  4. #2684
    Melkbosstrand
    Yup - memory like an elephant
    Thread 2490 - Henk H -
  5. #2685
    Bothasig
    Thanked: 14
    Mine are waaay too long to be mounted behind the spare. (They do work a treat though)
    '02 Patrol 3.0Di GL
  6. #2686
    Thanked: 180
    Quote Originally Posted by Jungle Jack View Post
    Thanks, I was looking for post, will see what I can do, looks simple enough
  7. #2687
    Dec 2012
    Thanked: 120
    Quote Originally Posted by Stefan View Post
    When I first saw the design of yours, I liked the idea. Their length (and priorities ) has kept me from upgrading mine as well.
    The standard ones are nice in that they are tucked under the trailer. Especially on the tent side.
    But not being finely adjustable has caused a few curse words to cross my lips in family campsites trying to get the
    trailer reasonable level. But that is most likely my own fault because I am overly perfectionist when camping, my wife will
    agree...
    Jurgen
    ______________________________________________
    Now: 2014 Toyota Prado TX 3.0D AT
    Then: 2012 Jeep Wrangler Unlimited Rubicon 3.6 V6
    Then: 2013 Ford Ranger 3.2L XLT AT D/C 4x4
  8. #2688
    Bothasig
    Thanked: 14
    lol, I know the feeling.
    To be honest, I also thought they would be in the way, but they really are not.
    '02 Patrol 3.0Di GL
  9. #2689
    Bothasig
    Thanked: 14
    I've gotten my hands on 2x Deltec 1250 High Cycle batteries. Bearing in mind that there is already a 100Ah Deep-cycle battery installed in the "cargo-hold" below the fridge, where would be the best place to install them?
    '02 Patrol 3.0Di GL
  10. #2690
    Nov 2014
    The Far East (...Boksburg)
    Thanked: 90
    Couple of pics I've seen of rear internal well. All from Maxi's with water tanks.
ID:	486339   Click image for larger version.
Name:	Henk Metalian underfloor P1380459es.jpg
ID:	486340   Click image for larger version.
    "Life is tough, but it's tougher when you're stupid." John Wayne
    Platkar: 2002 Audi A4 1.8T 110kW Multitronic
    Swambo: 2014 Clio IV 0.9L 66kW Turbo Expression
    Camper Trailer: Metalian Maxi (Pi) & 2010 Howling Moon TTT
  11. #2691
    Bothasig
    Thanked: 14
    Thanks Honey Badger,
    In these pictures the batteries appear to be located in the back of the trailer, is this the configuration in your trailer?
    '02 Patrol 3.0Di GL
  12. #2692
    Thanked: 180
    Stefan, the newer models have the batteries fitted in the rear,
    I chose to fit mine between the water tanks, made my own bracket.
    I only have one battery in at the moment but im planning to fit another between the tanks at a later stage.
  13. #2693
    Dec 2012
    Thanked: 120
    2012 model. Battery in the back.
    Jurgen
  14. #2694
    Nov 2014
    Thanked: 90
    Yes, got one battery on right hand side. Still space for a second. Didn't want more weight in fridge area.
    Eventually found the pics of install. One day I'll sort out a metal bracket. Must admit those straps are as tight as the day I installed them. Battery slides under the edge lip too. Insulation tape while I was testing with drawer.... nervous first-timer checking whether Heinz really did design this thing to miss those battery terminals !!! (he did)
ID:	486500   Click image for larger version.
ID:	486501   Click image for larger version.
  15. #2695
    Bothasig
    Thanked: 14
    Any pictures of your installation?
    Seems the consensus view is that the better place to fit the batteries are at the back. I'll get the necessary parts and attempt this sometime towards the end of May.
    '02 Patrol 3.0Di GL
  16. #2696
    Thanked: 180
    ill post some tonight
  17. #2697
    Dec 2010
    Eldoraigne
    Thanked: 37
    Stephan
    I placed the battery there for easier access. Behind the tanks you will need to remove the rear slider to get the battery in. I tried but there is not enough space and I dont have alot of patience. Other thing to consider is the trailer wants to tilt with 2 batteries at the back and nothing in the fridge. I like some weight on the towball. It makes towing a lot safer.
    Rudu
  18. #2698
    Thanked: 180
    Stephan here my battery. My plan is still to put a better battery bracket in there once I fit 2 batteries
  19. The Following User Says Thank You to ismail For This Useful Post:
  20. #2699
    Nov 2014
    Thanked: 90
    Is that in a MAXI?
  21. #2700
    Thanked: 44
    Been up at Mountain zebra park this weekend. Towed the maxi with Swambo's Jeep Cherokee 3.2. Towed it effortlessly and I think better than my Jeep wk2 3.6...
    Only concern is the low nose.
    2018 Toyota Fortuner 2.4 4x4 auto
    Metalian Maxi
    2014 Jeep Cherokee 3,2 Limited AWD A/T (swambo)
    2012 Jeep Grand Cherokee 3.6 Overland (sold)
    2011 Fortuner 3 D4D 4x4 (sold)
  1. Trailer crashed, Namibia
    By Biggles in forum Trailers, Caravans, Towing etc
    Last Post: 2016/09/11, 08:39 AM
  2. Replies: 19
    Last Post: 2015/12/19, 06:10 PM
  3. Metalian Maxi for Rent from Kubu 4x4
    By Jannie Kubu4x4 in forum Commercial Member Adverts
    Last Post: 2013/08/12, 11:52 AM
  4. Can a closed thread be reactivated?
    By Eggie in forum The 4x4 Pub
    Last Post: 2013/06/09, 08:14 AM
