Metalian Maxi super thread - Page 132
Page 132 of 152 FirstFirst ... 32 82 107 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 ... LastLast
Results 2,621 to 2,640 of 3025
  1. #2621
    Thanked: 174
    Default Re: Metalian Maxi super thread
    I did mine with a brad Harrison plug on the panel and the mating plug on the nose cone but wired to a ctek 250s tho. I would recommend not a Hella plug for I see they rated to 5A whilst BH plug 20A I think.
    Hilux 2700i s/c 4X4 with a few extras ...............
  2. The Following User Says Thank You to ismail For This Useful Post:
  3. #2622
    Thanked: 2100
    I like to fir a Brad Harris to one of the holes under the nose cone doors, keeps the interior of the trailer dry and dust free
    Henk
    Follow us on Facebook
  4. The Following User Says Thank You to hbannink For This Useful Post:
  5. #2623
    Fourways
    Thanked: 36
ID:	471215Click image for larger version.
ID:	471212Click image for larger version.
ID:	471213Click image for larger version.
  6. The Following User Says Thank You to Fordie For This Useful Post:
  7. #2624
    Aug 2010
    Thanked: 112
    Not sure if posted but an Australian review:
    https://www.campertraileraustralia.c...an-maxi-review
    Freelander 2 i6 SE - loveeee iitttttt!
    650 V Strom - my trusty beast
    Honda XR400R - wanna play......
    Vespa - when you just have to be cool 8)
    GT Expert and Giant Anthen MTB's - keeping the tummy in check
  8. #2625
    Dec 2007
    Thanked: 116
    Geniet ons Maxi ook nog baie.
    Metalian Maxi
  9. The Following User Says Thank You to 4x4 wannabie For This Useful Post:
  10. #2626
    Jan 2018
    London
    Hi all,
    I'm a new owner based in London. I've only managed to use the trailer once in about 6 months of owner ship so it has been sitting on the drive covered with a tarp .. that turns out had broken down by UV (surprising I know!) and was leaking. As a result I've had some seals leak water into the trailer. Is the seals leaking a common thing and is there something that can be done to combat it?
  11. #2627
    Nov 2014
    The Far East (...Boksburg)
    Thanked: 90
    Quote Originally Posted by grantaw View Post
    Hi all,
    Ouch.
    You'll want to get that dried out and the canvas bags removed from the backing carpet to allow it to fully dry out. Also check wherever your battery is (rear battery bay I would think) as that could have water in too.
    Some on the forum in this thread have had leaks (me included, I had old seals) but manage to resolve them with combination of new seals, door adjustments, knocking the inner lip outwards a little or bending the stainless steel paddle (the part that contacts the door). But you have a new unit and new seals....!?
    Reply below I had from Heinz got me sorted some time ago:
    "1. The first think I do is to take a R10 note and close this in the door seal at three places each along the horizontal edges and two places on the vertical edges (for the kitchen door) or just two places each all round. When the door is closed, pull the note out. It can pinch tight, but mostly all you want is a bit of resistance in pulling this out. Youíll quickly feel what feels like there is no contact.
    2. If that is sorted, set up a smart phone and record the inside of the door where you suspect the water leak. Mostly we then find that the leak is coming from behind the seal. This happens when a seal has been removed and replaced and the feather on the insides is folded over. Water that sits on top of the seal above, starts running down and creeps in behind the seal. The leak then looks like it is coming from the bottom corner, but often also exits halfway up the seal on the inside.
    3. If youíre really struggling, Iíve used childrenís water paint around the seal and then just follow the watermarks"
    Keep posting what you find and how you remedy this. Moving to lower rainfall - more sun region would help too.
    "Life is tough, but it's tougher when you're stupid." John Wayne
    Platkar: 2002 Audi A4 1.8T 110kW Multitronic
    Swambo: 2014 Clio IV 0.9L 66kW Turbo Expression
    Camper Trailer: Metalian Maxi (Pi) & 2010 Howling Moon TTT
  12. The Following User Says Thank You to Honey Badger For This Useful Post:
  13. #2628
    Jan 2018
    London
    Quote Originally Posted by Honey Badger View Post
    Ouch.
    That part is in the planning!
    Thanks for the response and i'll everything a shot.
    Once discovered everything was removed and dried out. Thankfully only mould grew on some of the things we had stored inside ... so not too much of a disaster.
    It's leaning on a slight forward slope so all the water gathered towards the front so the batteries have stayed dry.
    In the interim a new tarp will be covering it all up
  14. #2629
    Thanked: 174
    hope everyones still out camping : ) happy new year everyone.
  15. #2630
    Nov 2011
    Default Re: Fix 04 - Water tank access port leak
    Hi guys, going to need some assistance here to fix a water leak from the top access panel of one water tank (Maxi, 2 x 75L system). All nuts were pretty tight but we could see water oozing out on the one side.
    Couple of pics attached to show what I found... bolts and some washers rusted from the leak. Previous owner did say he opened tanks at one time to clean some debris/glue. You can see lower cup (through the open port ) that protrudes below body of trailer to ensure tanks empty completely.
    Quite scary how many small pieces of plastic and rust were inside tanks. That in-line mesh strainer I don't have is going in before I use tanks again.
    Henk - you mention in a post to "open and reseal the tank's lid, clean the stainless with a bit of acetone to remove all traces of oil and don't be afraid of the sika it is your friend" - where would I put Sika? Do I get rid of the rubber seal and replace with Sika? Or do I use both? Is Sikaflex 552AT the one?
    Heinz - I note the switch to Stainless Steel and better access port - saw the new ones at Ultimate Overland recently - nice. We checked our tanks for the water taste problem and traced it to a 1.5m PVC pipe the previous owner used to fill from underneath. Tossed the pipe, replaced with good old garden irrigation pipe (thanks for idea Henk) and did multiple tests and no more bad taste at all.
    Thanks for any help.
    Can anyone explain how to remove the "lower cup" ? Do you remove the bolts from below the trailer or do your remove them from inside the tank? From the picture attached I cannot see. Not with the trailer now and trying to explain to someone how to do it.
    Photos of removal would be great!!!
  16. #2631
    Thanked: 39
    Quote Originally Posted by Bushwakka View Post
    I removed mine sometime ago. Yes you need to unscrew from underneath the trailer and then remove the part in your pic from inside the tank.
    I sealed with Sika and all good.
    Sorry no pics.
    2018 Toyota Fortuner 2.4 4x4 auto
    Metalian Maxi
    2014 Jeep Cherokee 3,2 Limited AWD A/T (swambo)
    2012 Jeep Grand Cherokee 3.6 Overland (sold)
    2011 Fortuner 3 D4D 4x4 (sold)
  17. #2632
    Nov 2011
    Quote Originally Posted by Bartman71 View Post
    Sorry no pics.
    Thanks, from the bottoms there is a cover so you canít see the bolts. How do I take this off.
    Sorry donít have pictures of the cover
  18. #2633
    Thanked: 39
    If I remember correctly, the fitting inside the tank has a threaded section that protrudes through the tank. From underneath there is a fitting that screws onto that thread and pulls everything together including the cover.
    Metalian Maxi
  19. The Following User Says Thank You to Bartman71 For This Useful Post:
  20. #2634
    Nov 2011
    Thanks, sure weíll be able to sort it out
  21. #2635
    Dec 2010
    Eldoraigne
    Thanked: 36
    It is with a sad heart that I am putting my Metalian up for sale.See http://www.4x4community.co.za/classi...or-sale/cat/16 The trailer is currently with Henk Bannink for a service.You are welcome to contact him for any reference on it as well.Rudu
    2007 Hilux 3.0d4d 4x4 DC - Mine
    2005 Hilux 3.0d4d 4x4 DC - Her's
    2008 3.2 did 4x4 DC Triton - Now with my Dad
    2006 Imagine Trailvan with Bunduawn 360
  22. #2636
    Thanked: 174
    Anyone fit a gravity tap on their Maxi?
    Im toying with the idea but where would I tap into the piping and mount the tap?
  23. #2637
    Jan 2018
    London
    Has anyone considered fitting something like these with individual up/down controls to their maxi?
    https://www.amazon.com/Gabriel-49236.../dp/B001AMEENQ
    I saw the levelling capability on the patriot trailers and thought these could achieve the same thing quite easily. being able to raise it up for water crossings would be another great use too. I haven't looked at the lengths etc yet to work out which model would be the correct one ... so just a passing thought for the moment.
  24. #2638
    Jan 2014
    Little Falls, Roodepoort
    Thanked: 32
    Ismail, is the gravity tap to drain your tanks? If so, at the bottom of your Maxi (underneath the trailer) there are pipe fittings connecting the 2 tanks. Henk installed a tap there (on my previous trailer).
    2008 Fortuner D4D
  25. #2639
    Thanked: 174
    Quote Originally Posted by Jan777 View Post
    Thanks will check it out, when I install another rear draw will i look at it, its really there for a backup just case the batteries die.....or something
  26. #2640
    Jan 2011
    Thanked: 99
    Quote Originally Posted by ismail View Post
    I installed a gravity tap by just connecting to the stainless steel piping underneath the water tanks. Pictures attached (a little dirty as my last trip was rather dusty). The tap attaches to the brass quick release connector. Click image for larger version.
ID:	478134Click image for larger version.
ID:	478135Click image for larger version.
  27. The Following User Says Thank You to Munnika For This Useful Post:
  1. Trailer crashed, Namibia
    By Biggles in forum Trailers, Caravans, Towing etc
    Last Post: 2016/09/11, 08:39 AM
  2. Replies: 19
    Last Post: 2015/12/19, 06:10 PM
  3. Metalian Maxi for Rent from Kubu 4x4
    By Jannie Kubu4x4 in forum Commercial Member Adverts
    Last Post: 2013/08/12, 11:52 AM
  4. Can a closed thread be reactivated?
    By Eggie in forum The 4x4 Pub
    Last Post: 2013/06/09, 08:14 AM
