Metalian Maxi super thread - Page 112
Page 112 of 154 FirstFirst ... 12 62 87 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 137 ... LastLast
Results 2,221 to 2,240 of 3064
  1. #2221
    Lichtenburg
    I was wondering, Heinz, have you built something like a stand for the nose to take the weight off the jockey wheel - perhaps something to use as a stand in storage or even as the third support for levelling instead of the jockey wheel?
  2. #2222
    Nov 2012
    Thanked: 1087
    Quote Originally Posted by daneers View Post
    A 9kg gas cylinder works perfectly for that.
    Choose life
  3. #2223
    Jun 2013
    On our second day of a three week trip to Kruger staying at Skukuza, Letaba and Croc Bridge. Staying at camps with perennial rivers with the drought, with the park being 90% empty camping wise. Our stainless steel Maxi with the Conqueror Comfort tent is a dream, drawing a lot of attention from fellow campers. I've pointed them in your direction Heinz.
    A problem we currently have at Skukuza is the noise from the staff quarters to the south of the camp site. There has a been a party going on since yesterday evening, and speaking to the camp manager a number of times has made no difference. Hoping tomorrow will be better.
    1990 LR Defender 110 5.7 V8 (Chevy)
    2010 LR Discovery 4 SDV6
    Metalian Maxi 304ss
  4. #2224
    Thanked: 732
    The later model Maxi's, (I'd guess for at least the last two years), have the same stabilizer points in the front as we have at the rear, so you can get an additional two stabilisers and fit them to the front of the Maxi.
  5. #2225
    Jun 2013
    We also have the Katadyn Ceradyn filter which was used by aid workers in Japan after the 2011 tsunami to provide potable water to survivors. It filters at a rate of 4 litres an hour and is good for 140,000 litres. With this filter you can safely filter river water to provide potable water.
    Metalian Maxi 304ss
  6. #2226
    Lichtenburg
    Quote Originally Posted by Heinz Modricky View Post
    Thanks, Heinz - mine is a bit older and indeed without the stabilizer points.
  7. #2227
    Nov 2014
    The Far East (...Boksburg)
    Thanked: 90
    Heinz Sir, can these front points be retrofitted? Or is it more like "n boer maak n plan?" Maybe a pic would help. Ta
    "Life is tough, but it's tougher when you're stupid." John Wayne
    Platkar: 2002 Audi A4 1.8T 110kW Multitronic
    Swambo: 2014 Clio IV 0.9L 66kW Turbo Expression
    Camper Trailer: Metalian Maxi (Pi) & 2010 Howling Moon TTT
  8. #2228
    Thanked: 732
    Quote Originally Posted by Honey Badger View Post
    This requires a square hole to be cut and an internal support welded into place at the point where it is now. I guess we could provide a bolt on tube with holes that does the same trick. This will then need to be bolted to the drawbar. I'll give this some thought tomorrow.
  9. #2229
    May 2012
    pretoria
    Thanked: 73
    I fitted mounting brackets for the standard stabilizers to the front of my Maxi, will post a pic of the brackets tomorrow.
  10. #2230
    Apr 2008
    Kuils River
    Thanked: 53
    I am no farmer, but did the "boer maak 'n plan" thing: I fitted a stabilizer jack (see photo) to the A-frame, and also one on the rear tow bar (in retrospect...2 such stabilizers at the rear would be better if you want to use it as levelling struts as well)
    Francois Johnson
    (swambo: Christel)
    Our rides
    • 2010 Isuzu KB300LX DTeq 4x4 D/C
    • Metalian Maxi Trailer, Maxine
  11. #2231
    Sep 2013
    Thanked: 143
    Why not just put your hi-lift jack under the A frame, if you have one? One less thing to cart around.
  12. #2232
    Lichtenburg
    Thanks for giving this some thought, Heinz - I trust that you will come up with a fitting solution, I am currently using a piece of a creosote pole cut to length, but there must be a better solution.
  13. #2233
    Gordon's Bay
    Thanked: 4378
    Default Re: Metalian Maxi super thread
    So, I may well be selling my Maxi soon - It's kinda large and I just don't get out enough with it.
    Having had a chat to Heinz I'm considering something thats more weekender friendly...
    anyone interested in a Metalian with 35s on it?
    can be modified down to lower tyres or whatever is required,,,,
  14. #2234
    Nov 2012
    Thanked: 1087
    Are the shocks not a bit worn? A thread about noise at night comes to mind.
    Choose life
  15. #2235
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by Coenoes View Post
    I do not believe in Shocks on a trailer, they cause more trouble than 2 stroke oil in diesel
    but now that you mention it the stabilising jacks seem to be excessively worn, I shall supply new ones!!!
  16. #2236
    Gordon's Bay
    Thanked: 4378
    Pictures.... I've decided.... it's up for sale guys, inbox me if you are interested...
ID:	387870   Click image for larger version.
ID:	387871   Click image for larger version.
ID:	387872   Click image for larger version.
ID:	387873   Click image for larger version.
  17. #2237
    Sep 2008
    Swakopmund
    Thanked: 168
    If only you were closer - I'd be all over this... Unless you fancy a trip to deliver? 😀
    Fortuner 2.8 GD-6 4x4 Auto
    (Tough Dog Suspension / Frontrunner Roofrack and some more goodies...)
  18. #2238
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by Sniper View Post
    Delivery is easy
  19. #2239
    Thanked: 2224
    Nah no worry, it was not the Metalian it was the old guy's back squeeeeeking
    Henk
    Follow us on Facebook
  20. #2240
    Nov 2012
    Thanked: 1087
    And whoever buys the trailer will think about it every night. Value just dropped by half.
    Choose life
  1. Trailer crashed, Namibia
    By Biggles in forum Trailers, Caravans, Towing etc
    Last Post: 2016/09/11, 08:39 AM
  2. Replies: 19
    Last Post: 2015/12/19, 06:10 PM
  3. Metalian Maxi for Rent from Kubu 4x4
    By Jannie Kubu4x4 in forum Commercial Member Adverts
    Last Post: 2013/08/12, 11:52 AM
  4. Can a closed thread be reactivated?
    By Eggie in forum The 4x4 Pub
    Last Post: 2013/06/09, 08:14 AM
