Metalian Maxi super thread - Page 108
Page 108 of 154 FirstFirst ... 8 58 83 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 133 ... LastLast
Results 2,141 to 2,160 of 3064
  1. #2141
    Nov 2014
    The Far East (...Boksburg)
    Thanked: 90
    Thumbs up
    Quote Originally Posted by Heinz Modricky View Post
    The lock barrels have numbers on them (like E 04). If you let me have the number, I can always check my stock of keys, We fit these to all our canopies and have many spare keys. I won't charge you if you collect or send someone to collect from me or from Henk.
    Hey Heinz ! Don't guess online at lock numbers cause you may guess my lock number. Or maybe you didn't? Or maybe you did.
    Henk is R150 fuel and tolls away from me, you are 1500KM so R50 wasn't so bad I guess.
    PS: I'll save freebies for something(s) more substantial... am in process of getting our "previously-KZN-now-GP" trailer all sorted.
    "Life is tough, but it's tougher when you're stupid." John Wayne
    Platkar: 2002 Audi A4 1.8T 110kW Multitronic
    Swambo: 2014 Clio IV 0.9L 66kW Turbo Expression
    Camper Trailer: Metalian Maxi (Pi) & 2010 Howling Moon TTT
  2. #2142
    Thanked: 44
    Hi guys. What is the purpose of this vertical zip on my HM classic TT? Click image for larger version.
ID:	378327It is situated next to the rear door hinge.
    2018 Toyota Fortuner 2.4 4x4 auto
    Metalian Maxi
    2014 Jeep Cherokee 3,2 Limited AWD A/T (swambo)
    2012 Jeep Grand Cherokee 3.6 Overland (sold)
    2011 Fortuner 3 D4D 4x4 (sold)
  3. #2143
    Sep 2013
    Thanked: 143
    Re plastic tank sealing a few posts back, there's a product called "Sticks Like Sh*t" (I kid you not). Roughen the plastic surface with some coarse sandpaper and you'll be able to seal it with that stuff. I did use a rubber gasket too though.
  4. #2144
    Sep 2013
    Thanked: 143
    Quote Originally Posted by Bartman71 View Post
    Can't make out the pic properly but isn't for running a light/electric lead into the tent? Short zips or velcro'ed openings on tents are often provided for that purpose.
  5. #2145
    Thanked: 44
    This zip runs from the ground to the mattress? ?
    Metalian Maxi
  6. #2146
    Thanked: 732
    The tent appears to have been modified to fit the trailer. I'm guessing you have an aluminium rope channel fitted in the same position. If you unzip the zip, this frees up the half of the zip that is not on the tent side. You can now feed this end into the rope channel and then zip this closed. This is how you fix the tent to the rope channel in order to seal the tent against the trailer side.
  7. #2147
    Nov 2014
    Thanked: 90
    Default Tent zipped against trailer
    Agreed. We have this on our HM 2010 tent.
    If this isn't the case then you just have an extra secret (ssshhhh) entrance to your tent. A hidden feature of the Metalian-Howling Moon combo.
Name:	photo1445329640271 (Medium).jpg
ID:	378393   Click image for larger version.
Name:	photo1445329640638 (Medium).jpg
ID:	378394   Click image for larger version.
Name:	photo1445329641359 (Medium).jpg
  8. #2148
    Plett/Paulshof
    Thanked: 1007
    Brand new tent straight from the factory so this must be a standard part of the design.
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Kewer 2202, Fusion 17 boat-Yamaha FT100hp 4st.
  9. #2149
    Thanked: 44
    Yes it must be a standard design as there is no rope channel. What the design is for is the ?
    Metalian Maxi
  10. #2150
    Thanked: 732
    Can you unzip the entire panel? If so, maybe HM have different panels that can be fitted in order to make them more compatible with other trailer designs. (I always thought this is a good idea for any TTT to have.
  11. #2151
    Thanked: 44
    No Heinz it doesn't unzip the entire panel. Its just a vertical zipper that starts above the ground sheet and ends in line with the top of the zip that opens up to have access to the trailer. I've emailed them to see what they say.
    Metalian Maxi
  12. #2152
    Thanked: 44
    So here is the reply from Howling Moon....
    "That zip is merely for manufacturing reason for our machinist to slide the tent in while sewing."
    Metalian Maxi
  13. #2153
    Nov 2014
    Thanked: 90
    Default Hidden features for "sliding"
    Re Howling Moon tent:
    Re Maxi water tank installation:
    On the Maxi the dims are only 105mm and this is because we need that gap in order to slide the tanks into position, otherwise I would have provided no gap at all.
    Seems all good products have hidden features there for manufacturing purposes and for sliding things around.
  14. #2154
    May 2010
    Lynwood Glen
    Thanked: 27
    Afternoon gents, my water woes continue. I can not pressure the pump because it leaks out the side of the filter when I do. I have always run it by the power switch. I leave next week for Namibia and thus tried to solve my problems. In trying to do so I have snapped the one little exit port off the pump. Where can I get a replacment at short notice? In jhb
    2012 Fortuner D4D 4x4
    Metalian Maxi
  15. #2155
    Lonehill, JHB
    Thanked: 995
    Quote Originally Posted by Shippy View Post
    Send hbannink a message, he's in Honeydew
    2014 Pajero 3.2DiD SWB
  16. #2156
    May 2012
    pretoria
    Thanked: 73
    Upgraded my water tank covers on my MAXI from the standard St. Stl. covers to standard boat hatch covers (thanks Heinz for the supply), should have no more water leaking from them.
ID:	379449   Click image for larger version.
ID:	379450   Click image for larger version.
ID:	379451   Click image for larger version.
ID:	379452   Click image for larger version.
ID:	379453   Click image for larger version.
  17. The Following User Says Thank You to eloffmare For This Useful Post:
  18. #2157
    May 2010
    Lynwood Glen
    Thanked: 27
    Right so as usual, one email, one phone call and by the end of the day I have the waybill - another pump on the way to me over night delivery. Thanks once again to Heinz, Gareth and his team for their willing assistance and superb service!
    Metalian Maxi
  19. #2158
    Lonehill, JHB
    Thanked: 995
    @hbannink I know you monitor this thread closely, please respond to my sms . I would like to collect my trailer on Thursday afternoon, or this evening. Thanks.
  20. #2159
    Plett/Paulshof
    Thanked: 1007
    I am joining the Metalian clan again... Could not stay away....pics to follow..
  21. #2160
    May 2012
    pretoria
    Thanked: 73
    BruceH, so whats happened to the Bush Lapa Boskriek?
  1. Trailer crashed, Namibia
    By Biggles in forum Trailers, Caravans, Towing etc
    Last Post: 2016/09/11, 08:39 AM
  2. Replies: 19
    Last Post: 2015/12/19, 06:10 PM
  3. Metalian Maxi for Rent from Kubu 4x4
    By Jannie Kubu4x4 in forum Commercial Member Adverts
    Last Post: 2013/08/12, 11:52 AM
  4. Can a closed thread be reactivated?
    By Eggie in forum The 4x4 Pub
    Last Post: 2013/06/09, 08:14 AM
