ML 320 CDi acceleration problems
Results 1 to 6 of 6
    Mar 2012
    Default ML 320 CDi acceleration problems
    Hi there, i have a problem with my 2008 320 CDI with 104 000kms on the clock. Perhaps someone can help
    On friday evening 2 weeks ago, the ML was used during the day and after about 2 hours I used used teh car to the local shopping centre, After taking off from my entrance onto a hill, the car suddenly starts to lose accelartion and then gain it again until it goes into limp mode, no warning lights come o. After swithing all is reset and back to normal with no further acceleration problems.
    I ignored the problem as a once off but exactly a week later, after the same sequence of events as above and the same hill, the problem happened again and reverted to normal.
    Any ideas on what the problem could be. I have booked it in at MB but the earliest date is 26 Nov.
    Douglasdale Fourways
    Thanked: 7
    Does it sound like the gearbox is "slipping" or does it feel like someone cut the fuel off ?
    Jeep, there is only one.
    Mar 2012
    More like a fuel supply issue
    Vanderbijlpark
    Howzit Buddy, I had an issue with the c class the other day. I suggest you tell them to just do a diagnosis.... I took mine in unplanned on Monday .... Took 5 minutes to diagnose the fault. I am pretty certain the fault with be stored. The problem I had was different but also reset when the car was switched off an restarted. They usually have to order parts and you will have to take back to try and convince the dealer to squeeze your car in during the afternoon...good luck...
    Mar 2012
    Kev, good to see you on this forum
    Umhlanga MB is very busy, read on some overseas sites thatit coudl be anything from dirty filters to turbo problems, only happened twice and hopefully the error is not erased by the time it gets there...
    Constantia Kloof
    Thanked: 554
    Quote Originally Posted by Stealth View Post
    My money would be on a dirty fuel filter. For some reason this is not always a service item and thus never gets replaced (Before the Toyboys chirp me, Toyota doesn't replace them either, ask me how I know)
    My vehicle got serviced by MB in Port Shepstone and they were very professional, it may be worth the drive to go there.
  1. Ml 320 CDI Oil Consumption
    By Stealth in forum Mercedes
    Last Post: 2012/11/17, 06:29 AM
  2. ML 320 CDi DSR
    Last Post: 2012/07/20, 11:58 PM
  3. Ml 320 CDI Great
    By wad in forum Mercedes
    Last Post: 2009/09/23, 10:13 PM
  4. rim for 2008 ML 320 CDI
    Last Post: 2009/03/23, 03:23 PM
