C class gear change issue
Results 1 to 4 of 4
    Vanderbijlpark
    Default C class gear change issue
    Hi, I have a w204 c220cdi. I recently experienced a problem where the auto box did not want to change up into 4th gear. Sport button on the box did not work and I could not change gears manually. When the car was switched off and restarted, everything was fine again. However, the next day it happened again. Any idea what could cause this.
    Jan 2011
    South of the Lentil Curtain
    Sounds like it might have gone into 'limp mode'. 3rd gear is usually selected and the gearbox does not change up or down.
    How many km you done in the vehicle?
    Usually a good flush and filter replacement of the autobox oil does the trick.
    Otherwise hook up to a diagnostic machine and look for error codes.
    Sent from my HTC One using Tapatalk
    edenvale
    get the agents to do the gearbox fill and flush
    the local shop wont be able to flush out all the fluid
    the computer needs to be put in a certain mode
    and it takes plenty fluid
    if that doesnt work
    get a box out a scrapyard - there is a merc yard in city deep
    they will only be too happy to sell you one
    there is hardly any demand for them so it will also be cheap
    Vanderbijlpark
    Thanks. Vehicle has done 96000kms. Still under motorplan for the next month so need to get this resolved ASAP.
  1. Freelander 2 Gear Selector Spring
    By JJJ in forum Softroaders
    Last Post: 2017/11/23, 11:21 PM
  2. Prado gear ratio and cruise control
    By cacti in forum Toyota
    Last Post: 2012/07/12, 09:56 AM
  3. Replies: 6
    Last Post: 2012/05/07, 07:17 PM
  4. Pajero issue
    By mariusjk in forum Mitsubishi
    Last Post: 2009/10/30, 04:00 PM
  5. Landcruiser 70 oil change
    By Swifty in forum Toyota
    Last Post: 2007/06/18, 04:41 PM
