Handy technical files
Results 1 to 17 of 17
    Thanked: 1639
    Default Handy technical files
    Lets get some knowledge together. Amongst the community there must be how to or knowledge to do everything and if you include guys like Stan even brain surgery
    First lot is all about brakes, trailer and caravan brakes.
    Attached Files Attached Files
    Henk
    Follow us on Facebook
    Mar 2011
    Cape Town - Table View
    Thanked: 12
    Can this not be made to be sticky?
    Rory
    2005 Hyundai Terracan 2.9 CRDi aka Terry (Family/Weekend Car)
    2018 BMW R1200GS Adv LC aka Snow (My other joy)
    2013 Metalian Maxi aka Maximilian (A Good Year)
    Thanked: 1639
    Just for you done
    Henk
    Good idea Henk. My solar sizing and volt drop calculators attached.
    Bryan
    Disco 4 SDV6 S (me)
    Jeep Cherokee CRD (swambo)
    Think it was a mistake to make it a sticky so soon.
    Bryan
    Disco 4 SDV6 S (me)
    Bosveldsig, Nylstroom/Modimolle
    Thanked: 175
    Henk,
    Can you add the info on the supension and bolt breaks with the solution that Metalian offer.
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop - afgetree nou leef ons net.
    2017 BL - Kewer B1115 RUS WA GP - bos en kamp tyd
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT 4x4 - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - (verkoop 44 000 km)
    2010 Ford Ranger 2.5 DT DC XLT 4x4 - rondloop ry ding met "bietjie ekstra" krag (Verkoop 177 000 km)
    2005 Chev Aveo - Afgeskryf (2016 130 000)
    2005 Opel Corsa 17DTi - Geruil (warm enjin 180 000)
    2003 Opel Corsa 17DTi - Geruil (warm enjin 150 00)
    2000 Nissan Hardbody - Geruil (pyne by die duisended 52 000 km)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin 116 000 km)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003 (117 00km)
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000 (51 000 km)
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998 (328 000 myl/525 000 km)
    Thanked: 1639
    How to pack a wheel bearing with grease.
    http://www.youtube.com/watch?v=JXYvJv-zWlw
    Henk
    Thanked: 1639
    A few more to ponder
    Henk
    Apr 2014
    Menlyn
    Help!!!
    I have set my brakes according to the pdf file on this page.
    With the handbrake set on the second notch the wheels lock forward and release backwards which is correct.
    Then on releasing the handbrake the right wheel free wheels perfectly but the left wheel rotates with friction. This friction goes away when I release the lock nuts on the spring cylinder or the brake rod at the equaliser.
    Somebody else then said to me that when I turn the tumbler up on each wheel until they don't rotate I must then set them down 9 clicks to release.
    Which I did, now when I apply the handbrake the wheels lock forward which is correct but lock backwards too.
    So there is no reverse function!!
    Thanked: 1639
    How to set wheel bearings when replaced
    Henk
    Pretoria work in Zambia
    Henk,
    A good video but I differ from the producer in a small way. He should have kept pushing the grease through from on side only. By turning the bearing around before the grease is pushed all the way through, leaves an air gap. I know that the bearing gets warm and the grease will flow into the air gap but it's just the way I was taught during my appieship. Lessons learned the hard way
  12. The Following User Says Thank You to RoyG For This Useful Post:
    Mafikeng
    Thanked: 43
    Why do the manufacturers of trailers make the suspension so hard that the only movement there is is taken by the tyre sidewall flexing?
    Surely if you have an offroad rig it is safer to make the suspension work like the car where the shock absorbers do their work as designed to slow down the rebound and so make it safe?
    Ubbo
    Ubbo
    2011 FJ Cruiser
    2014 Rubicon - Sold
    Thanked: 677
    Default Re: Handy technical files
    Hi Guys.
    I found this link that might be helpful to anybody wanting to build a trailer and needing proper plans. These plans will take out the guess work in selection of materials and for dimensions.
    http://www.trailerplans.com.au/produ...r/#prettyPhoto
    http://www.trailersauce.co.nz/
  15. #14
    Sep 2010
    Sasolburg
    Thanked: 112
    Some bolt and nut data.
  16. #15
    Nigel
    Thanked: 1912
    Just pulled all the hubs off on my trailer.
    3 x bearings are rumbling and the last one failed on me, about 4yrs ago. I replaced that one myself and it is still fine.
    So moral of the story.
    Push the shells until they are home. 2 of these are not home.
    Never pull the shells home, by pulling on the nut. It WILL pit the shell.
    Never over-torque the bearing. It will build heat and that will be the end of that bearing. I believe that you torque to about 5nm. Just more than finger tight. Once it has run for a couple of km, under load, you can always go back and make sure that there is no play.
    Last but not least, make sure you use a proper high grade grease.
    +27 zero eight 2 four 95 9252
  17. The Following User Says Thank You to Henris For This Useful Post:
  18. #16
    Thanked: 39
    Default Re: A few Good Knots
    This could be handy.
    Your mind is your strongest weapon.
    Then there's.....POWER TOOLS!
    '94 LC 80 GX
    '00 Frontier 280DT 4X2
    2002 Sprite Surfer Nomad
  19. The Following User Says Thank You to steamer For This Useful Post:
  20. #17
    Thanked: 39
    Sorry about the upside down Yellowblade instructions! Can't seem to turn it over.
    '94 LC 80 GX
  1. Discovery 4 Technical Bulletins "applied"
    By Landy_Man in forum Land Rover
    Last Post: 2013/01/24, 09:59 AM
  2. LandyLuvvers Handy Tips
    By Schuits in forum Land Rover
    Last Post: 2012/10/19, 09:39 AM
  3. Disposal of confidential files.
    By Aries in forum The 4x4 Pub
    Last Post: 2012/07/09, 05:38 PM
  4. Loading mp3 files to a Nüvi...
    By stadleroux in forum GPS & Mapping
    Last Post: 2010/04/14, 04:59 PM
  5. Fugawi and btk track files
    By Dale in forum GPS & Mapping
    Last Post: 2007/07/12, 09:23 PM
