Page 3 of 3 FirstFirst 1 2 3
Results 41 to 50 of 50
    Alicedale
    Thanked: 44
    I think the ARB is not to blame here. I have towed game trailers in 35deg heat, 3.5tons with ARB, big lightforce spots and never a hassle with a airconditioner.
    Its one of the following:
    1. Radiator is blocked up by seeds or just needs a good flush.
    2. Injectors not right, running the engine a little hot.
    3. Injector pump
    4. Faulty a/c. insufficient gas or something.
    '18 Hilux 2.8 Auto 4wd
    '19 Fortuner 2.8 Auto 4wd
  2. #42
    Thanked: 49
    Aircon checked - thought to be original problem
    Re-gassed, still same.
    Some sensor had to be oredered, and was replaced.
    Still no change.
    Radiator was checked.
    Intercooler Checked.
    Thermostat replaced.
    Fan checked.
    SAC Chip removed.
    I suppose something next to check would be Fuel mixture.
    Vehicle does not smoke or sound odd.
    If he does this instead of trading it in on something else I'll keep you posted.
  3. #43
    Thanked: 9
    Default Re: Hilux running HOT
    Did you eventually find the problem? I have that issue with my d4d now. Standard, no towing, only happens on long drives after 2 hrs or so. Normal highway speeds
    --- 2016 Hilux 2.4 GD- 6 4X4 ---
    --- 2014 Golf 7 1.4 TSI ---
    --- PREVIOUS ---
    2007 Hilux 3.0 D4D
  4. #44
    Midrand Estates
    Thanked: 57
    Ever thing that the Explorer is just to much for the vehicle. Often diesel drivers do not realise how the combustion temp increases under load. Simply depressing the accelerator to get more out drives the EGT to dangerous levels. A more sedate approach to hills and using the gears will reduce the load on the engine and thus reduce the temps.
    A bigger radiator will often not solve the problem as the limiting factor is the flow of the coolant/water through the engine.
    Experience was with a 4.2 diesel that I then fitted with a Safari Turbo and Intercooler. ran for 400 k km + with no issues. The best investment was a EGT gauge. It teaches you how to drive a diesel for reliably.
    How can you be old and wise
    if you were never young and wild
    2016 Ford Ranger 3.2 XLT 4X4 Auto
    2015 Ford Ranger 3.2 XLT Auto
    2015 Mini Countryman
    2016 Conqueror Companion 2B
  5. #45
    Thanked: 49
    Problem was never solved and it was traded in on a new model.
    I suppose the EGT would have been the next thing to check?
    1996 : 80 Series Landcruiser 4500 GX SW
  6. #46
    Nigel
    Thanked: 2635
    And I assume the grass and seeds, between all radiators, was cleaned out.
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
  7. #47
    Thanked: 49
    Was part of the Radiator check.
    Radiator was removed, cleaned & pressure test done.
  8. #48
    Nigel
    Thanked: 2635
    Quote Originally Posted by LenArtman View Post
    Next stoopid question.
    Were the fluted checked that they were still true and not oval. That totally buggers the capabilities of the radiator.
    Uniglide
  9. #49
    Thanked: 49
    Unfortunately I wasn't with when he had it checked.
    Also vehicle is gone.
    With him not being very mechanical orientated I think he relied on what he was told.
    Got sick of throwing money at it and the problem not getting resolved.
    Since then he has had the 2.5 and then got the 3.0 d4d again.
    Very happy so far.
    Hasn't messed with chips etc.
    Kept it STD.
  10. #50
    Nigel
    Thanked: 2635
    I saw it was sold, but I was just wondering. I hate to let something like that just slide by. My brain wants to know why.
    Uniglide
  1. AT Tyre Tests
    By kalahari in forum Tyre chat
    Last Post: 2016/04/02, 08:58 PM
  2. Fortuner Towing with a Hilux or Fortuner
    By Uys in forum Toyota
    Last Post: 2014/10/13, 01:15 PM
  3. Replies: 41
    Last Post: 2013/11/08, 04:36 PM
  4. NEw Isuzu beats new Yota offroad.
    By Bryan Webber in forum Isuzu
    Last Post: 2006/12/20, 09:31 PM
