Gen1 & Gen2 Body Lift
Results 1 to 12 of 12
    4ePajero Guest
    Thanked: 267
    2015 Pajero Sport 4x4
    1996 3.5v6 Pajero (For Sale)
    Carpe Diem Scrotum
    4ePajero Guest
    Lift kits available at
    • your local industrial plastics retailer
    • friendly machine shop
    • 'bolts & nuts' shop
    • friend who can wield a spanner
    Cost ? Should not exceed R1500-00
    Do this in phases:
    1. Buy 1m of UHDPP (ultra high density polypropylene) or Polyacetal rods from Maizeys or other. Dia you need me finks is 65mm (measure your current mountings).
    2. Ask a machine shop to cut them into 50mm pieces with 10mm dia holes.
    3. Buy the 12 HT bolts from your local "Bolts & Nuts"
    4. Lift body and radiator
    5. Lift bumpers
    Thanked: 267
    Thanks to Gorman for sending me this document It describes a Gen2 lift.
    It seems the original website from which this was gleaned is no more. If anyone knows a different link please let me know so I can acknowledge the original author.
    Carpe Diem Scrotum
    Thanked: 267
    4e
    Maizeys do not do UHDPP or UHDPA, only UHD polyeth (R347pm for 70mm). What kind of difference will the material make? I see some people use alloy as spacers.
    Carpe Diem Scrotum
    Jan 2009
    Damn that looks like a lot of work for 5cm! But I must admit the difference in looks is amazing
    2006 Mitsubishi Colt Rodeo 3000i V6 4x4 D/C
    4ePajero Guest
    In some countries metal spacers are obligatory.
    Some people use ice hockey pucks.
    UHDPE rods should do it.
    Look in the Yellow Pages under Engineering Plastics.
    4ePajero Guest
    Quote Originally Posted by SimonB View Post
    Here's a better copy of that write-up.
    Good reading here.
    Beans Guest
    Simon i dont think any difference as i did my landy . I would think a 40mm lift would be fine. Remember the steering rod to the steering box and also the front and rear bumpers need to be lifted by the same spacer height. The only advantage is if you want to fit larger tyres.
    4ePajero Guest
    Quote Originally Posted by Beans View Post
    The steering needs no mod for a 50mm lift.
    Beans Guest
    Are your sure I know on a landy you cannot do it.
    4ePajero Guest
    Yes, I did it and all the write-ups confirm it.
  1. Navara Body Lift
    By garethjames1983 in forum Nissan
    Last Post: 2012/09/19, 01:44 PM
  2. Cherokee XJ Mods for Newbies (Help)
    By Tregrok in forum Jeep
    Last Post: 2011/09/08, 12:49 PM
  3. Cherokee XJ Body Lift advice needed
    By mojo in forum Jeep
    Last Post: 2011/06/27, 01:25 PM
  4. Wrangler 2dr Body Lift
    By big sam in forum Jeep
    Last Post: 2010/10/27, 08:10 AM
  5. Body Lift
    By Bundu in forum Ford & Mazda
    Last Post: 2007/06/01, 06:35 PM
