National Luna Danfoss controller
Results 1 to 20 of 22
    Dec 2007
    nelspruit
    Thanked: 54
    Default National Luna Danfoss controller
    Is it common for the electronic controller to fail. I must admit, mother thought the proper way to switch it off, is to unplug the plug from the fridge. Blows the 220v circuit. Cost of controller R3200.00. Very paifull. National luna do not repair them. Anybody do this?
    Bellville
    Thanked: 1773
    unplugging it really should not blow the controller .... these units are RUGGED.
    Mar 2011
    Walker Bay
    Thanked: 1022
    Bertus - Thanks for the warning! This sounds expensive!
    May 2013
    Sandton
    Thanked: 14
    The Danfoss is very rugged, heres the wiring diagram for pure DC and no electronics
    May 2013
    Sandton
    Thanked: 14
    Default Danfoss wiring diagram
    Hope this helps, mine is hardwired.
    Dec 2007
    nelspruit
    Thanked: 54
    read this
    Attached Files Attached Files
    Quote Originally Posted by bertus View Post
    I agree with Chris, should not be a problem. Give me the details and I will quiz them.
    Bryan
    Disco 4 SDV6 S (me)
    Jeep Cherokee CRD (swambo)
    edenvale
    Thanked: 212
    is there maybe a fuse or diode soldered onto the board thats blown
    5 minutes with soldering iron maybe all thats needed
  9. The Following User Says Thank You to 3bar For This Useful Post:
    Feb 2017
    Klerksdorp
    Thanked: 66
    Default Re: National Luna Danfoss controller
    Quote Originally Posted by Columbus View Post
    Hi i only check this tread now, i also got a problem with my National Luna Double door 90L fridge freezer, hope sone one can help.
    The compressor runs on 12 & 220v but it doesnot make cold it did the same when we were in Hartenbos but was running again after i unplug 12&220 then fine
    But when i want to start it at home again same problem
    Feb 2017
    Klerksdorp
    Thanked: 66
    Quote Originally Posted by OLi4 Chris View Post
    There are also no fualt id visable
    National luna said i must bring it in they will test & run for a week but it is not eazy for us to farr to take to them Nwest kldorp
    Feb 2017
    Klerksdorp
    Thanked: 66
    What i can remember is when i want to set both the temp on freeze or more than -1C this problem starts when inreset all back to normal then it does not making cold
    Thanked: 36
    Hi Guys,
    Not often that they fail but fail they certainly do if it is a BD35F compressor. Mine also failed on a Minus 40 and the price is eye watering.
    That is a very small but highly complex controller much like a mini VSD with a soft start, speed controller and overload and thermal protection. If it fails in the bush it will ruin your holiday for sure. I have a spare that I carry now when we go away. Replacement is very easy.
    There is no fix because it is cast in resin with no fuses and is pay and replace if the unit is out of warranty and only available from Danfoss.
  14. The Following User Says Thank You to Frontierfan For This Useful Post:
  15. #13
    Dec 2007
    nelspruit
    Thanked: 54
    Try only one power source at a time. The 220v has the highest priority when plugged together. Run on 220 only see what happens then 12v alone and see. hen we can take it from there.
  16. The Following User Says Thank You to bertus For This Useful Post:
  17. #14
    Dec 2007
    nelspruit
    Thanked: 54
    Quote Originally Posted by Frontierfan View Post
    Hi Guys,
    I know the pain. Do the same. But look at the plans you can get it working when s... strikes.
  18. The Following User Says Thank You to bertus For This Useful Post:
  19. #15
    Feb 2017
    Klerksdorp
    Thanked: 66
    Thankyou i will check & try again
  20. #16
    Oct 2012
    Roodeplaat
    Thanked: 40
    The Danfoss controller is very expensive,i normally replace the whole compressor unit,new compressor comes with a new controller for around R1700,controller on its own R3500
    Or just buy the compressor and use the controller only and keep compressor as a spare
    I repair these fridges all the time,and sometimes its only a small problem
  21. The Following 2 Users Say Thank You to Werner Brits For This Useful Post:
  22. #17
    Dec 2007
    nelspruit
    Thanked: 54
    Little bit late to hear this. Always wonder where to find it. Where do you buy it? Do you get a lot of blown controllers? One can always use this compressor to build your own 12v fridge cheaper than to buy one. Thanks
  23. #18
    Oct 2012
    Roodeplaat
    Thanked: 40
    TECSA RECO Pretoria
  24. The Following 2 Users Say Thank You to Werner Brits For This Useful Post:
  25. #19
    Feb 2017
    Klerksdorp
    Thanked: 66
    Quote Originally Posted by Werner Brits View Post
    TECSA RECO Pretoria
    Thanks Werner & Bertus
  26. #20
    Feb 2017
    Klerksdorp
    Thanked: 66
    Hi Bertus
    Do you have a picture of the controler ?
  1. CTEK and National Luna controller
    By TopHilux Hilton in forum Camping, Fridges, Accessories
    Last Post: 2013/11/03, 10:25 AM
  2. Overland Journal Portable 12V Fridge Review
    By ChrisH in forum Camping, Fridges, Accessories
    Last Post: 2011/11/30, 11:26 AM
  3. National Luna Weekender to swop for 80L dual National Luna
    By Kooskop in forum Camping, Fridges, Accessories
    Last Post: 2010/09/27, 01:13 PM
  4. National Luna Intelligent solenoid & controller
    By janfloris in forum Camping, Fridges, Accessories
    Last Post: 2010/07/27, 07:16 AM
