Results 1 to 14 of 14
    Thanked: 1061
    Default Triton 4x4 Lights flashing
    Hi all. The sticky thread did not contain anything similar so here is my issue.
    After returning from a recent trip driving in severe dusty conditions, the Triton's 4 wheel lights does not go out. It flickers and has been doing so ever since.
    I thought a good turbo spray wash in the engine bay and/or under carriage would get rid of whatever is causing this but no.
    With the Colt I've been able to tend to its similar issue myself, but have no idea with theTriton.
    Has someone had a similar experience and if so, where is the little actuator pump/vacuum switch/solenoid/sensor culprit thingy situated so I could address it?
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
    Thanked: 1986
    mine does the same
    Training: 4x4, bush mechanics, recovery, defensive, 4x4 trucks
    Supply and manufacture: Recovery gear, Custom 4x4 installations and manufacturing, 4x4 equipment
    Angel Construction:Turnkey Construction solutions [Indoor shooting ranges, safe rooms, shops and shopfitting,]
    IP CCTV, electric Fencing, Automation,Steel Fabrication. You name it, we can probably build or manufacture it.
    Angel solar :PV systems, rain water harvesting
    [email protected]
    [email protected]
    +27824453301
    Thanked: 1061
    So how do we sort it?
    Nico Swart
    ZS6NJS
    Cambridge, NZ
    Thanked: 20
    The system on the colt and triton is very similar.
    Check the switch on the front diff. They are very problematic.
    When Idling check that the front propshaft is free to turn, when out of 4x4.
    If it turns the wheels the entire time, then the two vacuum switches are also faulty and need to be replaced. They sit under the airfilter on the inside of the fender.
    Check them with a multi meter. They must read 400 ohms or there abouts. If they not even close, then replace them as e set.
    2002 Colt, 2.8 tdi Rodeo, 4x4, ARB Bull Bar, Excalliber Running Boards, Monroe Gas Magnum Shocks, Cooper AT3's, Excel 53l long range tank, National Luna Dual Battery System, Campmaster 80l Fridge/Freezer Combo, FrontRunner Fridge slide and Bin Slide, Alpha Gte Canopy with FrontRunner Roof Rack and Homemade Awning...Pulling a Caravan sometimes
    Thanked: 1061
    Quote Originally Posted by Haydn View Post
    Thanks Haydn,
    It appears that the system is indeed very similar to Colt in that the vacuum switches are situated in the same location.
    I will check on this and report back here.
    Nico Swart
    ZS6NJS
    Thanked: 1061
    OK, so I've decided on today to try and sort out my 4x4 flashing lights issue.
    I actually planned on taking off and cleaning my air inlet manifolt but got discouraged when I saw what a big job it is. I'll rather leave that one for the experts.
    Haydn, a 1st inspection revealed no vacuum switches at all near or under the airfilter housing. I know on the Colt this is where they're located. Maybe the 3.2's and the 2.5's differ in this regard?
    I''ll check the switch at the front diff next.
    Nico Swart
    ZS6NJS
    Thanked: 1061
    Ok, I have found and solved the problem.
    Still don't know where those vacuum switches are, but they're defintely on the driver's side near the air box.
    On the pics you will see the 2 rubber pipes coming from those hidden vacuum swtiches and terminating in the little actuator pump. I found the one to have worn through and you can clearly see something rubbed against it. This is actually cause for concern as I cannot see what did this.
    Luckily it is close to the actuator nozzle so I just cut and slid the pipe further over the nozzle.
    Then there is the shaft that when activated by the actuator pump, slides left and right to engage or disengage 4x4.
    Look how dirty it was with a grinding paste like substance at both ends. I cleaned it off and gave it a good whirl with good old Q20.
    The shaft moves more freely now and 4x4 lights off! Hapiness.
ID:	266287   Click image for larger version.
ID:	266288   Click image for larger version.
ID:	266289   Click image for larger version.
ID:	266290   Click image for larger version.
ID:	266291   Click image for larger version.
ID:	266292   Click image for larger version.
    Nico Swart
    ZS6NJS
    Thanked: 308
    I might have to also have a look at mine, also seems to be acting up
    Jul 2009
    Vioolsdrift
    Thanked: 140
    Nico dankie vir die fotos, myne maak nog niks maar ek kan nou bietjie inspeksie hou.
    Cambridge, NZ
    Thanked: 20
    Yes that will definately cause the flashing green light problem.
    Trace those rubber pipes up into the engine compartment and you will fined the two vacuum/electric switches.
    But no need if the problem solved
    Aug 2010
    Thanked: 23
    I put flexible tubing over it as I kept having the same issue. After doing so the hose never got damaged on my colt but by the time I sold it the outer tubing I installed was breaking apart.
    Sent from my iPhone using Tapatalk
    Pajero Sport 2014
    Polo 2018
    Audi A4 2018
    C220D 2015 ( Sold)
    Pajero Sport 2010 (Sold)
    Colt 2.8TDI 4x4 2005 ( Sold)
    Ranger 4x4 1998 (sold)
    Mazda Rustler 1995 ( sold)
    Thanked: 1061
    It's a pleasure guys.
    I just glad I could sort it myself.
    My sump plates had a few dents in them and they cover the diff and the actuator pump and the shaft.
    Wondering if it is possible that a hard knock could've caused the pype to sheer where it had. In other words a knock so hard that the sump plate traveled up far enough to squash the pipe against the nozzle?
    I think it may be time for a bash plate.
    Nico Swart
    ZS6NJS
    Jul 2017
    Van Wyksdorp
    Thanked: 947
    Default Re: Triton 4x4 Lights flashing
    Nico jy is n yster. Baie dankie.
    Daar is my flikkerende liggie ook gesort
    Hulle noem my Jacques (en n paar ander dinge)
    Trailblazer 2.8 A/T 4x4
    Kombi 2.0 75kw (Not the best I have ever had)
    Triton 3.2 Auto 4x4(SOLD- no use keeping something permanently in the garage)
    Qashqai 2.0 2+(SOLD- Was a very good vehicle, can highly recommend it)
    Thanked: 1061
    Quote Originally Posted by jooste777 View Post
    Happinesssss!!!!!!
    Nico Swart
    ZS6NJS
  15. The Following User Says Thank You to Die SwartKat For This Useful Post:
  1. Hazard Lights Flashing
    By AMA-ZING in forum Land Rover
    Last Post: 2014/01/06, 02:18 PM
  2. Dewildt in STD Jeep GC WJ
    By andrewbuch in forum 4x4 Trails / Routes / Clubs
    Last Post: 2011/12/02, 12:31 PM
  3. Flashing 4x4 Lights not flashing
    By otto1 in forum Mitsubishi
    Last Post: 2011/09/30, 04:23 PM
  4. Triton 4x4 - Take 1
    By Eurard in forum Mitsubishi
    Last Post: 2011/04/20, 07:35 PM
  5. Which 4x4 Triton - 3.2 or 2.5?
    By CjvR in forum Mitsubishi
    Last Post: 2010/06/09, 11:06 AM
