Page 1 of 15 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 20 of 297
    May 2012
    Namibia
    Thanked: 36
    Default Another 2SO Story
    I have another 2SO story
    Just recently came back from a long trip to Kunene, van Zyl's etc. in my Td5... About half way through the trip my lift pump in the fuel tank started screaming like a dying squirrel. Added a bottle of 2SO to the next fill up and no more screaming pump. Funny.
    1999 Land Rover Defender 90 Td5
    2003 Yamaha YZ250
    1997 Jeep Cherokee XJ, 3 inch Pro comp, TBS, Powerflow, MT's 10x9.5 - Sold
    Maun
    Thanked: 143
    Shows it works !!!
    Thanked: 356
    wonder if it will work on the kids when they are screaming in the car on long trips ....mmmm
    D90
    D130
    Thanked: 490
    Quote Originally Posted by BrendanR View Post
    George Bosch
    Distributor for:
    Oct 2007
    Thanked: 8
    Quote Originally Posted by D-tox View Post
    Only if they sound like dying squirrels
    Sent from my S3 with Tapatalk 4
    Now
    2011 Disco 4 SDV6 S
    Then
    '99 Defender 90 TDi
    2004 Discovery 2 TD5 GS
    2004 Discovery 2 TD5 GS - Yes, had two of them
    2007 Defender 110 Puma
    2008 Discovery 3 TDv6 S
    2011 Conqueror Companion
    2012 Defender 90 P/U LE
    Thanked: 3030
    It will prolong the pump's life due to the added lubricity but it won't "fix" the pump.
    Start saving for a pump regardless.
    May 2012
    Namibia
    Thanked: 36
    Yup, at 4.5k for a new pump i've started saving already
    2003 Yamaha YZ250
    Thanked: 48
    There is a cheaper solution somewhere on this forum. I think Discomad posted it - quite recently.
    Best regards
    Philip
    LR: '11 Rangie 5.0 S/C & '01 Disco 2 XS 4.6 V8
    Ford: '19 Ranger 3.2 XLS Manual SuperCab 4x4 (XLT was horrible)
    Chevrolet: '70 C10 350ci / 700R4 (4-sp Overdrive) & '59 Apache (Stepside)
    Apr 2011
    Thanked: 1059
    Quote Originally Posted by LRwit View Post
    I was abou t ask what makes this pump so much more special/expensive than the pump a V8 RRC or Disco 1 uses?
    I used to buy an intank fuel pump for the RRC at R400. Pumped at 3....something bar IIRC?
    Aug 2010
    Thanked: 16
    The latest Car have a writeup on feul and the additives. According to the article Sasol did a test and 2 stroke does not have a measurable effect on lubricity and because 2 Stroke apparently contains heavy metals it damages the injector holes during prolonged use.
    Interestingly Sasol is also the only feul retailer that add additives to increase lubricity.
    I thought I was wrong, but I was mistaken.
    Thanked: 48
    Quote Originally Posted by Tanrack View Post
    And the effect of heavy metals on Lambda sensors and Catalytic convertors?
    Best regards
    Philip
    Aug 2010
    Thanked: 16
    I have no idea. From the article I assume that the test centered around lubricity and injector life.
    Thanked: 490
    Hi All
    it is awesome how some of you guys love to debate in circles, like a dog trying to catch its own tail
    LRWit 2sO in diesel REDUCES smoking compared to the normal running of a diesel motor, especially under heavy load, low revs condition. Now reduced amounts of smoke mean a cleaner more complete combustion. And that is what prolongs the life of cats, DPF's and also what keeps exhaust sensors clean.
    LRWit a dirty partially clogged EGR is a much bigger threat to exhaust sensors on diesel engines than 2sO mixed into diesel at a rate of 5ml per litre.
    I have stocked up on popcorn and I will enjoy following this thread!!!
    George Bosch
    Distributor for:
    May 2012
    Namibia
    Thanked: 36
    Tried to get hold of the VDO pump unit alone from Diesel Elec. but up here in Nam they say its not available on their system. Any other options out there?
    2003 Yamaha YZ250
    Thanked: 3030
    I dont know what test they did but an independant study proved that 2SO adds lubricity.
    Why the hell do we add it to 2 stroke engines in the first place?
    http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
    Sent from my iPad using Tapatalk HD
    Thanked: 48
    Hi All
    George, it is VERY clear that you are utterly convinced that its safe to use 2SO on Lambda and CAT equipped cars.
    I remain unconvinced BUT I AM NOT STATING THAT ITS NOT SAFE EITHER!!
    So, unless you or whoever present categoric, credible, verifyable, scientific PROOF or reference to such evidence, that 2SO IS NOT HARMFULL to either, I will remain concerned (even if I am the only one to have - and voice - such concerns) about the POSSIBLY negative consequences your persistent recommendation of 2SO might have on those lamba/CAT equipped engines who's owners accept your (and other's) 2SO advice as "good, sound & safe advice".
    So, if I'm debating in a circle like a dog trying to catch its own tail - then its AWESOME!!!
    Since my concerns seem to trouble you - I will hence forth remain silent on this matter. Its no skin off my back.
    Best regards
    Philip
    Bellville
    You have zero control over the application of the advice regardless of your good intentions.
    I do not believe a Lambda sensor can survive 2SO additives.
    I do not believe a CAT can survive when a dirty system suddenly gets cleaned with 2SO additives.
    I do think it would be wiser to not only punt the benefits, but also point out some possible precautions, regardless of how small they might be.
    Always safer than sorry.
    Driven by passion
    Jakes 071 9855 258
    Henties
    Thanked: 1876
    Sorry Marius, but that on it's own is not an argument. 2SO is meant to be added to petrol used in 2 stroke engines. Petrol does have much lower lubricity than diesel and hence the addition of 2 stroke oil to petrol in 2 stroke engines is essential.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
    Springs
    Thanked: 287
    if you understand that a 2 stroke petrol engine has no sump with oil in it, you will understand why lubrication needs to be added to prevent things from seizing up
    Thanked: 3030
    My point is that these two posts
    Quote Originally Posted by Landyluvver View Post
    Contradicts this post
    I agree that the magical effects of 2SO are debatable but the fact that it adds lubricity is not debatable. Its a fact!
    I understand 2S engines very well and if 2SO is good enough to lubricate a 2S engine then it is definitely beneficial (even in our low ratios) in terms of lubrication in our diesel engines for the injectors and HPFP..... As proven in the study I posted earlier.
  1. 2sO Damages Diesel Engines
    By Disco-Deon in forum The 4x4 Pub
    Last Post: 2013/11/05, 08:37 AM
  2. 2SO question
    By TaunB in forum General 4x4 Discussion
    Last Post: 2013/06/07, 11:43 AM
  3. 2SO - The breakdown
    By MariusFourie in forum Vehicle & Technical Chat - General
    Last Post: 2013/04/16, 07:59 AM
  4. Diesel 50ppm + 2SO vs 500ppm with no 2SO?
    By LetsDisco in forum Land Rover
    Last Post: 2012/10/08, 10:16 PM
  5. Predators and Small ones (children) - is this a true story ?
    By jan.dup in forum General 4x4 Discussion
    Last Post: 2011/07/30, 01:23 PM
