Clutch problem Cherokee 2,4 Sport Manual
Results 1 to 4 of 4
    Jan 2007
    Default Clutch problem Cherokee 2,4 Sport Manual
    Hi guys
    Friend of mine's 05 2.4 sport manual is giving clutch or hydraulic clutch actuator problem , we think it's clutch (but not sure) , the symptoms were that depressing the clutch , the clutch pedal became extremely hard to depress and suddenly something gave and now he can not get the car in gear while the car is idling
    Like to know could he opt for a FUCHS kit or any other Ideas ??
    The dealers quote is R2400 for clutch plate, Pressure plate and thrust bearing (Spares only)
    Are the other afternarket stuff worth it ??
    Me thinks not , but what are your ideas !!
    Land Cruiser 105 GX 4.5 EFI
    Jurgens Xplorer I
    BMW 1200 GS Adventure
    De Kelders
    Thanked: 131
    If it has a hydraulic clutch the slave cylinder may have exploded, dont laugh , it happened to my MK1 Cortina.
    Fuchs? You sure it is not Sachs.
    Thanked: 42
    Check the hydraulics first.
    Any sign of fluid leakage? What is the fluid level in the master cylinder resevoir? After the stiff clutch what does it feel like now?
    Unbolt the slave cylinger and see it there is any movement on the actuator rod when depressing the clutch.
    Andre
    PS. It is Sachs and there might well be a aftermarket clutch kit available. Sachs, Rhine Valeo, LUK Repco are all reputable.
    2010 JKU Rubicon
    Jan 2007
    Thanks Andre
    Sorry , yip you are corect it's SACHS
    Jurgens Xplorer I
    By charlatan in forum Jeep
  2. Cherokee Sport Overland
    By RGoosen in forum Jeep
    Last Post: 2011/06/05, 12:09 PM
  3. Odd Clutch Problem
    By SimonB in forum Vehicle & Technical Chat - General
    Last Post: 2009/05/04, 11:25 AM
  4. Replies: 8
    Last Post: 2008/01/07, 06:04 PM
  5. Cherokee KJ suspension problem
    By Anton72 in forum Jeep
    Last Post: 2007/09/10, 09:45 AM
