Solar panel battery charger
Results 1 to 7 of 7
    Nov 2012
    Default Solar panel battery charger
    Yes, I did search, but the solutions that came up dealt with either dual battery systems, or maintaining a 12V system for a campsite.
    Years ago I vaguely remember that one could buy these little solar panels that you put on the dashboard and plugged into the cigarette lighter socket. They'd then quietly keep the battery charged - perfect for vehicles that end up standing for a while.
    I'm looking for something like that, or an alternate idea to maintain the T'can's battery over extended periods (up to three months). Doesn't have to be able to charge the battery, but should be able to maintain it at roughly 12V and be able to compensate for the minor drain of electronics of a parked car.
    Running an extension lead is not an option.
    Open to ideas and suggestions please!
    Last edited by athansor; 2013/09/13 at 06:51 PM. Reason: Change notification status
    aka Jason
    Thanked: 19
    Must it be solar?
    Donkerhoek, Pretoria
    Thanked: 19
    Nov 2012
    @Fanatic: No, doesn't have to be solar, but solar is convenient. Open to other ideas and suggestions...
    @moetbiedjiewegkom: thanks for the link! I'll check it out.
    aka Jason
    Thanked: 19
    A simple trickle charger from Midas is about R450. It's about the size of a packet of cigarettes.
    Works very well to keep the battery fully charged.
    Thanked: 19
    Oops...saw now you say running an extension is a problem...
    Then why not get a small solar panel and regulator. That would work as well.
    Nov 2012
    Quote Originally Posted by Fanatic View Post
    That would probably be a better, more useful solution - can then use it in a campsite as well.
    Back to "search" and see how the budget can deal with it. The bidorbuy option is cheap enough to try for a short while at least.
    aka Jason
  1. Benton BX-1(M), BX-2, BX-4, BX-5 Multi-Stage Automatic Battery Chargers
    By Family_Dog in forum Camping, Fridges, Accessories
    Last Post: 2020/05/17, 09:35 AM
  2. Solar powered camping
    By pikkewyn in forum Camping, Fridges, Accessories
    Last Post: 2018/01/09, 07:58 PM
  3. solar panel and charger suppliers ...
    By Elders in forum Camping, Fridges, Accessories
    Last Post: 2013/02/01, 02:09 PM
  4. Stoor van battery
    By HendrikG in forum Camping, Fridges, Accessories
    Last Post: 2010/09/28, 03:59 PM
  5. U.P.S. as a battery charger
    By Gert du Preez in forum Camping, Fridges, Accessories
    Last Post: 2010/09/20, 09:19 PM
