Results 1 to 4 of 4
    Default Daihatsu Terios using oil - no smoke
    SWAMBO's 2006 Terios (1.5L petrol Auto) is using in the order of 1.5L of oil over a 3 week period (1500 km's) with no significant oil leaks visible and not smoking excessively. It doesn't seem to run hot or exhibit any other symptoms.
    Any idea's? Hoping this wont be an expensive exercise!
    '06 Isuzu Kb 300 TDi LX 4x4 D/C
    Jun 2008
    kleinmond
    Thanked: 117
    Default Re: Daihatsu Terios using oil - no smoke
    also have the same issue with my daughters, no clever ppl out there
    Landrover Puma 110, OME - sold
    Imagine Trailvan
    Disco1 V8 - sold
    Disco 4 V8 HSE -passed away 6/7/21
    Thanked: 109
    Quote Originally Posted by PaulG View Post
    With the amount of info you supplied only someone with a crystal ball will be able to help you
    How many kilo's has the car done?
    What oil do yo use?
    How does your wife drive? If she drives like a granny, no pun intended, the engine sleeves may be glazing.
    Does she only drive short distances?
    Greyton westerncape
    Thanked: 92
    Post Re: Daihatsu Terios using oil - no smoke
    Toyota motor so should be ok.more info needed,milage ?
  1. Navara oil pump failure
    By Ace in forum Nissan
    Last Post: 2020/08/31, 11:40 PM
  2. diesel fuel
    By Landyluvver in forum Land Rover
    Last Post: 2012/03/04, 07:05 PM
  3. Oil Change: men vs women
    By Hello2Africa in forum The 4x4 Pub
    Last Post: 2010/05/09, 09:13 PM
  4. Daihatsu terios Key - Help
    By warrenaken in forum General 4x4 Discussion
    Last Post: 2010/03/17, 02:21 PM
  5. Buying oil
    By OFFROAD ADDICT in forum General 4x4 Discussion
    Last Post: 2008/07/04, 10:25 AM
