Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 41
    Pietermaritzburg
    Default Endless hot shower from your vehicle
    I have been toying with the idea of fitting a heat exchanger to my defender to make hot water for a shower when camping in remote places. I have battled to find one locally so decided to make one myself. It works really well and fits neatly into the void under the turbo on a TD5. The exchanger heats river water to 40 degrees Celsius in real time on one pass through while the engine is idling. I have uploaded a video to Youtube showing how it works http://www.youtube.com/watch?v=Bj10ZyKWRaY
    Sure makes for happy camping in remote places as hot showers are no longer a prerequisite.
    North of Rooiberg.
    Please give more details on the actual exchanger. do you have coiled copper on the inside?
    Werner Smit
    2001 Defender 130 TD5
    2005 Discovery 3 TDV6
    2003 Discovery 2 TD5
    1999 Discovery 1 300tdi with lots of mods
    19 something Forward Control 2B
    Klipriver
    Thanked: 570
    Very interesting, how would /could a person adjust the temperature/ flow rate so that one doesn't burn oneself?
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
    May 2012
    Namibia
    Thanked: 36
    any chance of some pics for those of us with no youtube access at work?
    1999 Land Rover Defender 90 Td5
    2003 Yamaha YZ250
    1997 Jeep Cherokee XJ, 3 inch Pro comp, TBS, Powerflow, MT's 10x9.5 - Sold
    North of Rooiberg.
    Quote Originally Posted by All -in -one View Post
    Guess you could put a tap in the line (radiator water line from engine) to manage the amount of hot water to the exchanger?
    less hot water flow = colder water?
    Werner Smit
    Pietermaritzburg
    Yes there is a copper coil in the exchanger. Was trial and error as to how long it had to be and how far to compress the pipe in order to extract sufficient heat. But there is a trade off between the amount of heat you draw out the cooling system as the more efficient the process, the quicker the vehicle cools down. I think I have the balance right now as I am getting hot water for at least 10 minutes and the vehicle temperature is stable.
    Klipriver
    Thanked: 570
    Quote Originally Posted by Ystervark View Post
    I was thinking perhaps a bigger pump in the cold water, then regulate that flow. Obviously the faster you pump water through the heat exchanger the less time it has to get hot, and vice versa, ...............
    or have I got it all wrong
    Alan
    _________________
    Range Rover P38
    Jun 2007
    Thanked: 33
    Current planet killers
    Range Rover Sport
    Colt Rodeo 2800
    Land Cruiser 79 V6
    Previous
    SIII Chevy 4.1 Straight 6
    Forward Control SII
    Rangie Classic 3.5 V8
    Rangie Classic Chevy 5.7 V8
    Defender 2.8 Straight 6
    Disco 1 3.5 V8
    Disco 3 TDV6
    Disco 3 V8
    Disco 1 V8
    Disco 2 TD5
    Disco 3 V8
    http://heine9999.wordpress.com/
    Pietermaritzburg
    I have taken the coolant supply going to the heater and passed it through the exchanger. If one kept the heater in "series", then the heater dial in the vehicle would control the flow rate of coolant passing through the exchanger and thereby control the water temperature. The submersible pump is delivering water through the exchanger at 2 litres per minute, so I fitted a flow regulating valve on the shower hose. If I need the water to be hotter, then I simply slow down the flow rate. It is only the first bit of water that has been standing in the copper coil that comes out at the same temperature as the coolant when you first turn the pump on. It is really hot!
    Feb 2013
    Wellington
    Or put a branching pipe between the submersible pump's pipe and the shower head outlet pipe with a valve so you could udjust the amount of cold water mixing with the hot water.
    Pietermaritzburg
    Quote Originally Posted by heine View Post
    Thanks Heine
    I saw this setup on line - If you have the tank already, then you can get away with a smaller heat exchanger. I wanted to get around the need for a storage tank. I have found that it only takes 2 minutes to heat half a bucket of water if you circulate the water.
    Jun 2007
    Thanked: 33
    Mine comes out the exchanger at about 65 deg if I set the heater control in the car to max. I don't circulate the water to heat it , but rather to prevent you having to switch it off while showering , as this causes the water in the pipes to get dangerously hot
    Range Rover Sport
    Colt Rodeo 2800
    Land Cruiser 79 V6
    Previous
    Forward Control SII
    Disco 1 3.5 V8
    Disco 3 TDV6
    Disco 3 V8
    Disco 1 V8
    Disco 2 TD5
    Disco 3 V8
    cape Town - 0624206806
    Thanked: 800
    Nice stuff this modern technology.....
    in the old days, we used to wrap a copper pipe around the exhaust and heat up a tank of water.....was a bit of a bastard to regulate the flow when you had a bucket shower.......too hot , just right, too cold
    Thanked: 8
    That's brilliant. Showering right in the river not exactly environmentally friendly though
    Having a collapsible tank would resolve that though.
    Care to divulge more on the dimensions and cost of the project.
    ___________________________
    98 Defender 110CSW 300TDI
    2015 Discovery 4 SDV6 HSE
    97 Discovery V8i
    2010 Freelander 2 HSE (SOLD)
    You can go fast but....I can go anywhere!
    doonside
    Seen that idea many years ago. Good if you traveling. If I had to do that with my rangie it would cost me R40 every shower. V8 powered shower is not that effective. I prefer using a copper coil over a gas burner. Instant heat, no need to let the vehicle idle for half an hour waiting for it to get up to temperature.
    Wesley
    1988 Range Rover 4 door. 2.7 turbo diesel. 4.7:1 diff ratios. 2" body lift. 255/85R16 maxxis bighorn's + camel cut. AKA: shady
    A true oil burner that runs on Black Diesel.
    Jun 2007
    Thanked: 33
    Mine is ready after 5 min. Depends on the size of your heat exchanger
    Sent from my GT-N7100 using Tapatalk 2
    Range Rover Sport
    Colt Rodeo 2800
    Land Cruiser 79 V6
    Previous
    Forward Control SII
    Disco 1 3.5 V8
    Disco 3 TDV6
    Disco 3 V8
    Disco 1 V8
    Disco 2 TD5
    Disco 3 V8
    King Williams Town
    Thanked: 2946
    BigAl,fantastic set up.Did u buy the heat exchanger unit or make it up.
    Craig
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Pietermaritzburg
    Hi Craig. Made the exchanger up myself with lots of trial and error - kinking the copper pipe becomes expensive!!!. A friend has asked to me to make one up one for him, so I will do a more accurate costing and post when I have finished. Dimensions of the exchanger are 420mm long and 120mm in diameter at the widest point.
    Brits
    Quote Originally Posted by NeilFourie View Post
    +1
    Rulof
    Ford 3.0TDCI DC 4x4 2008- Wit Blits. LR Defender90 2.8i.-Bulletjie. Heeltyd speeltyd!!!
    ......you only experience the bush when the engine is switched off
    <v:shape id="_x0000_i1025" style="width: 415.5pt; height: 105pt;" type="#_x0000_t75"><v:imagedata src="file:///C:%5CTEMP%5Cmsohtml1%5C01%5Cclip_image001.jpg" o:title="untitled"></v:imagedata></v:shape>
    Bellville
    Quote Originally Posted by terratiger View Post
    TD5's only leak oil either from the oil filter area, drain plug, front inspection cover, vacuum pipe, rear of rocker cover gasket and diesel from the fuel pressure regulator.
    This was carefully planned to drip down the area between the front bumper and driver's door.
    So in this case the "inventor" made every effort to park his vehicle, exactly with the front wheel in the clean water stream & upstream from the submersible pump in order to detect any pollutant as soon as it runs down his face...
    The TD5 has a fuel cooler on the other side doing exactly what you want... ever wondered if it's really needed for fuel?
    Driven by passion
    Jakes 071 9855 258
  1. Towing Regulations
    By Ant in forum Trailers, Caravans, Towing etc
    Last Post: 2023/11/13, 09:30 AM
  2. Towing with an A frame
    By Woolf in forum Trailers, Caravans, Towing etc
    Last Post: 2012/02/15, 10:57 AM
  3. Replies: 110
    Last Post: 2011/11/25, 04:43 PM
  4. What license?
    By Brian1 in forum The 4x4 Pub
    Last Post: 2011/03/24, 06:45 PM
  5. First licence suspension
    By Ore in forum The 4x4 Pub
    Last Post: 2010/12/21, 09:30 AM
