Ford & Mazda Alternator & Sediment Light - 2001 Drifter B2500 TDi 4x4
Results 1 to 4 of 4
    May 2013
    Default Alternator & Sediment Light - 2001 Drifter B2500 TDi 4x4
    Hi All,
    A little back I had the head of my bakkie replaced due to overheating (and after changing the radiator). Since then there seems to be some sort of electrical problem.
    Over the weekend it appeared that the alternator was not charging (or at one stage over-charging) so yesterday, I replaced the regulator and the fan belts (just to be on the safe side). Testing the alternator (using a multi-meter) it seems to working as required.
    However, the Alternator and Sediment Filter lights are constantly on. This happened just after the replacement of the head but seemed to solve it self i.e. the lights went off. The fuel filter is less than 5,000km old.
    Now they are back again.
    Also, this morning the rev counter & spedometer went to max when turing the key on and stayed there. Again, it seemed to solve itself a few min. later. To me this indicates some sort of earthage problem.
    Any suggestions as to why these lights are on and where I should start investigating..
    Any help will be appreciated.
    Thanx
    DW
    HI, had a similar problem, the lights came on barely visible while driving and increased slightly in brightness when revs when up, popping sounds on the radio, everything going off when the brights were engaged, immobiliser doing strange things. I fixed my cables going into the battery connectors, plus and negative, seems the crimping comes loose after years and does not make a decent connection, worth a try, hope it will solve your issue. Havent had the problem again. Traced it to the plus terminal connector, all electrics was dead, opened the bonnet and by chance just pushed the cable and everything came to life. Somewhere there is a thread about an earth in the wiring loom close to the firewall that has spot welding which comes loose also.
    2000 Drifter SLX DC 2.5 TD
    Mar 2013
    Brakpan
    Check the earth cable at the back of the head that goes to the firewall, maybe they didn't fasten it properly
    May 2013
    Hi,
    Been a while, so thought I would just provide an update.
    I tried the above suggestions with no luck. Then out of the blue the lights went off and is still off. So I don't know what happened and why....
    Thanx none-the-less for the advice though
    DW
  1. Brakkeduine 4x4 Trail near PE.
    Last Post: 2017/11/13, 07:56 AM
  2. Females
  3. Replies: 12
    Last Post: 2007/07/24, 10:10 AM
  4. Another bash at The Rocky Mounatin 4x4 Trail
    Last Post: 2007/02/20, 01:19 PM
  5. Search Engines
    By benhur in forum General 4x4 Discussion
    Last Post: 2006/09/14, 09:42 PM
