Results 1 to 15 of 15
    Jeffreysbay
    Default TD5 Transfer box ratio
    Needing some info as I have noticed that my 2004 defender 110 TD5's transfer box ratio is given as 1,667:1 according to the sticker on the box.
    Interestingly going by the Ashcroft ratio calculator on the web it appears that the TD5 comes standard with a 1,441 ration box and not a 1,667 as per mine.
    Would love to reduce the engine refs for a more comfortable cruising though as I can get hold of a D2 1,221 ratio box for a straight swap, which actually started the idea.
    Having the issue with the sticker indicating 1,667 ratio, could I please ask other Defender 110 TD5 owners to comfirm the engine revolutions at say 100kmh and 120kmh in 5th gear. Mine runs at a little over 2500rpm @100kmh and at 120kmh approximately 3100rpm.
    Has a conversion like this been attempted before and if so, what is the verdict?
    Would appreciate any feedback.
    Thanks,
    Wessel
    Thanked: 25
    Both my td5 are 120km/h @ about 3000rpm. Yours might be 120km/h @ 3100rpm due to transfer ratio or tire size? Im running 235 85 R16. Will have a look at the ratio on the transfer case tomorrow. If I remember correctly LRWit is running a disco transfer case in his defender, ask him.
    Jeffreysbay
    Thanks for the response. I am running 265/75/16 Bridgestones. Might be the difference in tyre size only as according to the Ashcroft ratio calculator the 1,667 ratio should run 3986rpm @ 65mph (104kmh) in 4th, being the direct drive. I checked yesterday and my Defender runs approx. 3500rpm @ 105kmh in 4th.
    I am now fairly confident that the indication of 1,667 ratio on my box is wrong and I am actually running a 1,41 ratio box
    Thanks again and I will try and contact LRWit for more info.
    Melkbosstrand
    Thanked: 492
    Tyre size does not affect the relationship between speedo and rev counter. It only impacts true speed (GPS) vs revs
    Yes, LRWit has a Disco TC.
    Rob
    Disco 3 SE TDV6
    Disco 2 ES TD5. Custom map, V8 TC
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Jeffreysbay
    I would like to post the outcome of my query above in that the plunge was taken and the transfer box swaps were successfully done.
    My Defender now sits with a 1.221 ratio transfer box ex 1998 Disco 1 Auto and found the end result very satisfying. Engine revolutions at a comfortable 110 km/h is approx 2500rpm and it does not sound like it wants to take off and starts flying anymore. Sound levels is also much quieter and I can listen to my favorite Boere musiek again.
    Have not had the opportunity to travel a longish distance as yet but hope to soon. Fuel consumption will be measured over a period and will report back for whoever wants to know. Planning a three week tour of the Northern Natal, Mpumalanga and Swaziland Nature reserves next month using back roads as much as possible.
    Looking forward to it and counting the days/hours.
    Thank you to LRwit for information and re-assurance of the feasibility of the conversion.
    Thanked: 188
    Awesome!!
    WE married up my Td5 to a D2 V8. I am also very very happy with the outcome!!
    Have you had her offroad yet?? would love to know what she feels like in 1st and 2nd low, and still have to take her of the beaten track!!
    My wife is simple, in a complicated way
    Jan 2009
    Thanked: 113
    Quote Originally Posted by Benson View Post
    Awesome!!
    As far as I know the low range ratio stays the same.. It's onlyu high range that is different
    Range Rover Big Body 5.0 V8 Supercharged
    Land Rover Defender 110 V8 Game viewer
    Land Rover Defender 100 PU V8
    Land Rover Freelander II SD4
    Jaguar XJS V12
    Jeffreysbay
    Yes, low range stays the same so offroad in low range will not be different. Because high range is now lower means more comfortable high speed (110 kmh !!!!!) cruising, also 120 kmp if you want to albeit slightly less power for uphill driving. Is not an issue because of the other advantages such as less engine noise and expected extended engine life.
    Springs
    Thanked: 287
    to the best of knowledge it was only the 2.8 BM defender that ran the 1.6:1 ratio TC
    May 2021
    rosetta
    Question Re: TD5 Transfer box ratio
    hi all
    got a 2004 Disco 2 V8 Auto. does anyone have an idea what the transfer case ratio is and is there a better ratio for long distance cruising?
    Thanked: 20097
    Default Re: TD5 Transfer box ratio
    Quote Originally Posted by Vido Da Luca View Post
    hi all
    T-case ratio is 1.211
    Ashcroft sells a 1.1 ratio gear. This will however only drop your revs by 300rpm @ 120 km/h.
    Fastest, cheapest solution for long distance cruising is larger diameter tyres...........
    Jakes Louw
    Mar 2015
    New Germany
    Thanked: 1111
    You can go down to a 1.001 ratio to land that gear cluster you looking about 10k then you still need to strip LT230 and install gear cluster
    2005 Defender TD5
    Thanked: 20097
    If you can still find that old Range Rover gear set.............
    Jakes Louw
    Mar 2015
    New Germany
    Thanked: 1111
    Ashcrofts still do it as imported one 2 months ago for a LT230 had to build for some one thatís why said about 10k to land it
    2005 Defender TD5
    cape Town - 0624206806
    Thanked: 565
    Iíve got one.... (behind a RR LT77S - in Puttanesca)
  1. Replies: 32
    Last Post: 2015/08/21, 09:39 AM
  2. Fortuner Gearbox, propshaft, transfer box
    By sarelb in forum Toyota
    Last Post: 2013/07/17, 07:37 AM
  3. Discovery 2: Transfer Box
    By johnB2 in forum Land Rover
    Last Post: 2013/07/11, 04:41 PM
  4. Seels, iets werd?
    By witklipbank in forum The 4x4 Pub
    Last Post: 2013/05/30, 03:51 PM
  5. Series II Transfer Box Problem
    By Kooos in forum Land Rover
    Last Post: 2010/12/22, 02:35 PM
