4 Amp Charger
Results 1 to 3 of 3
Thread: 4 Amp Charger
    May 2007
    Welgelegen, Cape Town
    Thanked: 123
    Question 4 Amp Charger
    I discovered a 4 amp charger in my garage the other day or yes dusted it off. Does the charger charge 4 amps per hour or how does it work? I have recently aquired a 102 amp high cycle battery. Would one assume then that this battery would take 102\4 = hours to charge??
    Klerksdorp
    Thanked: 341
    Yep, at least! Normally, a while longer because as the battery voltage rises, the amperage from the battery charger falls. But be careful of trying to use it as a permanent charger, it will eventually overcharge the battery because it will never 'switch off" completely. A regulated battery charger does just this, measuring the battery voltage and adjusting the charge rate accordingly, from max to a nominal trickle to charge to just keep the battery topped up in a standby mode.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
    Dec 2007
    nelspruit
    Thanked: 50
    Quote Originally Posted by johanvb View Post
    Look at the back of the charger its usely half of that in front dont be fooled , then you can do your maths. the charge time depends of how many amps did you draw against time.
  1. Benton BX2 Dummies Guide!
    Last Post: 2019/04/09, 02:07 PM
  2. Dissapointed in my CTEK Charger
    By Fritzie in forum Camping, Fridges, Accessories
    Last Post: 2017/08/24, 05:21 PM
  3. Part catalogs & other useful info
    By charlatan in forum Jeep
  4. Stoor van battery
    By HendrikG in forum Camping, Fridges, Accessories
    Last Post: 2010/09/28, 03:59 PM
  5. Advise on battery charger selection
    By HennieL in forum Camping, Fridges, Accessories
    Last Post: 2010/07/22, 08:26 PM
