Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 56
    Thanked: 1966
    Default Another Project: 1947 Farmall Super A
    1947 Farmall Super A.
    My Grandpa bought it in 1961. I was taught to weld with this tractor, it had a Eclipse welder on.
    It was parked in more or less 1990. I got it running again in 2000. I picked it up from my Dad three weeks ago with the best intentions of restoring it to original.
    1800 cc Petrol/Parrafin engine, The A had 12 Hp, this is a Super A, 14 HP!!!!!
    And what it should look like.
Name:	2013-07-13 15.22.34.jpg
ID:	226501   Click image for larger version.
Name:	2013-07-13 15.26.53.jpg
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    083 399 2046
    Hunters Close, Port Elizabeth
    Thanked: 77
    nice tractor. guy at my church restored an old massey in his garage. he uses it to cut the church grass and stuff.
    Luke aka Jedi
    1954 Landy Rover Series 1 86"- Rambling Rose
    Best company slogan: Cherrybomb performance exhaust, Disturbing the peace since 1968
    Thanked: 451
    Love the crank handle start.
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
    Thanked: 7
    Pragtig Uys
    Strand
    Thanked: 37
    Ai tog, die heimwee. Het op so een, vermoedelik effens nuwer model, geleer ploeg so in die laerskooldae. Vet pret gewees. Het hom ook vie so 5-10 meter op sy agterwiele gery. Was dit nie vir die ploeg nie, het ek hom agteroor getuimel..... :-))
    I might be a FOOL, but I am an OLD fool - from unknown.
    Thanked: 1966
    It stood for 9 months when I picked it up three weeks ago. I cranked it less than 360 degrees and the engine was running.
    It does kill the spark plugs with oil so I investigated. It turned out one sleeve ha some deep gouging marks (1.5mm) and one piston burned through from the third compression ring to the gudgeon pin. Still have to remove pistons 2-4.
    083 399 2046
    Dec 2007
    Harties
    Cool Project!!. please keep us posted!!.
    I like anything with 4 or more wheels...
    Bellville
    Thanked: 727
    Uys you have your priorities arse about face !!! A PETROL farm implement and a DIESEL car !!!! Reminds me of a Pieter Dirk Uys show in PW, years ago, called "Farce about Uys". Students moved the "F" on the PE Opera House info panel to change it to "ARCE ABOUT FUYS"
    Nice tractor, BTW 8)
    Thanked: 1966
    I just ordered a complete rebuild kit.
    Can anybody recommend engineering works that can replace the sleeves for me?
    Uys
    083 399 2046
    durban
    Thanked: 1494
    Why dont you try it yourself ,even if it only costs a little bit more.
    I would be curious to know myself as I might need to find an engineering firm when I go up to your side of the world this Sunday to check on my massey fergusson. Are they finished liners or semi finished.?How hard would it be to make a liner puller to extract these old liners. Someone told me they used to run a cold bead vertically from bottom to top and they would just fall out.If you find a place please let me know
    Thanked: 1966
    I have no clue how easy it would be to extract them ,and even if I get that right, how do I press the new ones in? Blocks for these engines are not exactly lying around, so I'd rather have a pro do it.
    What is a cold bead?
    083 399 2046
    Thanked: 1966
    Look what I just got! Nou so opgewonde ek kan my lus nie hou nie.
    Sent from my GT-I9300 using Tapatalk 2
    083 399 2046
    Gordon's Bay
    Thanked: 4378
    Nice toy Uys!!!
    Suffolk, UK
    Thanked: 37
    Nice Uys! I love a good old tractor.....
    Just make sure that when you spray it up after you have finished the restoration that you spray everything. And I mean everything. Belts, spark plugs, cables, fuel & brake lines. Every single thing other than the tyres, the steering wheel, and the battery.
    Almost like you couldn't be bothered to mask anything off!
    Mike
    "Mike for President" Freeflyd
    Thanked: 1966
    But why?
    083 399 2046
    Teen die Berg langs die See
    Thanked: 291
    Ja why?
    Thanked: 63
    But why?
    That's how it was painted when it was new.
    Thanked: 1966
    Hmmmmm
    083 399 2046
    Hmmmmm
    Hmmmmmm? Wats fout?
    Pat
    Hilux 3.0 D4D 4x4
    Jeffrey's Bay
    Thanked: 13216
    I love old tractors. Spent my holidays on our family farm where my uncle used to collect and restore tractors. I think by the time he passed away he had 20-30 of them. Running and restored, the oldest being a 1928 John Deere.
    On our own small farm (weekend getaway) we had two vintage tractors. One was a 1942 Farmall H which did all of the work, including ploughing etc.
    One like this (unfortunately don't have pics of it with me):
    Which we later put on steel wheels.
    Also had a 1934 McCormick Deering W12. Relatively small tractor, for vineyard or small farm work.
    If only Ihad the space and time....
    Anton van Kampen
    "At the end of the game, the King and the pawn go back into the same box." - Italian Proverb
    "The single most important component of a camera is the twelve inches behind it." - Ansel Adams
  1. Project overhaul
    By brenda101 in forum The 4x4 Pub
    Last Post: 2020/12/12, 07:41 AM
  2. New project - De Wildt (Shingwedzi) Cheetah & Wildlife Farm
    By DouglasN in forum Environmental & Conservation
    Last Post: 2011/10/19, 07:14 PM
  3. Reach for a Dream - Ongoing National Project
    By Jeep Luvva in forum Environmental & Conservation
    Last Post: 2010/12/09, 11:58 AM
  4. Namibian Desert Lion Project
    Last Post: 2010/02/15, 03:29 PM
  5. Super Select Display problem
    By arnijr in forum Mitsubishi
    Last Post: 2009/09/18, 11:10 AM
