Stupidity costs another engine rebuild under 10000km - Page 9
Page 9 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 161 to 180 of 359
  1. #161
    Dec 2012
    In my agterplaas in die WC
    Thanked: 193
    Looks like we sit with the same type of problem. After speaking to Bunchat i came to the conclusion that we had our own "Bermuda triangle" here in South Africa also known as the Vaal Triangle. If you deal with someone in that area...your money will just disappear.
    Sakkie van Staden
    Silver de Lange.2003 WJ Jeep..NOW powered by a 4L VVTI V8 Defy motor Forum Rebuild thread
    2004 Jeep Grand Cherokee 2.7 CRD Diesel power....4 inch Home build Long arm lift
    Past
    Jeep 3.1 Wj..AKA Turbo Esel (RIP)
    Man made it....Man Fix it.....
    I'm going to use all my tools, my God-given ability, and make the best life I can with it.
    LeBron James
  2. #162
    May 2013
    Here's the latest.
    Took the injectors to the workshop that replaced the tips on my missing injectors last August. The owner John, is willing to testify that these are not the ones he worked on last.
    In my presence, he tests these injectors, they're stuffed! We can see on 2 of them that they are not atomizing, it's more like a stream of diesel. One other only sprays out diesel from 2 of the 5 or 6 orifices until heavy pressure is applied. I'd most probably get holes in the pistons in time if I had continued to use these injectors as is.
    I phoned rebuilder to inform him off my findings, "Eh, I'll look for other ones" is the reply I get. Surely, once I take the injector pump in for testing, I'm going to get a similar result. EISH!
    Edit:
    For those of you that are interested, we noted that the spray pattern of the 280 & 300 injectors are identical, thus swapping 300 injectors with 280 injectors is very feasible. The 280 injectors can have all 4 tips replaced for roughly R2k, whereas the 300 injectors are about R1.5k each. A slight pipe modification may be necessary, as well as a set of 4 280 "crows feet", injector retainers.
  3. #163
    Jan 2009
    Germiston
    Thanked: 93
    That said, if you swop 300 foe 280 injectors you must change.the pump also to 280. The 300 injector is a dual stage(whatever that means) 280 diesel pipes then fit perfectly.
    __________________
    '01 Isuzu Frontier LX 4x4 Diesel - For the brown Stuff
    '14 Renault Sandero 900cc Dynamique, small with a big heart
  4. #164
    Sep 2013
    Thanked: 71
    This sounds like such a nightmare! Something like my current issues with Suzuki...
    I hope you eventually come right and I can't believe the chances these guys are taking!
    2009 Pajero Sport 3.2DiD
  5. #165
    Kathu
    Thanked: 2234
    Take your engine away from that clown asp. I knew it is hard to say get a lawyer and sue him for your money or cut your losses.
    I have owned a few Isuzu`s and rebuild a 250 motor once. You need to do very accurate machining , measuring and stick to the manufacturers tolerances 100% or accept it failing within 10 000km. Doing it right and a Suzy engine will last forever.
    Seems this punk cannot even rebuild a Briggs & Stratton must be using a shifting as a micrometer and hacksaw blades for feeler gauges.
  6. #166
    Thanked: 974
    I do believe this oke needs a visit.
    AG PLEASE Bud - let's visit him...
    Stay Safe
    Disco-Deon
    This morning I woke up,
    Making today a great day.
    Nerdy, 2011 Honda Jazz, 1500 Exc
  7. #167
    Jul 2007
    Despatch
    Thanked: 21
    Quote Originally Posted by Disco-Deon View Post
    We can call that the 2nd anual GTG......!
    Offroad junky
    '97 SsangYong Musso 602 EL exec
    '14 Citroen DS4 2.0 HDI swambo's platkar
    Previously;
    '03 Nissan HB 3.0TD D/C 4x4
    '07 Hilux D4D D/C 4x4
    '16 Ford Ranger 2.2 DC XL Hi-Rider
    '12 Disco 4 SDV6 SE - Beauty
    '06 Disco 3 TDV6 S (De-cat, EGR blanked, remap, Johnson rods suspension rods, 285/65-R17 Kuhmo KL61) - Beast
    '04 Terracan 3.5 V6
    '96 Ssang Yong Musso 602 (non turbo manual)
    '04 Ford Ranger 2.5 TDI D/C 4x4 with Solid front axle and 33" Maxxis
  8. #168
    May 2013
    Deon, I can see you feel very strongly about exercising your rights.......and lefts!
  9. #169
    May 2013
    Patience is wearing thin.
    Phoned rebuilder on Monday morning, he was stripping the engine to send in to engineering.
    It's now Thursday afternoon, just got off the phone with him, the block is still at the engineering. Eish!
  10. #170
    Boksburg
    Has he found your 300 injectors
    Kb300 Dtec 4x4 ...let the mods begin
    2003 Kb300Tdi d/c lx 4x4 - sold
    GP0274 batmandiver
  11. #171
    Vredenburg
    Thanked: 28
    Quote Originally Posted by batman diver View Post
    And the pump?
    Marius Swart
    (Blackie)
    2010 Land Rover Freelander 2 Td4 SE
    1997 Opel Corsa Bakkie 1.3i
  12. #172
    May 2013
    I got a feeling he'd already sold my injectors & pump! He says he's going to look for mine!
    I very much doubt he'll come up with it. I'm trying to get him to pay for the new tips, my diesel shop is prepared to change them for me without charging labor.
    Currently, he has the pump, so I can't take it in to be checked.
  13. #173
    Boksburg
    What pump does he have .... 300 or 280
    GP0274 batmandiver
  14. #174
    May 2013
    He's giving me someone else's 280 pump.
  15. #175
    Thanked: 974
    Quote Originally Posted by Bunchat View Post
    And next week that oke's ginna be here complaining about parts missing on his van. This guy needs to be stopped!!!
    Stay Safe
    Disco-Deon
  16. #176
    Jan 2009
    Germiston
    Thanked: 93
    Yip...nes Deon se
    __________________
  17. #177
    Jul 2010
    Pinetown
    Thanked: 1144
    Thiswhole story sounds like the type of "help" we were getting on the road last year before the Forum stepped in and sorted out our problems
    These type of "mechanics" should be black listed so that no one else get's burnt.
    ISUZU KB 280 DT LE NOW POWERED BY THIS AMAZING COMMUNITY
    Platkar = Chevy Spark 1.2
  18. #178
    Dec 2012
    lusaka
    Quote Originally Posted by Peter1949 View Post
    +1
  19. #179
    Langs die rivier, op n berg
    Thanked: 2437
    This sounds too bad to be true. Joh!
    Marius, ek dink jy moet af trek kaap toe. Dan maak ons n indy shop oop. Jy doen veedub en ford/mazda, ek sal nissan doen. Dan kort ons netnog n zuus man. No need for toy, hulle breek nooit, so ons salnie besigheid uit hulle kry elkgeval.
  20. #180
    Thanked: 2295
  1. Advantage of a Diesel vehicle?
    By Krimpie in forum Mitsubishi
    Last Post: 2014/12/26, 12:05 PM
  2. Inloop tydperk/Run in period
    By Bogaards in forum Volkswagen
    Last Post: 2011/11/11, 08:11 PM
  3. Safari Safari engine rebuild to 3.1L Stroker
    By '83 Safari in forum Nissan
    Last Post: 2010/11/24, 06:38 PM
  4. 2-stroke/4-stroke Hybrid Engine
    By SimonB in forum General 4x4 Discussion
    Last Post: 2008/03/26, 12:51 PM
  5. Imported engine VS Rebuild
    By Rocky in forum Vehicle & Technical Chat - General
    Last Post: 2007/09/14, 03:52 PM
