Bolero Water Pump.
Results 1 to 2 of 2
    Jul 2013
    South Africa
    Default Bolero Water Pump.
    Gooday Peeps
    I just registered on this forum today and have seen a few great bits of info.I own a 2005 Bolero which has been using water for a few months. After buying a second hand pump from the Fochville guys ( Scrapyard) about 4 months ago the pump only lasted 3 months. So i took my old pump to my local engineering firm and had it refurbished. Sadly it started leaking again today.I have found a few supplier that have new pumps for around R1450.00.
    I however saw another post here where someone commented on the 2 small holes on the pump. Has anyone got some insight concerning these holes or is it best just to spend the R1450 and buy a new pump.
    Would just like to add i really love my Bolero which i use for work reason ( farming) so although its old ...........it is still great value for money as i bought it on an auction 2 years ago for R35000.00
    Any comments will help. I wouldnt mind buying a new pump if i have to but still believe i should have another go at this one.
    regards
    Robbie McColl
    Hi and welcome to the forum,
    I would rather spend the R1500 for a new pump than risk overheating the engine due to no water or pump failure. R1500 is not a bad price, especialy if it is original?
  1. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  2. Colt 2.8TD Water pump replacement
    By Callabria in forum Mitsubishi
    Last Post: 2013/06/22, 09:49 AM
  3. toyota 2005 d4d water pump
    By robinpretorius in forum Toyota
    Last Post: 2012/05/26, 09:19 AM
  4. 12v Water pump - help needed please
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2012/01/25, 08:03 AM
  5. Water pump
    By Epinephrine in forum Land Rover
    Last Post: 2010/09/30, 08:10 AM
