Crawler gear leader board.
Page 1 of 22 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 20 of 439
    Gordon's Bay
    Thanked: 4378
    Default Crawler gear leader board.
    SEE POST 3 FOR ACTUAL LEADERBOARD.
    This comes from these 2 threads:
    http://www.4x4community.co.za/forum/...34#post1717334 - where the Amarok guys got all excited when they discovered they had 2.72:1 low range
    and this thread: http://4x4community.co.za/forum/show...63#post1717163 where the hobbitses got all uptight because SA4x4 said they were underendowed in the Low Range department.
    A leader board was posted in the Amarok one, but it's short on info and incorrect.
    so - post 2 will be the actual info and post 3 will be the abbreviated leaderboard, which I will endeavor to keep updated.
    I think a STOCK board and a MODIFIED Board is in order. pretty self explanatory. perhaps we can make it a sticky, this info is hard to come by... and it is a VERY importantr measure of off road ability.
    what we need from you is the following:
    your vehicle, if standard state STOCK or list mods made, model, motor (inc CC, power at rpm, toruque at rpm) ,gearbox (manual/auto) , gearbox ratios (all) Transfer case , low range ratio, high range ratio, diff ratio, tyre size - actual size (e.g. 285/70R17) plus diameter in metres please. weight of vehicle (Tare and GVM)
    then you need to calculate your crawler ratio and crawler multiplier (see formula below) and give us the info in the following format:
    STOCK/MAKE/MODEL/ENGINE/GEARBOX/CRAWLER RATIO/CRAWLER MULTIPLIER/MAX TORQUE AT WHEEL (N.m)/MAX AVAILABLE FORCE AT WHEEL ([email protected]/h)/MAX FORCE per kg(GVM)/max force at wheel (Tare)
    calcs:
    Crawler Ratio: 1st gear ratio x low range ratio x diff ratio
    Crawler multiplier: Crawler ratio / Tyre radius (in metres)
    max torque at wheel : Crawler Ratio x max engine torque
    Max Available Force: Crawler multiplier x max torque = N
    Speed of max Force: engine rpm at max torque / Crawler ratio x tyre diameter in metres x pi x 0.06 = km/h
    max Force per kg (GVM) : Max force / GVM
    max force per kg (tare) : max force/Tare
    see post 4 as an example below... If you struggle with the calcs, just post the info you have and I'm sure someone will sort it out for you... If your vehicle is already listed, please check the info/calcs and comment if you want...
    EDIT - See attached spread sheet from Elliot - punch your numbers into the Blue section, and copy the result in the bottom right box into your post.
    PLEASE NOTE - you need to submit the details for the" full details post" as well as the summary from the spread sheet to get your details entered!
    Attached Files Attached Files
    Gordon's Bay
    Thanked: 4378
    FULL DETAILS OF VEHICLES:
    STOCK VEHICLES:
    FULL DETAILS - AUTOMATICS:
    Jeep Wrangler unlimited Rubicon V6 (Pentastar) 3.6 petrol / [email protected]/ [email protected] / auto 5 speed / 1st 3.59, 2nd 2.19, 3rd 1.41, 4th 1.00, 5th 0.83 / HiRange 1:1, Low range 4:1 , Diff ratios 4.1:1, 245/75R17 = .8m diameter / GVM 2540kg / Tare 1920kg
    Jeep Wrangler unlimited Sahara V6 (Pentastar) 3.6 petrol / [email protected]/ [email protected] / auto 5 speed / 1st 3.59, 2nd 2.19, 3rd 1.41, 4th 1.00, 5th 0.83 / HiRange 1:1, Low range 2.72:1 , Diff ratios 3.73:1, 245/75R17 = .8m diameter / GVM 2540kg / Tare 1920kg
    Suzuki Grand Vitara 2.4 petrol Auto / [email protected]/ [email protected] / Auto 4 speed / 1st 2.826, 2nd 1.493, 3rd 1.000, 4th 0.688 / HiRange 1:1, Low range 1.970:1 , Diff ratios 5.125:1, 225/65R17 = .724m diameter / GVM 2100kg / Tare 1620kg
    2009 Suzuki Grand Vitara 3.2l V6 / [email protected] / [email protected] / Auto 5 speed / 1st 3.52, 2nd 2.043, 3rd 1.401, 4th 1.00, 5th 0.717 / Final drive 3.583, Low range 1.97:1, Diff ratios 4.875:1, 235/65/r17 (29*9 R17") = 0.737m diameter / GVM 2170 kg / Tare 1713kg
    Jeep WJ Grand Cherokee Ltd V8 (Powertech) 4.7 petrol / [email protected]/ [email protected] / auto 5 speed / 1st 3.0, 2nd 1.67 (upshift)/1.5 (Kickdown), 3rd 1.0, 4th 0.75, 5th 0.67 / HiRange 1:1, Low range 2.72:1 , Diff ratios 3.73:1, 235/75R15 (29*9.5R15") = 0.734m diameter / GVM 2330kg / Tare 1876 kg
    Hummer / H3 Adventure / V8 5.3 petrol / [email protected] / [email protected] / Auto 4 speed / 1st 3.059, 2nd 1.625, 3rd 1.000, 4th 0.696/ HiRange 1:1 , lowrange 4.03:1 , diff ratios 4.1:1, 265/75R16 (0.803m) /GVM 2722/ Tara 2260kg
    Hummer / H3 Adventure / I5 3.7 petrol / [email protected] / [email protected] / Auto 4 speed / 1st 3.059, 2nd 1.625, 3rd 1.000, 4th 0.696/ HiRange 1:1 , lowrange 4.1:1 , diff ratios 4.56:1, 265/75R16 (0.803m) /GVM 2722/ Tara 2260kg
    Jeep Commander V8 Auto/ 5.7 petrol / [email protected] / [email protected] / Auto 5 speed / 1st 3.0, 2nd 1.67, 3rd 1.00, 4th 0.75 5th 0.67/ HiRange 1:1 , lowrange 2.7:1 , diff ratios 3.73:1, 245/75R17 (0.803m) /GVM 2900/ Tara 2370kg
    Land Rover Discovery 3 / Auto / 2005 2.7l 6cyl TDV6 /1st gear ratio - 5.08/Lowrange 2.93/Diff Ratio 3.73/Tyre Dia - 763mm (255/55/19)/Max Torq - 440 @ 1900/GVM 3180/Tare 2419
    Mercedes ML55 5.5 V8 petrol / [email protected]/ [email protected] / auto 5 speed / 1st 3.595, HiRange 1:1, Low range 2.7:1 , Diff ratios 3.46:1, 285/50R18 = 0.742m diameter / GVM 2750kg / Tare 2080kg
    1996 Toyota Land Cruiser 80 4.5 Petrol. /158kW @ 4600 rpm/ 373Nm @ 3600 rpm/ 4spd Auto/ 1st 2.95:1/ Low range 2.488:1/ Diff ratio 4.11/ 265-75-16 tyres .8m/ GVM 2960 kg/ Tare 2100kg
    2006 Toyota Prado 120 4.0 V6 Auto / [email protected]/ [email protected] / Auot 5 speed / 1st 3.520, 2nd 2.042, 3rd 1.400, 4th 1, 5th 0.716 / HiRange 1:1, Low range 2.566:1 , Diff ratios 3.721:1, 265x65R17 0.776m diameter / GVM 2850kg / Tare 1910kg
    Land Rover Discovery 4 V8HSE 255/55 R19 tyres 5.0 petrol / [email protected] / [email protected] / Auto 6 speed / 1st 4.171, 2nd 2.34, 3rd 1.52, 4th 1.14, 5th 0.86, 6th 0.69, R 3.40 / HiRange 1:1, Low range 2.93:1 , Diff ratios 3.54:1, 255/55 R19" = .763m diameter / GVM 3240kg Tare 2548kg
    Land Rover Discovery 4 TDV6S 255/55 R19 tyres 3.0 Diesel / [email protected] / [email protected] / Auto 6 speed / 1st 4.171, 2nd 2.34, 3rd 1.52, 4th 1.14, 5th 0.86, 6th 0.69, R 3.40 / HiRange 1:1, Low range 2.93:1 , Diff ratios 3.54:1, 255/55 R19" = .763m diameter / GVM 3240kg Tare 2583kg
    VW Amarok 2.0 Diesel / 420N.m. @ 1750 RPM / auto 8 spd / 1st 4.714 / Transfer case (no low range) 1.0 / diff ratio 3.7 / wheel dia 750.3 mm / GVM 2820 kg / Tare 1975 kg
    Toyota Hilux 3.0 D4D / [email protected]/ [email protected] / auto 4 speed / 1st 2.804, 2nd 1.531, 3rd 1, 4th 0.705/ HiRange 1:1, Low range 2.566:1 , Diff ratios 3.583:1, 265/65R16 = .751m diameter / GVM 2770kg / Tare 1840kg
    Nissan Navara DC 2006 / 4L V6 Petrol / [email protected]/ [email protected] / Auto 5 speed / 1st 3.842, 2nd 2.13, 3rd 1.30, 4th 1.00, 5th 0.77 / HiRange 1:1, Low range 2.625:1 , Diff ratios 3.357:1, 265/65R17 = .7763m diameter / GVM 2805kg / Tare 1923kg
    Toyota Prado 90 VX 3.4 V6 petrol / [email protected]/ [email protected] / auto 4 speed / 1st 2.804, 2nd 1.531, 3rd 1, 4th 0.753,/ HiRange 1:1, Low range 2.566:1 , Diff ratios 4.3:1, 265/70R16 = .778m diameter / GVM 2710kg / Tare 1720kg
    2008 Hummer / H2 / V8 6.2 petrol / 293kW @ 5700rpm / 563NM @ 4300rpm/ Auto 6 speed 6L80E/ 1st 4.027, 2nd 2.364, 3rd 1.532, 4th 1.152, 5th 0.852, 6th 0.667 / HiRange 1:1 , lowrange 2.64:1 , diff ratios 4.1:1, 315/70R17 (0.889m)/ GVM 3900 / Tara 2902kg
    2006 Hummer H1 Alpha V8 BiTurbo 6.6 l Diesel with Allison 6 speed Auto [email protected] / 820Nm @1600rpm / 1st:3.1 2nd 1.81 3rd 1.14 4th 1 5th .71 6th .61 / High 1:1 Low 2.72:1 / Diff 2.56 / Reduction Hubs 1.92:1 / Tyre 37x12.5R17 940mm / open top 7847lbs Tare : wagon 8114lb Tare / Open top 10300lb GVM/Wagon 10300GVM
    2013 Ford / Ranger / 5cyl 3.2 Diesel / 147kW @ 3000rpm / 470NM @ 1500rpm/ Auto 6 speed / 1st 4.171, 2nd 2.312, 3rd 1.521, 4th 1.143, 5th 0.867, 6th 0.691 / HiRange 1:1 , LowRange 2.48:1 , diff ratios 3.73:1, 265/65R17 (0.765m)/ GVM 3200 / Tara 2118kg
    2010 Jeep / Wrangler Sahara / V6 3.8 petrol / [email protected]/ [email protected] / auto 4 speed / 1st 2.84, 2nd 1.57, 3rd 1.0, 4th 0.69,/ HiRange 1:1, Low range 2.72:1 , Diff ratios 3.73:1, 245/75R17 = 750.3m diameter / GVM 2286kg / Tare 1821kg
    2012 Jeep / Grand Cherokee WK2 Overland / V8 5.7 petrol / [email protected]/ [email protected] / auto 6 speed / 1st 3, 2nd 1.67, 3rd 1.50, 4th 1, 5th 5 ,6th 0.67 / HiRange 1:1, Low range 2.72:1 , Diff ratios 3.45:1, 285/65R18 = 827.7m diameter / GVM 3084kg / Tare 2388kg
    2009 Jeep WK Grand Cherokee /3.0 V6 Diesel / 168 [email protected] / 610Nm @1600 /Auto 5 Speed / 1st 3.59, 2nd 2.186, 3rd 1.405, 4th 1 , 5th 0.831, R 3.167 / Hi Range 3.73 / Low Range 2.92 / Dif Ratio 3.73 / 265/65 R17 = 776.3 m diameter /GVM 1886 Kg TARE 2142 Kg.
    __________________
    FULL DETAILS - MANUALS
    Suzuki Jimny 1.3 petrol / [email protected]/ [email protected] / manual 5 speed / 1st 4.425, 2nd 2.304, 3rd 1.674, 4th 1.190, 5th 1.000 / HiRange 1:1, Low range 2.002:1 , Diff ratios 4.3:1, 205/70R15 = .668m diameter / GVM 1420kg / Tare 1050kg
    2001 Mitsubishi Colt 2.4 (4G64) Trailbuster (S/C) 2.4 petrol / [email protected]/ [email protected] / Manual 5 speed / 1st 3.967, 2nd 2.136, 3rd 1.36, 4th 1.00, 5th 0.856 / HiRange 1:1, Low range 1.925:1, Diff ratios 4.875:1, 245/75/r15 (30*9.5R15") = 0.762m diameter / GVM 2830kg / Tare 1630kg
    Suzuki Grand Vitara 2.4 petrol Manual / [email protected]/ [email protected] / Manual 5 speed / 1st 4.425, 2nd 2.304, 3rd 1.674, 4th 1.190, 5th 1.000 / HiRange 1:1, Low range 1.970:1 , Diff ratios 3.727:1, 225/65R17 = .724m diameter / GVM 2100kg / Tare 1605kg
    Suzuki SJ410 970cc petrol / [email protected]/ [email protected] / manual 4 speed / 1st 3.140, 2nd 1.947, 3rd 1.423, 4th 1.000/ Hi range 1.58:1, Low range 2.51:1 , Diff ratios 4.11:1, 215/75R15 = .684m diameter / GVM 1250kg / Tare 815kg
    Unimog 404 2.2 petrol/[email protected]/ [email protected]/ 6 speed manual 1st. 14.93 2nd. 8.23 3rd. 4.47 4th. 2.47 5th. 1.53 6th. 1.00/ no low range/ diff ratio 7.56/ 12.50x20 tyres= 1.016m diameter/ GWM 4400kg/ Tare 2850kg.
    Hummer / H3 Adventure / I5 3.7 petrol / [email protected] / [email protected] / Manual 5 speed / 1st 3.753 , 2nd 2.260 , 3rd 1.370 , 4th 1.000 , 5th 0.729/ HiRange 1:1, lowrange 4.1:1 , diff ratios 4.56:1, 265/75R16 /GVM 2722/ Tara 2260kg
    Land Rover Series III 109 SW / 2.25 Petrol / [email protected] / [email protected] / manual 4 speed / 1st 3.68, 2nd 2.22, 3rd 1.50, 4th 1.00, / HiRange 1.15:1, Low range 2.35:1 , Diff ratios 4.7:1, 235/85/16 = .7m diameter / GVM 2710kg / Tare 1679kg
    Toyota Hilux SFA 2.2 petrol / [email protected]/ [email protected] / manual 5 speed / 1st 3.954, 2nd 2.141, 3rd 1.384, 4th 1.00, 5th 0.85 / HiRange 1:1, Low range 2.2:1 , Diff ratios 4.88:1, 245/75R15 = .7785m diameter / GVM 2880kg / Tare 1440kg
    2006 Toyota Hilux 3.0 D4D / [email protected]/ [email protected] / manual 5 speed / 1st 4.313, 2nd 2.336, 3rd 1.436, 4th 1, 5th 0.838 / HiRange 1:1, Low range 2.566:1 , Diff ratios 3.583:1, 255/70R15 = .738m diameter / GVM 2770kg / Tare 1840kg
    STOCK - Land Rover Defender Kalahari 2006 / i4 (300TDi) 2.5 diesel / [email protected]/ [email protected] / manual 5 speed / 1st 3.692, 2nd 2.132, 3rd 1.397, 4th 1.00, 5th 0.77 / HiRange 1.41:1, Low range 3.32:1 , Diff ratios 3.54:1, 235/85R16 = .8059m diameter / GVM 2950kg / Tare 2020kg
    Land Rover Discovery V8i 2" lift and 32" tyres 4.0 petrol / [email protected] / [email protected] / manual 5 speed / 1st 3.32, 2nd 2.13, 3rd 1.39, 4th 1.1, 5th 0.73 / HiRange 1:1, Low range 3.32:1 , Diff ratios 3.54:1, 0.820m diameter / GVM 2720kg Tare 1980kg
    Mitsubishi Triton 2006/2007 / 3.2l Diesel / [email protected]/ [email protected] / Manual 5 speed / 1st 4.313, 2nd 2.33, 3rd 1.436, 4th 1.00, 5th 0.789 / HiRange 1:1, Low range 1.9:1 , Diff ratios 3.917:1, 245/70R16 = .7494m diameter / GVM 2930kg / Tare 1905kg
    2013 VW Amarok 2.0 BiTDi DC Highline/ [email protected]/ 400 @ 1500-2250rpm / manual 6 speed / 1st 4.81, 2nd 2.54, 3rd 1.50, 4th 1, 5th 0.76, 6th 0.64 /
    HiRange 1:1, Low range 2.72:1 , Diff ratios 4.1:1, 265/65R17 = .776m diameter / GVM 2820kg / Tare 1951kg
    2013 Amarok: [email protected], [email protected], 1st 4.81 2nd 2.54 3rd 1.50 4th 1 5th 0.76 6th 0.64, Hi 1:1 Low 2.72, GVM 2820, Tare 1931
    Mitsubishi Pajero 1999 / 3.5l Petrol / [email protected]/ [email protected] / Manual 5 speed / 1st 3.952, 2nd 2.238, 3rd 1.398, 4th 1.000, 5th 0.819 / HiRange 1:1, Low range 1.9:1 , Diff ratios 4.636:1, 31*10.5/15 = .787m diameter / GVM 2550kg / Tare 2035kg
    Kia Sportage 2002 Petrol Manual : (2.0 DOHC “Mazda engine”) / [email protected] / [email protected] / Manual 5 speed / 1st 3.717, 2nd 2.019, 3rd 1.363, 4th 1.000, 5th 0,804 / HiRange 1:1, Low Range 1.981 :1 ,Diff Final Gear ratios 4.778:1, Tyres 205/70 R15 = .668m diameter / GVM 1928kg / Tare 1440kg
    Isuzu KB300 D-Teq: [email protected], [email protected], 1st 4.326 2nd 2.557 3rd 1.490 4th 1.000 5th 0.795, Hi 1:1 Low 2.482, GVM 2900, Tare 2000
    Stock Steyr Puch Haflinger - unknown year model - 19.9Kw @ 4800 rpm - 44.13 Nm @ 3500 rpm - Manual 5 SPD - 1st 6.83 / 2nd 3.73 / 3rd 1.84 / 4th 1.12 / 5th 0.71 - no low range but axle reduction = 2.21 - Diff 9.327 - Tyres 3.5x12" = 482.6 mm - GVM 1250 kg - Tare 635 kg
    MODIFIED VEHICLES AUTO:
    APOCALYPSE: Jeep Wrangler unlimited Rubicon V6 (Pentastar) 3" lift and 35" tyres 3.6 petrol / [email protected]/ [email protected] / auto 5 speed / 1st 3.59, 2nd 2.19, 3rd 1.41, 4th 1.00, 5th 0.83 / HiRange 1:1, Low range 4:1 , Diff ratios 4.1:1, 35*12.5R17" = .889m diameter / GVM 2540kg / Tare 1920kg
    THYSLEROUX: Jeep Grand Cherokee Ltd V8 (Powertech) 2" lift and 30.6" tyres 4.7 petrol / [email protected]/ [email protected] / auto 5 speed / 1st 3.0, 2nd 1.67 (upshift)/1.5 (Kickdown), 3rd 1.0, 4th 0.75, 5th 0.67 / HiRange 1:1, Low range 2.72:1 , Diff ratios 3.73:1, 265/70R16" = .7774m diameter / GVM 2330kg / Tare 1876 kg
    GASHOG: Jeep TJ Wrangler I6 4.0 Petrol, 2.5" lift, 31" tyres / [email protected] / [email protected] / Auto / 1st 2.84, 2nd 1.57, 3rd 1.00, 4th 0.69, Rev 2.21 / HiRange 1:1, Low range 2.72:1, Diff ratios 4.88:1, 31*10.5R15" = .787 diameter / GVM 1975kg Tare 1456kg
    MOPAR: 1978 Jeep SJ, 8.2lit V8, TF727 autobox, 2.45,1.45.1.1, 450kW at 5800, 900Nm at 4200, doubler transfercases 4:1, 4.88:1 diff ratio, 40"tyres 1,016m, Tare 2200kg, Gwm 3500Kg
    MOPAR: jeep Tj , 2003, 4.0 lit, auto 2.84:1, 142Kw at 4600, 319Nm at 3200, Dana 300 with 4:1 gears plus rubicrawler wit 2.72:1 gears for total 10.88:1, 4.56 diffratios, 37"tyres 0.940m, tare 1600, Gwm 1975.
    MOPAR: Willys MB, 1947, 4.3 lit chevy V6, Turbo 350 autobox with 2.52 first gear, 300kW at 6000, 600Nm at 4500, T case Dana 300 2.62:1 plus A Klune V with 4:1 gearing for combined 10.48:1 gearing, 4.88 diff ratio, 35" tyres .890m, tare 1350, Gwm 1600
    ZOMBICON - Jeep / Wrangler Sahara / V6 3.8 petrol / [email protected]/ [email protected] / auto 4 speed / 1st 2.84, 2nd 1.57, 3rd 1.0, 4th 0.69,/ HiRange 1:1, Low range 2.72:1 , Diff ratios 5.13:1, 37x12.5xR17 = 940m diameter / GVM 2286kg / Tare 1821kg
    MODIFIED VEHICLES MANUAL:
    GREENDISCO: Jeep Wrangler TJ I6 5" lift and 35" tyres 4.0 petrol / [email protected] / [email protected] / manual 6 speed / 1st 4.46, 2nd 2.61, 3rd 1.72, 4th 1.25, 5th 1.00, 6th 0.84, R 4.06 / HiRange 1:1, Low range 2.72:1 , Diff ratios 4.56:1, 35*12.5R15" = .889m diameter / GVM 1359kg
    Andre' : UniMog 404 with factory option motor and crawler gears: 2.8 petrol/ [email protected]/ [email protected]/ Crawl 1st. 46.01:1 / crawl 2nd. 25.34:1 /1st. 14.93 2nd. 8.23 3rd. 4.47 4th. 2.47 5th. 1.53 6th. 1.00/ no low range/ diff ratio 7.56/ 12.50x20 tyres= 1.016m diameter/ GWM 4400kg/ Tare 2850kg.
    COENRAADB: Toyota Hilux 3.0 D4D / [email protected]/ [email protected] / manual 5 speed / 1st 4.313, 2nd 2.336, 3rd 1.436, 4th 1, 5th 0.838 / HiRange 1:1, Low range 2.566:1 , Diff ratios 3.583:1, 31x10.5R15 0.813m diameter / GVM 2770kg / Tare 1840kg
    GRIPS: Ford Ranger Modified 347 v8 8 speed manual when using splitter normal ratios for calculations / [email protected]/ [email protected] / Manual 8 speed / 1st 6.68, 1st od 4.88 2nd 3.34, 2nd od 2.44, 3rd1.74 , 3rd od 1.27 4th 1.00, 4h od 0.73 / HiRange 1:1, Low range 1.96 , Diff ratios 4.1:1, 35 x 12.5 = .889m diameter / GVM 2613kg / Tare 1960
    SAKKIE : Isuzu Frontier 1st 5.016 (MSB-5S Isuzu Gearbox)LR 3.07 (Terra Low 307 into the T/Case)Diff 4.55 (standard) Engine rpm to Final Drive ratio 70.066 : 1 Means at 500rpm (where mine's idling is set), running 31" tyres, she crawls 1.059 km/h.
    Gordon's Bay
    Thanked: 4378
    SUMMARY AND LEADER BOARD:
    Vehicles are sorted by diesel/petrol, manual/auto, stock/ modifed and are ranked in their categories by the total reduction available on the vehicle.
    Figures are:
    see post 1 for explanation of figures.
    VEHICLE / CRAWLER RATIO/ CRAWLER MULTIPLIER / Max Torque at wheel /max Force (at speed)/Force per kg (GVM) / Force per kg (Tare)
    STOCK VEHICLES PETROL AUTO:
    Jeep Wrangler Unlimited Rubicon 3.6 Petrol Auto / 58.876:1 / 147.19 / 20430 N.m / 51075 N @10.6km/h / 20.1 N/kg/ 26.6N/kg
    Hummer / H3 Adventure / Auto / 57.191:1 / 142.978 / 18759 N.m / 46897 N @ 12.13 km/h / 17.2 N/kg / 20.75 N/kg
    Hummer H3 adventure V8 auto / 50.54:1 / 125.9 / 21934N.m / [email protected]/h / 20.07 N/kg / 24.18N/kg
    Hummer H2 V8 auto / 43.6:1 / 98.1 / 24540.2N.m / 55208.5N @ 16.5kph/ 14.2 N/kg / 19 N/kg TARE
    Land Rover Discovery 4 Automatic 2012 5l 8cyl Petrol- 43.3/113.4/22491.1 Nm/58954.3N @ 11.6kph/18.2N/kg GVM/23.1N/kg TARE to be checked/confirmed - same ratio as diesel doesn't seem right
    2012 Jeep Wrangler Unlimited Sahara JK 3.6 Petrol Auto / 36.42:1 / 91.05 / 12638 N.m / 31595 N @17.8km/h / 12.4 N/kg/ 16.46 N/kg
    2012 Jeep Grand Cherokee WK2 Auto 5.7l 8cyl Petrol- 33.7/81.5/17518.1 Nm/42365.3N @ 19.7kph/13.7N/kg GVM/17.7N/kg TARE
    2004 Mercedes Benz ML55 Auto 5.5l 8cyl Petrol- 33.6/90.5/17128.1 Nm/46154.9N @ 22.5kph/16.8N/kg GVM/22.2N/kg TARE
    Toyota Prado 120 Auto 2006 4l v6cyl Petrol- 33.6/86.6/12637.1 Nm/32569.8N @ 16.9kph/11.4N/kg GVM/17.1N/kg TARE
    Toyota Prado 90 VX 3.4 V6 petrol- 30.938/39.767/9374.5 Nm/37 279.4N @ 17.7kph/13.8N/kg GVM/21.7N/kg TARE
    Jeep Grand Cherokee Auto 1999/2004 WJ 4.7l 8cyl Petrol- 30.4/82.9/12113.8 Nm/33007.8N @ 14.6kph/14.2N/kg GVM/17.6N/kg TARE
    Jeep Commander Auto 5.7l V8 Petrol / 30.4:1/75.8/15218.4 Nm/37903.9N @ 19.9kph/13.1N/kg GVM/16N/kg TARE
    1996 Toyota Land Cruiser/Auto/ 4.5l 6cyl Petrol- 30.2/75/11251.8 Nm/27989.6N @ 18.1kph/9.5N/kg GVM/13.3N/kg TARE
    2010 Jeep JK Wrangler Unlimited Auto 3.8l 6cyl Petrol- 28.8/76.8/9364.4 Nm/24961.7N @ 19.6kph/10.9N/kg GVM/13.8N/kg TARE
    Johan Stock Land Rover Range Rover Auto 2000 4.6l 8cyl Petrol- 28.7/108.9/10784.9 Nm/40903.8N @ 10.4kph/18.8N/kg GVM/14.7N/kg TARE
    Suzuki Grand Vitara 2.4 Auto / 28.53:1 / 78.82 / 6420 Nm / 17734 N @ 19.61 kph / 8.44 N/kg
    Suzuki Grand Vitara 3.2l V6 Auto 24.84:1 / 68.446 / 7056.25 N.m / 19438.7N @ 9.638 km/h / 8.957N/kg / 11.34 N/kg
    STOCK VEHICLES DIESEL AUTO
    2008 Land Rover Discovery tdv6 Auto 2,7l 6cyl diesel- 45,6/119,5/20052,3 Nm/52561,8N @ 6kph/16,2N/kg GVM/20,3N/kg TARE
    2012 Land Rover Discovery 4 Automatic 3l 6cyl Diesel- 43.3/113.4/25951.2 Nm/68024.2N @ 6.7kph/21N/kg GVM/26.3N/kg TARE
    2006 Hummer H1 ALPHA Auto 8 cyl - 41.4/88.2/33984.9 Nm/72308.2N @ 6.8kph/15.6N/kg GVM/23.4N/kg TARE
    2013 Ford Ranger T6 Auto 3.2l 5cyl Diesel- 38.6/100.9/18134.2 Nm/47409.7N @ 5.6kph/14.8N/kg GVM/22.4N/kg TARE
    2006 Nissan Navara Auto 4l 6cyl Petrol- 33.9/87.2/13813.3 Nm/35587.6N @ 17.1kph/12.7N/kg GVM/18.5N/kg TARE
    2009 Jeep Grand Cherokee Auto 3l 6cyl Diesel- 28.5/73.5/17393.1 Nm/44810.2N @ 8.2kph/23.8N/kg GVM/20.9N/kg TARE
    2009 Toyota Hilux D4D Auto 3l 4cyl Diesel- 25.8/68.7/8842.5 Nm/23551.8N @ 17.6kph/8.5N/kg GVM/12.8N/kg TARE
    2013 VW Amarok Automatic 2l 4cyl Diesel- 17.4/46.5/7325.6 Nm/19527N @ 14.2kph/6.9N/kg GVM/9.9N/kg TARE
    STOCK VEHICLES PETROL MANUAL
    Steyr Puch Haflinger Manual 0.643l 2cyl Petrol- 140.8/583.4/6212.8 Nm/25747.3N @ 2.3kph/20.9N/kg GVM/40.5N/kg TARE
    Unimog404 2.2petrol 6speed manual /112.87:1/222.18/16140Nm/[email protected]/h/7.22N/kg/11.14N/kg
    Hummer / H3 Adventure / I5 3.7 petrol / Manual / 70.166:1 / 175.415 / 23014 N.m / 57536 N @ 9.89 km/h / 21.1 N/kg / 25.45 N/kg
    Johan Stock Land Rover Defender Manual 1994 3.9l 8cyl Petrol- 46.8/185.2/14284.6 Nm/56485.6N @ 5.3kph/32.4N/kg GVM/23.5N/kg TARE
    1990 Toyota Hilux SFA Manual 2.2l 4cyl Petrol- 42.5/109.1/9763.5 Nm/25082.9N @ 8.1kph/8.7N/kg GVM/17.4N/kg TARE
    1977 Land Rover Series III 109 SW 2.25 Petrol / 40.646:1 / 116.13 / 6503.36 Nm / 18576N @ 6.5km/h / 6.855 N/kg GVM / 11.06 N/kg Tare
    Land Rover Discovery 1 Manual 1998 3.9l 8cyl Petrol- 39/106.2/13266.6 Nm/36099.5N @ 9.2kph/13.3N/kg GVM/18.2N/kg TARE
    Suzuki Jimny 1.3 Petrol manual / 38.1/114.1/ 4191 N.m/ 12551N @ 13.54km/h / 8.83N/kg
    Mitsubishi Colt Trailbuster (S/C) 2.4 petrol Manual / 37.228:1 / 97.711 / 8116 N.m / 21301 N @ 15.43 km/h / 7.5 N/kg / 13.06N/kg
    1999 Mitsubishi Pajero Manual 3.5l 6cyl Petrol- 34.8/88.5/10443.2 Nm/26539.4N @ 12.8kph/10.4N/kg GVM/13N/kg TARE
    Grand Vitara 2.4 Manual / 32.49:1 / 89.75 / 7310 Nm / 20194 N @ 17.22 kph / 9.62 N/kg
    Suzuki SJ410 970cc Petrol Manual/32.39:1/94.71/2365 N.m/6914N @ 11.94km/h /5.5N/kg /8.5N/kg
    STOCK VEHICLES DIESEL MANUAL
    2013 VW Amarok BiTDi DC Highline Manual 2l 4cyl Diesel- 53.6/138.2/21456.4 Nm/55278.8N @ 4.1kph/19.6N/kg GVM/28.3N/kg TARE
    2013 VW Amarok Manual 103kW 2l 4cyl Diesel- 53.6/143.2/18238 Nm/48673.6N @ 4.2kph/17.3N/kg GVM/25.2N/kg TARE
    2006 Land Rover Defender 300TDi Kalahari Manual 2,5l 4cyl Diesel- 43,4/107,7/11458,8 Nm/28437,2N @ 6,3kph/9,6N/kg GVM/14,1N/kg TARE
    2012 Isuzu KB 300 Manual 3l 4cyl Diesel- 40/106.8/14406.2 Nm/38447.4N @ 6.4kph/13.3N/kg GVM/19.2N/kg TARE
    2006 Toyota Hilux 3.0D4D Manual 3l 4cyl Diesel- 39.7/107.5/13363.3 Nm/36214.8N @ 11.2kph/13.1N/kg GVM/19.7N/kg TARE
    2006 Mitsubishi Triton manual 3.2l 4cyl Diesel- 32.1/85.7/11138.2 Nm/29725.7N @ 8.8kph/10.1N/kg GVM/15.6N/kg TARE
    MODIFIED VEHICLES PETROL AUTO:
    MOPAR Jeep Wrangler Tj auto 2003 4l 6cyl Petrol- 140.9/299.8/44947.2 Nm/95632.4N @ 4kph/48.4N/kg GVM/59.8N/kg TARE
    MOPAR Jeep Willys MB auto 1947 4.3litl 6cyl Petrol- 128.9/289.6/77327.3 Nm/173769.2N @ 5.9kph/128.7N/kg GVM/108.6N/kg TARE
    MOPAR Jeep SJ (Wagoneer) auto 1978 8.2l 8cyl Petrol- 47.8/94.1/43041.6 Nm/84727.6N @ 16.8kph/24.2N/kg GVM/38.5N/kg TARE
    Apocalypse - Jeep Wrangler JK Unlimited Rubicon 3.6 Petrol Auto 35s / 58.876:1 / 132.45 / 20430 N.m / 45962 N @11.8 km/h/18.1N/kg / 23.93N/kg
    Zombicon- - Jeep JK Zombi Auto 2010 3.8l 6cyl Petrol 37s and ratios- 39.6/84.3/14266.2 Nm/30353.5N @17.9kph/13.3N/kg GVM/16.8N/kg TARE
    GasHog Jeep Wrangler TJ (31" muds - 4.88 diffs - 2.5" lift) Auto 2006 4l 6cyl Petrol - 37.7/95.8/12025.4 Nm/[email protected]/15.5N/kg GVM/21N/kg TARE
    ThysleRoux: Jeep Grand Cherokee Ltd V8 (Powertech) 2" lift / 30.437:1 / 78.304 / 12114 N.m / 31165 N @ 15.41 km/h / 13.4 N/kg 16.61N/kg
    Samaya: Suzuki Grand Vitara 3.2l V6 2" lift / 24.84:1 / 68.446 / 7056.25 N.m / 19438.7N @ 9.638 km/h / 8.957N/kg / 11.34 N/kg
    MODIFIED VEHICLES PETROL MANUAL:
    Andre' Unimog 404 2.8petrol (factory option motor and crawler) 6speed manual/347.84:1/684.7/77568Nm/152 688 [email protected]/h/34.7N/kg/53.57N/kg
    GREENDISCO: Jeep Wrangler TJ, 4.0l I6, Manual 6 speed / 55.318:1 / 124.45 / 17646 N.m / 39699.64 N @9.69 km/h / 29.21N/kg
    GRIPS Ford Ranger 347 v8 8 speed Manual / 53.680 / 149.92 / 28978.2 N.m / 80956.8 N @ 9.37 km/h / 30.98 N/kg GVM/ 41.30 N/kg Tare
    OWEND: Mitsubishi Colt Trailbuster (S/C) 3.5" lift and 31" tyres 2.4 petrol Manual / 37.228:1 / 94.606 / 8116 N.m / 20624 N @ 16 km/h / 7.3 N/kg 12.7N/kg
    MODIFIED VEHICLES DIESEL MANUAL
    Sakkie: Isuzu Frontier Manual 1999 2.8l 4cyl Diesel- 70.1/178/15764.8 Nm/40042.8N @ 4.5kph/17.4N/kg GVM/22.2N/kg TARE
    CoenraadB Toyota Hilux 3.0D4D Manual 2006 3l 4cyl Diesel- 39.7/97.6/13363.3 Nm/32882.1N @ 12.4kph/11.9N/kg GVM/17.9N/kg TARE
    Gordon's Bay
    Thanked: 4378
    Example of info needed:
    FULL DETAILS:
    STOCK - Jeep / Wrangler unlimited Rubicon / V6 (Pentastar) 3.6 petrol / [email protected]/ [email protected] / auto 5 speed / 1st 3.59, 2nd 2.19, 3rd 1.41, 4th 1.00, 5th 0.83 / HiRange 1:1, Low range 4:1 , Diff ratios 4.1:1, 245/75R17 = .8m diameter / GVM 2540kg / Tare 1920kg
    SUMMARY:
    STOCK:
    Jeep Wrangler Unlimited Rubicon 3.6 Petrol Auto / 58.876:1 / 147.19 / 20430 N.m / 51075 N @11km/h
    Gordon's Bay
    Thanked: 4378
    Current Leaderboard, but we need more details to make it meaningful..
    Jeep Sahara 3.8 manual is wrong below - should be 47.07 Crawler ratio...
    Quote Originally Posted by superduper View Post
    From this thread: http://www.4x4community.co.za/forum/...d.php?t=120177
    CRAWLER GEAR LEADERBOARD
    Jeep Rubicon 73
    LR Puma 62.987
    Toyota LC80 Auto 54.298
    VW Amarok 53.75
    Mahindra MM540 47.7
    JerrydeLange (Benz GL? it's a small photo...) 47.48
    LR Disco3 45.58
    LR Disco Diesel Auto 43.25
    Toyota Hilux SFA 42.40665
    Toyota LC80 Manual 41.731
    Mahindra Thar 41
    Toyota Hilux D4-D Manual 39.65
    Suzuki Jimny VVT Manual 38.09
    Mitsubishi Triton 32
    Jeep Sahara 28.81
    VW Amarok 8sp (No Low) 20.7
    Subaru Forester X 17
    Yes, the list needs work. Some did not say if their car was diesel or petrol or manual or auto.
    Gordon's Bay
    Thanked: 4378
    The Calculations I've put in are designed to give some more meaningful info than just a ratio.
    the last one - force and speed - is probably the most meaningful measurement of rock crawling ability - and sand driving ability, wher you don't want really low speeds... It also gives a realistic comparison of something with huge torque - big diesels - against the high revving but low torque petrol motors.
    as you can see - the Jimny can suddenly look very good against a Wrangler Sahara when speed and tyre size are considered... One must also bear in mind that an auto box has it's own multiplier in terms of the torque convertor, which we are not taking into account as you can never get that info...
    Gordon's Bay
    Thanked: 4378
    FULL DETAILS:
    STOCK - Jeep / Wrangler unlimited Sahara / V6 (Pentastar) 3.6 petrol / [email protected]/ [email protected] / auto 5 speed / 1st 3.59, 2nd 2.19, 3rd 1.41, 4th 1.00, 5th 0.83 / HiRange 1:1, Low range 2.72:1 , Diff ratios 3.73:1, 245/75R17 = .8m diameter / GVM 2540kg / Tare 1920kg
    SUMMARY:
    STOCK:
    Jeep Wrangler Unlimited Sahara 3.6 Petrol Auto / 36.42:1 / 91.05 / 12638 N.m / 31595 N @17.8km/h
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by ByronH View Post
    Thanks SaxJ,
    Correct and SA4x4 confirms that, here are the drive ratio's for the GV.
    Transmission
    Shift type Manual
    First gear 4.545
    Second gear 2.354
    Third gear 1.693
    Fourth gear 1.241
    Fifth gear 1.000
    Final drive 3.727
    Reverse 4.431
    Low range 1.970
    stolen from the Suzi thread...
    this gives a crawler ratio of 33.37:1 - which doesn't seem that great on the face of it for a manual - BUT as the GV has small wheels - not sure of the size - it will pick it's score up compared to bigger vehciles with a shorter diff ratio and bigger tyres.
    Thanked: 228
    Ok I will post some of the details here so long
    Stock LC 80 4.5 Petrol. /158kW @ 4600 rpm/ 373Nm @ 3600 rpm/ 4spd Auto/ 1st 2:95:1/ Low range 2.488:1/ Diff ratio 4.11/ 265-75-16 tyres .8m/ GVM 2960 kg/ Tare 2100kg
    Crawler ratio = 30.165756
    Crawler multiplier = 37.51959701
    Max torque at wheel = 11251.8NM
    Max Force = 13994.8NM
    Speed of Max force = 17.98 km/h
    Max force/ kg = 4.73
    Jan 2007
    Thanked: 328
    Vic
    Gordon's Bay
    Thanked: 4378
    hey - you okes have to do the summaries too, I'll never get any work done
    but yes, quickly, 38.1:1 overall reduction doesn't look all that great, but when you factor tyre size to score 114 it looks a lot better.
    Please remember to state Stock or Modified...
    EDIT - okay, did it to get things rolling...
    andre` Guest
    Does my Unimog count? Crawlratio 347.84:1
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by andre` View Post
    wahahahah!!!
    I knew someone would have one of those!!!
    definitley will put it up there if you put in all the info - the additional box is a modification isn't it? We'll put the stock one up as well as the modified, so Please do!!!
    will be interesting to add a "Force at wheels / GVM kg " figure too - the ultimate measure of low range!!!
    Thanked: 228
    Isn't there like a multiplier of 1.8 for the torque converter on an auto box to factor in as well?
    Dec 2007
    Harties
    cant do the math!...
    But 5.13's and 37"....
    I like anything with 4 or more wheels...
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by Wicd View Post
    Well, yes, but it depends on the torque conertor and rpm.
    A lot of info that would be very hard to get.
    I've split off the Autos from the manuals, as a good rule of thumb 1.8 to 2 for the multiplying action of a torque convertor is good if you want to directly compare a manual to an auto.
    This is why autos are often better offroad, and definitely for rock crawling!
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by Zombicon View Post
    oh go on, at least get all the rest of the info...
    like ratios / weight / power etc... all needed!!
    Gordon's Bay
    Thanked: 4378
    Will check Apoc calculations later and add the tyre diameter and final torque calcs.
    note I added a Force/mass field too!
    that is the ultimate measurement - you'll need the GVM for that though.
    anything over 9.8 and you can drive straight up!!!
    Dec 2007
    Harties
    Give me a day or 10 to clear my head from this flue.....
    Gordon's Bay
    Thanked: 4378
    well, 37s and 5.13s is pretty wild. you'll do some high rpm at 120km/h... but you'll score big on low end torque
    32" (812.8mm diamter) and 4.1 is Force Multiplier (from propshaft, NOT overall) of 1.66
    37" (939.8mm) and 5.13 is a Force Multiplier of 2.41
    is yours a Rubicon T/C or a Sahara? will be intersting to see how it scores against a 3.6 with those low ratios...
    I'm interested to see how the bigger engined vehicles do with lower crawling gears - those big 4.5 Toyota engines make a lot of torque... the Bigger Diesels and V8s in thigns like discos and Range Rovers will also be interesting..
    do you have the details for your hemi? ratios and power/torque etc?
  1. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  2. Replies: 56
    Last Post: 2017/09/19, 11:30 AM
  3. Defender Puma Rattle in Gear Box/Gear Stick
    By Natural Defender in forum Land Rover
    Last Post: 2017/01/25, 11:55 AM
  4. 1st and 2nd gear - difficulty - 4.0
    By xdoomx in forum Ford & Mazda
    Last Post: 2013/09/18, 09:32 PM
  5. "Loose" Colt Gear Lever
    By BruceB in forum Mitsubishi
    Last Post: 2013/06/22, 08:48 AM
