Sorento Repair Manuals
Results 1 to 16 of 16
    Jun 2012
    Richards Bay
    Thanked: 15
    Default Sorento Repair Manuals
    Good day
    I will post all of the manuals that I have here on the forum.
    Please use and abuse them just don't sell them
    Sakkie
  2. The Following User Says Thank You to oosta91 For This Useful Post:
    Jun 2012
    Richards Bay
    Thanked: 15
    Engine Manuals
    Attached Files Attached Files
  4. The Following User Says Thank You to oosta91 For This Useful Post:
  5. #3
    Jun 2012
    Richards Bay
    Thanked: 15
    More Manuals
  6. The Following User Says Thank You to oosta91 For This Useful Post:
  7. #4
    Thanked: 617
    Oosta
    Thank you for the manuals. Have already read up on the aircon that the guys can't seem to fix after the third attempt. Now I understand more and hope to ask some direct questions.
  8. #5
    Port elizabeth
    Default Sorento manuals
    Hi, Have just collected today a 2005 2.5 Auto in PRISTINE condition, 134Ks, FSH, and all reciepts of monies spent, 2 owners, inc contact details of 1st owner in C/T. I looked on the forum to familiarise myself with any info, having just walked away from a Jeep. Would like to thank you for making these manuals available. It realy is appreciated.
  9. #6
    Jun 2012
    Richards Bay
    Thanked: 15
    Good day
    The 4x4 system explained
  10. #7
    Jun 2012
    Richards Bay
    Thanked: 15
    Bump
  11. #8
    Thank you very much Sir, for sharing this wealth of information.
  12. #9
    Hello Oosta,
    Do you possibly have anything on the 2.5 Sorento's fuel injectors.
    I want to have my injectors tested and I want to do a leak back test myself.
    So I need some facts to work on, flow rates, leak back rates, etc.
    If you can help, thank you.
  13. #10
    Feb 2015
    Hi SorentoMB
    I don't have the numbers you are looking for but the attached files may provide useful info.
    Roger
  14. #11
    Oct 2015
    Noordhoek
    Hi Sakkie I trust your wealth of knowledge on specifically the 2007 Kia Sorento 2,5 CRDI is still available. My vehicle (150000km) has been losing coolant for some while now. My regular service centre has replaced hoses, pressure tested and re-tested the cooling system for leaks which were not apparent externally. I continued using the vehicle & a while later noticed steam vapour pouring from the exhaust after a restart after running the engine to temp. & allowing to stand for +/-10 minutes. Still losing coolant & eventually he did a compression check on the head and it was found to be low on pots 2 & 4. Strip the head, skim, replace valves, head gasket & head bolts. I have now done 2500km since this was done and today in 32 degC conditions the AC unit stopped working and the radiator temperature shot up and the car nearly overheated. Took about 3 to 4 litres of water and still no clue of where it is being lost. AC started working again after being switched off for 5 mins.
    Have you any insights as to where the water is escaping and is this a regular Sorento problem?
  15. #12
    If it is not a physical leak, it can only go out the exhaust as steam while you drive.
    Are you sure it was bled well and that it was not an airlock that caused it to almost overheat?
    Has it used any water since your last fill up?
  16. #13
    Oct 2015
    Noordhoek
    Hi SorentoMB
    Vehicle continues to require top ups on checking each morning. I have taken it back to the same place that did the head job 3months ago and they find water in pots 2 & 4. This is exactly the same feedback before the head was done the first time. I am now told that the engineering shop that did the skim, valve seat and pressure test last time cannot find a leak at room temperature, that maybe there is a small crack/s that only relieves pressure at running temperature. If only I could find a proper Kia mechanic. Each time I pick up a problem on this vehicle I am told a lot of nonsense by the agents/repair workshop. Nobody seems to understand these vehicles. Spent more in repairs in 3 years on this vehicle than on my old Isuzu KB23 LE 4x4 in the last 25 years. Birders at leisure
  17. #14
    Default Re: Sorento Repair Manuals
    What about searching for a good 2nd hand head? They need to test it at operating temp.
  18. #15
    Moreletapark
    I do most if not all maintenance and repairs to my vehicles but specialist information is hard to come by- generosity like this saves time and money.Thanks a million (or 2).
  19. #16
    Thanked: 60
    Bump
    Engineering Fact
    An opinion without 3.14 is just an onion.
    2007 Ford Ranger 2.5TD Montana Supercab
    2015 Toyota Etios (SWAMBO)
  1. Jeep Problems
    By Barto in forum Jeep
    Last Post: 2019/06/10, 02:57 PM
  2. Platkar questions
    By Lou07 in forum Vehicle & Technical Chat - General
    Last Post: 2012/09/12, 08:05 PM
  3. 2005 Kia Sorento Wheel Spacers
    By Hellas in forum Kia
    Last Post: 2012/04/20, 10:37 AM
  4. Anyone know this WJ?
    By IndianaJones in forum Jeep
    Last Post: 2012/01/03, 09:32 PM
  5. Hilux repair manuals
    By Bush Baby in forum Vehicle & Technical Chat - General
    Last Post: 2009/09/04, 02:33 PM
