Results 21 to 40 of 45
  1. #21
    Thanked: 568
    Anyway, 1st low wouldn't have been your correct gear for the sandy bit. Try 2nd or 3rd low. It should stick with the Disco no problem. Even with the narrow-ish tyres.
  2. #22
    Newcastle
    Thanked: 71
    Opps! I see you said it was a Toyota Land Cruiser Pick-up that battled. Did it have the Marie Biscuit stock tyres on?
    aftermarket 17inch wider tyres. not sure what width they were
    It's not leaking oil, it's sweating power!
  3. #23
    Newcastle
    Thanked: 71
    Will keep that in mind for the next outing
  4. #24
    Thanked: 4861
    I don't think it is reverse only the whole pressing the clutch thing is a bit dodgy. Water and most probably a lot of debris can enter the space between clutch plate and pressure plate or flywheel and it is quite possible to end up with bad or no traction. Strange things happen inside a bell housing if flooded with water
    Henk
    Follow us on Facebook
  5. #25
    Newcastle
    Thanked: 71
    thanks for the feedback
  6. #26
    Thanked: 115
    As per what hbannink said, but sometimes it's just about the lesser evil.....if you're stuck, what are you going to do, leave it spinning in gear while you attach the recovery equipment? No, you either press the clutch and stop to prep for a recovery, or you press the clutch and select reverse or another gear. Either way you're already done the thing that's the problem, pressing the clutch which kan let water and dirt into the clutch. A worse option would be to keep it in gear and let it stall in the water.
    So, in short, selecting reverse is not the real issue, using the clutch is, but when you get stuck, you have no real choice, somehwere between driving out and being recovered, you will have to use the clutch.
  7. #27
    Gaborone
    Thanked: 3293
    If you engage reverse, then the engine cranks the other way, which can suck water into the motor through the exhaust
    Not the pub here - careful!
    Walter Rene Gygax
    Kalahari Safari
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
  8. #28
    Randpark Ridge
    Thanked: 305
    I suppose it depends on the vehicle and depth of the water.
    A friend reversed his Isuzu in deep water and flooded the ECU under the back seats. The water came in through the cab vents which are behind the cab.
    Discovery 3 TDV6 S G4 No 29 - Mine
    Discovery 4 TDV6 SE - SWAMBO's
  9. #29
    Christo Meissenheimer Guest
    Quote Originally Posted by rabbiddog View Post
    That is why I like the Fortuner. In Savuti my Dad took the wrong line and went into a elephant hole , the water was just below the left side mirror , likely not the right side, because the air intakes sits there. The water was already seat high when my Dad reversed out. The Fortuner had not problems after it. We only struggled to get everything dry again, to get the smell out. That same day a Ford Ranger went into the same hole , got stuck for more than 2 hours and drowned the Ranger. It is not a nice feeling and I will never wish it upon someone. Likely we did not get stuck in that hole, else the Fortuner would had the same fate as the Ranger. We replaced all the oil in the diffs, transfer case and gearbox after that episode because water got into everthing. We are more than 50000km past that episode ,and if we did not change all the oil , we would have had a lot of problems. Likely Savuti had oil so we could have change everything.
  10. #30
    Thanked: 568
    Quote Originally Posted by Christo Meissenheimer View Post
    Luckily the elephant wasn't home
  11. #31
    Haha XJ Junkie My English is horrible. It was elephant bath hole . I don't know the correct term for it.
  12. #32
    Boksburg
    Oh my Hat! I've needed a good laugh all day! Thanks XJ! HA HA!
    Take only pictures, leave only tyre prints.
    www.intelliserve.co.za
  13. #33
    Thanked: 568
    Is it like a mole hole, just bigger & under water?
  14. #34
    Thanked: 115
    The best way is to strip out the entire interior, because most of that water and smell is in the thick absorbent lining under the carpets and since it sits between the carper and the body it takes forever to dry inside the car. Take it out, give it some air and it dries out quickly.
  15. #35
    haha no XJ Junkie. Is it like mud bath. Dit is plate water wat staan en dan is daar groot modder gatte onder the water wat die Olifante maak as hulle bad in die water en modder , soos dis basies hulle speel gat. Dit is nie 'n tonnel onder die water nie . Dit was die enigste water plaat wat ons nie geloop het voor ons deur gery het nie en toe gebeur dit. Slim vang sy baas.
  16. #36
    Jan 2009
    On the beach in Ramsgate But unfortunately paying the bills in Bellville CT
    Thanked: 18
    Yip proof that when going through water one needs to walk through it to avoid trying to drive through an elephants jaccuzzi
  17. #37
    Thanked: 1478
    If in water, the vehicle must be kept engaged in gear at all times. If revs are applied with the gearbox in neutral, this will result in the spare wheel spinning in the boot.
    This must be avoided at all costs, a spinning spare wheel in the boot is really going to mess up the chick that you are kidnapping and it will make a substantial dent on her resale value.
    If I can change I hope I never know.
  18. #38
    Apr 2011
    Wilderness
    Should'nt the bell housing be watertight with a vent pipe and drain plug?
    I recall something like that with an old Defender I had.
  19. #39
    Thanked: 115
    The older landies had a open threaded hole and a second blind threaded hole with a plug in it. When doing a water crossing, you move the plug from the blind hole to the open hole to close off the bell housing.
    Unfortunately a failing rear main oil seal is relatively common on a lot of vehicles, so leaving the bellhousing sealed or with a raised breather is a bad idea as leaking oil will fill up the bell housing and contaminate the clutch.
  20. #40
    Thanked: 1082
    Quote Originally Posted by OwenD View Post
    No jokes in the discussion section Neil, this isn't the pub.
    Besides I am sure if he is wading he would have already fitted an exhaust snorkel to prevent that.
    Hahahahahaha now that was funny. I'm pi$$ing myself where I sit.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
    By charlatan in forum Jeep
  2. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  3. Triton Reverse gear grinding ?
    By 4x4 freak in forum Mitsubishi
    Last Post: 2010/01/12, 10:29 AM
  4. Difficulty selecting reverse gear?
    By JDNaude in forum Toyota
    Last Post: 2009/08/27, 09:03 PM
  5. shifting "on the fly"
    By OwenD in forum Mitsubishi
    Last Post: 2009/02/20, 08:44 AM
