will my 4x2 make it to Ponta do ouro?
Results 1 to 20 of 23
    Jun 2013
    pretoria
    Default will my 4x2 make it to Ponta do ouro?
    As the title says will my auto 3.0d4d 4x2 toyota fortuner manage the trip without 4x4?
    Any advice will be appreciated.
    Are you towing anything?
    Without a trailer you shouldn't have any problems.
    Let your tires down to 1 bar
    Prado 4.0 2005
    Wrangler Unlimited JK CRD 2008 (Ex)
    Cherokee 3.7 2004 (Ex)
    Colt 2.8 (Ex)
    just south of Mozambique border
    Thanked: 154
    If you have a diff lock you should easily as long as you choose the right track and avoid the steep sandy sections.
    Nappies and politicians should be changed regularly AND FOR THE SAME REASON
    Save the rhino kill a poacher
    Dung beetles have right of way
    2006 DISCO 3 TDV6 HSE
    1998 Disco I V8 Bought it back Sold again.
    1973 Series IIA 109 (Jorrie)
    1974 Series III S/W modified Ford V6 Defender box. Body work (Sold)
    Sep 2012
    Thanked: 68
    Shyam since u rid of your performance vehicles you off the map! lol
    Do you have experience driving on sand?
    If not, you may have a problem. If you have done it before it should be ok.
    Its not about how fast you are but about how quick you get there...
    Harties
    Hi
    Most probably, if you let your tyres down as mentioned and keep enough momentum in the thicker sand.
    There is one dune that you will need to just check the correct tracks for easier travel
    If you get stuck, there is also vehicles every now and again that can assist you
    We did it with a normal Terios, only problem was the guys left the aircon on which “stole” the xtra “horses” and got stuck
    "Jaag elke avontuur met n Hart wat gelowig klop"
    2008 Land Rover Puma 90 - sold
    2003 Land Rover Disco 2 Td5 - sold
    1972 Land Rover Series 3 88'' - investment
    Jun 2013
    pretoria
    Quote Originally Posted by Die$eL View Post
    Hehe im around bro. Only experience of sand driving is at sodwana.
    Ok good so it can be done. 1 bar and correct route and I should be ok. Not towing anything but friends and scuba gear
    Thanked: 30
    You will be fine. Just stay in the tracks and dont try funny things.
    I did it numerous times in my 4x2 Isuzu with deflated tyres to 1Bar
    Jacques
    2013 Amarok BiTDi DC 4Motion
    2018 Bushlapa Ratel 4 Military Edition - BL1402
    Sold - 2011 Conqueror Comfort
    Sold - 2004 Isuzu KB300 DC (was only 4x2 but a happy 240000km and 9 years)
    Ruimsig
    Just put foot in the sand an keep your difflock on!
    2012 FJ Cruiser
    2005 Jeep Sahara 4.0
    2010 Renault Megane Coupe'
    2013 Conqueror Commander
    Tuff Stuff Insurance
    Jun 2013
    pretoria
    Ok sweet! my friend told me I will get my answer in a day from this forum. . . And I did. Many thanks
    Jun 2007
    Thanked: 31
    Hmmm not so sure about the locker bit in thick sand. What you may gain in traction will surely be overridden by under steer , especially if only in 2 wheel drive .
    Current planet killers
    Disco 3 V8
    Colt Rodeo 2800
    Land Cruiser 79 V6
    Previous
    SIII Chevy 4.1 Straight 6
    Forward Control SII
    Rangie Classic 3.5 V8
    Rangie Classic Chevy 5.7 V8
    Defender 2.8 Straight 6
    Disco 1 3.5 V8
    Disco 3 TDV6
    Disco 3 V8
    Disco 1 V8
    Disco 2 TD5
    http://heine9999.wordpress.com/
    Thanked: 30
    There is not a lot of very sharp turns on the way to Ponta, so the understeer problem should not really matter. Momentum was a lot more important to me in the 4x2 and also keeping in mind to let the bakkie roll to a stop rather than applying hard braking.
    Jacques
    Nigel
    Thanked: 2062
    Quote Originally Posted by pretorjn View Post
    .......... Momentum was a lot more important to me in the 4x2 and also keeping in mind to let the bakkie roll to a stop rather than applying hard braking.
    Very good tips. The difflock will save your day.
    Uniglide
    +27 zero eight 2 four 95 9252
    Rustenburg
    Thanked: 119
    You will make it.
    Just do not try something stupid, and do not travel alone (1 vehicle)
    Thanked: 30
    Quote Originally Posted by Andrewfus View Post
    ... and do not travel alone (1 vehicle)
    Agreed. Although we did this numerous times in our young and stupid days, it is advisable to rather have a travel companion to get help if need be. Otherwise someone has to walk very far
    Jacques
    JHB South
    and before you pull away, reverse a meter or so in order to have a nice flat compacted surface to start again... when necessary like in very thick sand; try not to brake; rather roll to a stop
    May 2013
    A couple of years ago I saw a Bantam parked at simply Suba....don't know how he got there....
    Thanked: 30
    On my first trip I saw a Polo Playa at Malongane
    I have to admit that it had a towrope attached to the front
    Un believeable what some people will try to do
    Jacques
    Sep 2012
    Thanked: 68
    yip as mentioned, dont brake or come to an abrupt stop as it builds a mound of sand in front of your tyres. reverse a little before taking off
    keep momentum up.
    keep to the tracks. Deflate your tyres.
    Best is to have a second vehicle with you.
    Fitting A/T tyres made a Huge difference on my bakkie! Nice thick thread to grab the sand.
    sand driving is sooo much fun! we going to Kosi bay at the beginning of august. Cant wait!!
    End of the day, remember 3/4 of the fun is in getting stuck!
    Mar 2013
    Tarentaalpan
    Thanked: 33
    Its completely do-able as everyone said. Did it in my 2.5 Drifter. Yes, I did get stuck but luckily plenty 4x4's were around to help. Also Ruan on his 4x4 tractor.
    johannesburg
    Hi there, the short answer is yes, i however do not agree with the locker on, i have done moz many times in my isuzu 4x2 and never got stuck (never used a locker as it is not needed an just gives understeer) what you can look at is deflating even more than 1 bar at the back (leave the front @ 1 bar) in really thick sand i have gone as low as 0.4 bar but keep it straight and steady or you will chuck a bead. (only went \ needed .4 on the famous dune close to kosi bay but for moz .8 rear will be just fine)
  1. 4x2 Deflation in Soft Sand - The story !!!
    By PGJ in forum Tyre chat
    Last Post: 2013/09/24, 10:55 PM
  2. Road Conditions Joburg to Ponta do Ouro
    By BillyH in forum Mozambique
    Last Post: 2013/05/15, 04:28 PM
  3. Centurion to Ponta do Ouro
    By JNel in forum Mozambique
    Last Post: 2012/04/05, 10:45 PM
  4. Ponta Do Ouro over easter weekend
    By Gee S in forum The 4x4 Pub
    Last Post: 2012/03/29, 10:20 AM
  5. Ponta Do Ouro to Maputo on a quad
    By moz fan in forum Mozambique
    Last Post: 2009/09/09, 10:39 AM
