Two Stroke oil in TDV6 works wonders!!
Results 1 to 20 of 88
    May 2012
    Smile Two Stroke oil in TDV6 works wonders!!
    Just to say thank you to Baben for his advise to add some two stroke oil to my Discovery 3 TDV6 diesel. The TDV6 was very lazy from 0-2000rmp. Then suddenly a lot of power. After adding the two stroke oil i now found that the engine is much more alive from 0-2000RPM. I don't know what it did to the engine, but it worked wonders.
    I may also mention that i did the remap, but i think a lot of the new gain in power is to do with the two stroke oil and the rest the remap.
    Thanks Anthony.
    Kloof
    Thanked: 402
    Heron,
    Did you do the remap and 2S0 at the same time?
    If so, how can you tell which of the 2 is responsible for the improvement?
    Andrew Beuster
    Amarok milk bottle
    "So really , you are not so smart , you are a old Oomie that has to much time on his hands" - Christo Meisenheimer
    May 2012
    My brothers TDV6 has a lot more power than mine. The i did the remap with Baben and was hoping to have the same power as my brother.
    After the remap i could not really tell if threre was a difference. my TDV6 was still lazy.
    While Anthony did the remap he advised me that i may have to add some two stoke oil. I did this for three tanks in a row, and it was almost at every pull away that i was more and more amazed with the new found power.
    I even had to appologise to some of my pasangers when driving off from a full stop, because i was use to putting pedal to the metal just te get off the dot. Now if i do that i can drop a GTI (almost)
    I think the remap is a must, but in my case the two stroke oil did the trick
    Kloof
    Thanked: 402
    Enjoy! Take the lead weights out of all your right shoes now.
    Andrew Beuster
    Amarok milk bottle
    Thanked: 468
    Quote Originally Posted by Heron View Post
    Thanks Anthony.
    Hi Heron
    great it did the trick for you. BTW Anthony got that tip from me.
    Now let me explain why you suddenly got back that lost power.
    Aside from giving much needed extra lubrication to the CRD injection components (it will save your injectors and the HPFP), the new Jaso-FC grade 2sO's contain some VERY effective additives, that remove carbon buildup from the inside of the engine.
    In your specific case it will most probably have been the vane mechanism of the VVT turbo, that was getting sticky due to excessive carbon build up around the actuator ring of the turbo.
    Below some pics that illustrate this.
    Pic one:
    Excessive carbon build up - This turbo failed due to a seized actuator motor (burnt out)
    Pic Two
    Turbo out of our D3 run on 500ml 2sO in EVERY tank - Check the clean pivot points
    George Bosch
    Distributor for:
    2beFree Guest
    Hi Heron
    Pic one:
    Pic Two
    Hi there George
    500ml for a full tank. What is the ratio per litre, 5ml for every litre of diesel? Can any two stroke be added?
    PS: Thanks for showing out to me where that little button is located to release the gear lever when in park.
    Walvis Bay
    Moet dit 'n spesifieke soort two stroke wees ?? Sal dit op my 300 D-Teq isuzu ook werk ??
    Toyota Hilux Extended Cab 3.0 D4D 4x4
    Toyota Hilux Legend 45 S/C 4x4
    Springs
    Thanked: 281
    as discussed before - don't use synthetic 2SO
    TT grade Jaso FB or FC is perfect
    after 3 tanks at 500 ml per tank, you could step down to 250ml per tank
    one of the guys on the forum misread 500ml and did 5l per tank for 1/2 of the first tank.
    the Td5 ran well, no smoke and was very quiet
    after around 300km he realised his mistake, called and told him not to stress. he topped up the tank in any case.
    he is now running 250ml per tank and she is happy
    kempton park
    where can you get Jaso FB or FC in bulk?
    1997 Defender 90 300TDI
    BF Goodrich Mud Tyres
    2008 Discovery 3 TDV6 SE
    BF Goodrich AT Tyres
    Springs
    Thanked: 281
    Autozone sells in 1 litre units but i have seen 5 litre units around
    1 litre is a handy size
    lasts about a month and will fit inside the vehicle centre console
    Where can one get a remap done in CT?
    I guess DECAT + 2SO + REMAP = very spirited TDV6.
    Can i add the normal tso one finds at the local Shell/Engen stations?
    Current: AMAROK BITDI 4MOTION
    Ex: HILUX D4D 4x4 DC
    EX: Land Rover D3 TDV6 SE
    EX: Land Rover Defender 110 300 Tdi
    EX: Mitsubishi Pajero 4x4 LWB V6 Blister
    Baviaans, Richtersveld, Tankwa Karoo, Kgalagadi, Botswana, Addo, West Coast, Southern Namibia
    kempton park
    Quote Originally Posted by Landyluvver View Post
    thanks
    Dave
    Centurion + Others
    Thanked: 208
    I THINK!! The ratio quoted was 0.05%...
    Merit before Race - anything else IS Racism.
    Stay Calm, engage low-ratio, keep buggering on - a Landy Man
    Longevity isn't worth dying for,
    Thanked: 468
    Quote Originally Posted by Capt Chaos View Post
    Hi guys
    the correct ratio is 1:200 or 500ml per 100lt of diesel.
    Sasol and Caltex sell JASO-FC grade 2sO at all their fuel stations.
    Bulk 2sO can be purchased from Fuchs Oil or one of their distributors in 1lt, 5lt 20lt or 210lt bindings. You do however have to order the bigger volume bindings per special order.
    Trust this helps.
    George Bosch
    Distributor for:
    Thanked: 2494
    another believer here
    http://forums.tdiclub.com/showpost.p...08&postcount=5
    his post for those that don't want to click
    Here is what mine looked like after 393,400 miles of running a blend of 2 cycle oil and Power Service.
    Feb 2012
    Brackenfell
    Thanked: 44
    Quote Originally Posted by Mojito View Post
    +++1
    2009 Range Rover Sport 4.4 V8 HSE (his)
    Izmir Blue
    2012 Audi S3 (hers)
    Brilliant Red
    Springs
    Thanked: 281
    PM Discomad
    May 2012
    Thanks. I sommer added 500ml of normal two stroke oil which i got from the boat shop in 5l container. A few months back. Will do the JASO-FC next every 5th or so tank.
    Maybe the Boat shop oil has that something magic inside :-)
    Can't wait to see how it goes with the Caravan now?
    Thanked: 468
    Heron
    500ml with every tank full.
    It really works!
    George Bosch
    Distributor for:
    Thanked: 468
    This is what they look like when stripped at high mileage. Check especially the total lack of a carbon ridge in the bore.
    When I inspect an opened diesel engine (high miler), I can immediately tell if the owner added 2sO or not. The lack of carbon ridges and heavy carbon deposits on top of the pistons are a dead giveaway!
    George Bosch
    Distributor for:
  1. Oil warning !!
    By DVR in forum Vehicle & Technical Chat - General
    Last Post: 2012/12/04, 03:46 AM
  2. Mixing 2-stroke oil into Diesel
    By hgbosch in forum General 4x4 Discussion
    Last Post: 2011/01/03, 01:11 AM
  3. Replies: 7
    Last Post: 2010/06/21, 12:34 PM
  4. Prolong
    By henlo in forum Jeep
    Last Post: 2007/06/06, 11:59 AM
  5. Good Oil ---- Bad Oil !!!!!!!!!
    By Landy Nut in forum Vehicle & Technical Chat - General
    Last Post: 2007/02/12, 12:34 PM
