Results 1 to 2 of 2
    Jun 2013
    Default Mitsubishi Colt drive chain (in transfer case) replacement
    My Mitsubishi Colt 2.8 TD has a very bad noise coming from the transfer case when I engage 4x4. From what I have read it seems to be the drive chain for the front drive shaft that is slipping.
    Over the weekend I checked the vacuum system that engages/disengages the front diff. I found numerous problems with it but sorted it all out. The actuator in the diff works perfectly now and I donít think that the noise is coming from the diff.
    Does anybody know whether you can split the transfer box from the main gearbox without removing the entire gearbox from the vehicle? And if it is the chain that is causing the noise, is a new chain easy to find and install?
    Wilhelm Kenny
    Aug 2010
    Florida
    Did my transfer case a few years ago. Chain was expensive at dealers. I bought a used gearbox from Jap imports. Cost less that time, I think it was 4 years back. Clutch kit was also bit costly.
    Mercedes ML 320 CDI
    Vw golf 6 GTI
    Vw Transporter Double Cab
  1. Colt Drive chain
    By Johnna in forum Mitsubishi
    Last Post: 2011/10/20, 08:05 AM
  2. Auto Jimny transfer case
    By Tjarra in forum Suzuki
    Last Post: 2011/04/07, 08:54 AM
  3. Discovery 2 Transfer Case Refurbishment
    By Kooos in forum Land Rover
    Last Post: 2011/04/01, 09:25 AM
  4. Transfer case oil seal replacement
    By dph in forum Mitsubishi
    Last Post: 2009/12/14, 11:01 AM
