Results 1 to 2 of 2
    Thanked: 16
    Post Replacing Windscreen
    Hi
    I've just replaced the windscreen on my Defender while doing a bit of a respray and tidy up. I bought a shatterproof (Not Shatterprufe) for R500 and decided to do it myself as I've done it before, except last time I cracked it. I also put 35% smash and grab on all the glass. R600 odd for 3m x 1.5m. Bit of a learning curve a few small bubbles but I'm happy as the bubble are where there are pits in the glass. (and I saved myself R1000)
    I followed this advice
    http://forums.lr4x4.com/index.php?sh...=0#entry107519
    Had it done in 20 min flat.
    Tips to follow :
    1 - Use plenty of lubricant. Best is 50:50 green washing up liquid and H20
    2 - Pour lube down groove on the inside of the rubber and fit the rubber to the windscreen.
    3 - Put your cord in the outer groove and pour the lube in the groove.
    4 - Have someone !gently! hold the windscreen square with the frame.
    5 - Pull the cord from both sides evenly. Make sure that you don't get one side in first otherwise you will struggle.
    6 - DONT!! try to push the screen in from the outside especially the corners as this WILL crack the glass!
    Thats it! and Remember PLENTY of LUBE.
    Charles
    Charles
    Defender TDI 110 CSW
    Lift, Long Range Tanks, Dual Battery's, A few Dents and loads of FUN!
    Don't Regret Enjoying Life!!
    Sep 2012
    Thanks, I want to replace mine also!
    Richard
    ONE LIFE. LIVE IT.
    1995 Land Rover Defender 110 300tdi - Winston
    BMW Z4 - Platkar/Fuel saver
    4x4Action Group - 0001
    [email protected]
    "Buying a Land Rover, specifically a Defender, is not a transaction, it's a marriage of personalities, a natural childbirth, a proud moment in time......!!" - Oldtimer
  1. windscreen ...aargh
    By playback in forum Jeep
    Last Post: 2012/10/15, 10:44 AM
  2. Disco II Windscreen Leak
    By Kevn Disco II WP in forum General 4x4 Discussion
    Last Post: 2012/06/02, 07:58 AM
  3. The "great windscreen daylight robbery"
    By Wynandd in forum Softroaders
    Last Post: 2012/01/13, 01:27 PM
  4. Windscreen replacement.
    By Johan in forum General 4x4 Discussion
    Last Post: 2010/11/29, 12:27 PM
  5. Replacing windscreen rubber
    By davetapson in forum General 4x4 Discussion
    Last Post: 2006/12/07, 11:34 AM
