Broken Defender light switch?
Results 1 to 8 of 8
    Default Broken Defender light switch?
    My landy's headlights stopped working last night, it works when I pull back to flash the brights, but not when in the normal position.
    I checked all the fuses and are all fine.
    I think it is the short light switch behind the indicator lever that's faulty? Anyone ever had this issue?
    Would appreciate any other ideas about this.
    If at first you do succeed, don't look too surprised.
    Jan 2009
    Common issue. Replace the switch. Dover will most probably be the cheapest
    Range Rover Big Body 5.0 V8 Supercharged
    Land Rover Defender 100 PU V8
    Land Rover Freelander II SD4
    Jaguar XJS V12
    Witfield, Boksburg
    Had the same problem.
    It's the switch, easy enough to replace
    Chris
    "Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing" Helen Keller
    1996 Range Rover P38 4,6 HSE
    1977 LandRover Series III 109" Project
    Sep 2012
    Secunda
    Jip, what they said
    Vtown
    Could also be the bulb-the low beam element might have frizzled,easier to check than replacing a switch?
    A legend in his own mind
    Ladybrand
    Replace the switch, AND put in a relay. Common fault from a bad design as all the current passes through the switch and burns it out.
    98 Defender 110 tdi CSW
    96 Defender 110 tdi pick-up
    Will pop into Dover, thanks guys!
    Dec 2010
    Amanzimtoti
    Boesmanland before you replace the switch you can easily repair it as well or if you do replace repair the old one and keep as spare for times when you need it. Also add relays to your lights as this will lessen the load on the switch.
    Theo le Roux 1995 Defender 110 300TDI 2014 Bush-Trotter Warthog
  1. What Makes a Defender Iconic
    By JohanJvV in forum Land Rover
    Last Post: 2011/09/07, 10:21 AM
  2. Fortuner Where is the light switch ?
    By DavidGX in forum Toyota
    Last Post: 2010/01/15, 07:03 AM
  3. Defender td5 reverse light switch
    By Jon747 in forum Land Rover
    Last Post: 2010/01/01, 09:35 PM
  4. Defender Puma Broken manifold bolt
    By Pieter Landy in forum Land Rover
    Last Post: 2009/09/05, 01:06 PM
  5. Diff Lock switch - Indicator light
    By Blackie in forum Mitsubishi
    Last Post: 2008/05/13, 10:38 AM
