Terios OffRoad Ground Clearance: Measured with pics.
Results 1 to 3 of 3
    Default Terios OffRoad Ground Clearance: Measured with pics.
    Hi,
    The ground clearance of the Terioss Offroad edition has been the topic of a lot discussion over time. So I'm posting my measurement findings for the forum.
    Daihatsu promotional info:
    Ground clearance:
    Daihatsu Terios Offroad : 255mm
    Daihatsu Terios 4x4 / 4x2 / LWB: 205mm
    Tyres:
    Daihatsu Terios Offroad: 235/60r16
    Daihatsu Terios 4x4: 215/65/r16
    Conditions:
    2010 Daithatsu Terios Offroad.
    Tyres as measured: 215/70/r16*
    * I'll adjust my findings for the different tyres fitted.
    Radius adjustment from 215/70/r16 to 235/60r16: -9.5mm
    Raduis adjustment from 215/70/r16 to 215/65r16: -10.75mm
    Lowest point of ground clearance - area below rear shocks:
    Clears 195mm but not 200mm.
    2nd Lowest point of ground clearance - area below front suspension arm:
    Clears 220mmm but not 225mm.
    Rear diff clearance:
    Clears 225mm but not 230mm.
    Sump / Front suspension clearance:
    Conclusion:
    Terios Offroad (215/70r16)
    Ground Clearance on center of vehicle: 225mm.
    Lowest point under rear shocks: 195mm.
    Standard Terios Offroad (235/60r16) (-9.5mm, rounded to 10mm)
    Ground Clearance on center of vehicle: 215mm.
    Lowest point under rear shocks: 185mm.
    Standard Terios 4x4 (215/65r16) (-10.75mm, rounded to 11mm)
    Ground Clearance on center of vehicle: 214mm*.
    Lowest point under rear shocks: 184mm*.
    *The assumption is the raised suspension does not influence ground clearance - has been explained elsewhere on the forum.
    Org.
    Last edited by dieOrg; 2013/04/13 at 12:51 PM. Reason: Added std 4x4 conclusion / spelling
    '10 Terios 4x4 Offroad
    Live : Bethal , Work : Saudi
    Thanked: 231
    Ok nou maak dit meer sin.
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
    Mar 2007
    Thanked: 719
    dieOrg
    Thank you for making the effort to take the measurements.
    One thing though .... Just check your tire size calculations.
    As I have it the 215/65R16 has a diameter of 686mm, the 215/70R16 = 707mm and the 235/60R16 = 688mm
    The total height difference therefore = +21mm and +2mm and the actual increase of the height of the axle = +10.5mm and 1mm.
    For practical purposes, the difference in negligable ......
    Johan
    2011 Daihatsu Terios 4x4
  1. Ford & Mazda New Ranger T6 offroad pics
    By Carel.Broekman in forum Ford & Mazda
    Last Post: 2013/10/01, 02:28 PM
  2. Replies: 2
    Last Post: 2013/02/25, 12:20 PM
  3. Ground Clearance (Suspension upgrade)
    By MadCat in forum Mitsubishi
    Last Post: 2013/02/08, 03:35 PM
  4. Gauteng West VII Hennops Offroad Trail
    By Flagster in forum Gauteng
    Last Post: 2011/09/13, 01:42 PM
  5. Replies: 5
    Last Post: 2010/06/17, 09:10 AM
