Trailer Tyre Pressure
Results 1 to 6 of 6
    Jul 2007
    Gauteng
    Default Trailer Tyre Pressure
    I have a Echo 4 Trailer and I was wondering if anyone can suggest a General rule for Trailer tyre pressure. I have the same tyres on the trailer as my vehicle. 255/65/16. The Vehicle recommended pressure is 2.21 Bar to 3 bar depending on the load.
    The trailer weighs 450 KG unloaded but with a full load it must be close to 1000kg.
    I have been using 2.5 Bar and not had any issues so far. Comments please.
    Ek weet 'n goeie aanduiding is om die trailer se banddruk dieselfde te ry as die voertuig wat hom sleep.
    Oct 2006
    Thanked: 16
    First set of tyres on our Echo 2 were replaced at an estimated 75 000km due to eccesive tyre wear in the insides - the middle & outsides were still in very good shape. I kept them at 1.8 bar and realised too late about the inside tyre wear.
    The current set I run at 2.4 bar to hopefully "spread" the tyre wear more even. It has done an estimated 15 000 km without any signs of inside wear.
    In sand I go down to 1 bar on the trailer (if you look at the behaviour of a trailer following the car in a thik 2 spoor sandtrack you will notice it slide quite a bit to the sides - therefore I do not go lower than 1 bar due to the risk of the tyre getting off the rim...??)
    Willem Grobler
    LC 105 GX
    Pennington
    Thanked: 119
    I tow a Mongoose off road trailer behind my Hilux, weight is the same as your Echo 4 and I also have 16" all round. Open road I run 210 front and 250 for both rear & trailer. Keeps the rig stable & the heat build up is very small, which is the first sign that the pressure is wrong
    Jul 2007
    Gauteng
    Thanks for the replies - I suppose there can be no general rule!
    The tyre pressure for loaded LR Discovery 2 is 2.4bar front and 3.2bar rear if I remember correctly. I have as a result run the trailer at 2.5. It has been very stable on road and on dirt road. I have not done any heavy sand or serious off-road yet.
    Why would you drop the tyre pressure on the trailer in sand?
    Richards Bay
    Flotation. Better flotation = lower rolling resistance = smaller chance of bogging down.
    Gerrit Loubser
    Richards Bay
  1. Advice needed for Tankwa - tyre pressure
    By winemaker in forum Tyre chat
    Last Post: 2011/04/19, 06:13 PM
  2. Why bigger tyres?
    By SimonB in forum Tyre chat
    Last Post: 2010/10/05, 01:22 PM
  3. Diving at altitude?
    By Biggles in forum Scuba Diving
    Last Post: 2008/08/25, 03:14 PM
  4. Tyre pressure gauge
    By Kaptein Jack in forum Tyre chat
    Last Post: 2007/12/18, 03:23 PM
  5. Tyre Pressure monitoring system
    By AJP in forum Tyre chat
    Last Post: 2007/10/24, 09:26 AM
