Results 1 to 6 of 6
Thread: Bolero Brakes
    Apr 2012
    Newcastle
    Default Bolero Brakes
    Hi There
    I would like to find out if anyone has had a problem with brakes fading away
    My bolero brakes work fine but if you drive a while and press brakes there is nothing then you pump the brakes and it works again ,
    Please let me know i would like to know what i need to repair it
    Master Cylinder Repair kit was my first choice @ the Dealer
    Pretoorsdorp (Centurion)
    Thanked: 167
    I had the same on my Bolero, also replaced the Master Cylinder and still the same, sold the Bolero and my Thar has also done the same, maybe once or twice..
    No idea what the problem is
    Klipriver
    Thanked: 435
    Have you tried replacing the brake fluid?
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
    Thanked: 167
    Quote Originally Posted by All -in -one View Post
    Yes, I did replace the brake fuild on the Bolero when I changed the master, in fact I fitted a all new booster and master combo at the time
    But not on the Thar yet
    Kuilsrivier
    Thanked: 210
    Does your brake pedal go soft, or is it still hard, but just no brakes?
    A soft pedal could be loads of things, air bubbles due to heat or poor brake fluid, water in the lines, poor flexable brake lines.....
    A hard pedal with no stopping power could be brake pads. Not sure what type the chinaman use, but perhaps look at uprated pads?
    Thanked: 167
    Quote Originally Posted by Wetkit View Post
    Mine went soft, dropped to the floor and then when pressed again working 100%
    Most times I could recall was in 4x4 applications
  1. Hydraulic trailer brakes.
    By Henris in forum Trailers, Caravans, Towing etc
    Last Post: 2013/02/17, 03:02 PM
  2. Brakes on Toyota Hi-Lux 1986
    By Bertus Geyer in forum Toyota
    Last Post: 2009/09/01, 12:31 AM
  3. Ford Ranger 2.5TD - Rear Brakes Grabbing
    By Steel-Wheels in forum Ford & Mazda
    Last Post: 2009/08/17, 10:24 AM
  4. Jeep rear disk brakes
    By gorman in forum Jeep
    Last Post: 2008/10/03, 12:58 PM
  5. Improving your 4 x 4's brakes
    By mvcoller in forum General 4x4 Discussion
    Last Post: 2007/12/04, 09:46 AM
