Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Drawer system
  1. #21
    Thanked: 379
    http://connect-it.cc/products.html
    Connect it blocks. Maizey Plastics in PTA West is an agent.
    Peet Schultz
  2. #22
    Apr 2012
    Thanked: 101
    Offroader2be, well done. I wish I could something like that - well done mate!
    Mitsubishi Pajero Gen4 3.2 DiD SWB Auto - the Squeek, Rattle and Shudder Mobile (almost all fixed!)
    Goodyear Wrangler ATSA Tyres
    Stofpad4x4 50mm Spacer Lift
    Stofpad4x4 Front Bashplate
    Stofpad4x4 Rock Sliders
    Llumar Smash & Grab Window Tint
    Dual Battery
  3. #23
    Oct 2012
    PeetS, Thank you for this link. BRILLIANT PRODUCT!!
  4. #24
    Bellville
    Default Alu Corners
    Hi Offroader2b
    Looks magic. Where can I find the Alu Corners, T's etc. for the Frame?
  5. #25
    Default Springbok
    I intend using mild steel for the framework. What is your opinion on that?
  6. #26
    Very nice
    2007 Toyota Fortuner 3.0 D4D 4x4
    2005 VW Polo 1.6
  7. #27
    Thanked: 379
    Quote Originally Posted by christo ferreira View Post
    Christo, mild steel will work, but you pay a price in terms of the extra weight that you will carry around. I built my very first attempt out of 3 mil x 25 angle iron and believe me, it is quite heavy.
    Best is to try and work out how much material you will need and then calculate the difference in weight. Apart from that, no reason that you cannot use mild steel.
    The one advantage is that you can then experiment until you get to the proper setup - nothing easier to just cut and weld!
    Peet Schultz
  8. #28
    Oct 2008
    Uitenhage
    Phoned for prices today , you only get the 1430mm slide in the heavy duty at R 1200 a set. The setup I want to do I need 3 sets , R 3600 for slides is a bit rof.
    TONY ERASMUS
    2022 Hilux 2.8 GD6 Legend Auto 4x4
    Eascape Gear seat covers , dash cover and tranny cover
    Led cab lights
    LED Headlights
    Led Lights Hella
    Tyre monitors
    50mm lift
    2 way radio
    Snorkel
    Rinocab canopy
    Electric drawer system
    Built in compressor with air point at each wheel
    Air helpers
  9. #29
    Thanked: 379
    Quote Originally Posted by TonyE View Post
    http://www.customleisuretech.co.za/c...mmo-box-slides
    You need to offset this against what a manufacturer is going to ask you. Have a look at the link above.
    Maybe try a design where you can add on later? Start with a single set.
    Peet Schultz
  10. #30
    Oct 2008
    Uitenhage
    Quote Originally Posted by PeetS View Post
    Thanks for the link , it looks good but the problem i have is not building the system or to get a design but mainly the fact that you don't get a 1430mm slide in a medium or light duty . The design i have will only need one set of heavy duty slides and two sets of lighter ( hope fully cheaper ) slides.
    Suppose if i use the heavy duty then it will just last longer .
    TONY ERASMUS
    Led cab lights
    LED Headlights
    Led Lights Hella
    Tyre monitors
    50mm lift
    2 way radio
    Snorkel
    Rinocab canopy
    Air helpers
  11. #31
    Jun 2012
    Kempton park
    Very nice!!
    Faan 8)
  1. DIY Hilux D/C Drawer System
    By UtataNtaka in forum Camping, Fridges, Accessories
    Last Post: 2015/03/11, 09:03 AM
  2. Home Built Discovery Drawer System
    By AndyF in forum Camping, Fridges, Accessories
    Last Post: 2013/12/07, 11:26 AM
  3. African Outback Drawer System
    By Gentoo in forum Mitsubishi
    Last Post: 2012/04/04, 10:49 AM
  4. Camping after a drawer system
    By Skalla in forum General 4x4 Discussion
    Last Post: 2010/08/09, 08:07 PM
  5. Disco Drawer System
    By LandJero in forum Camping, Fridges, Accessories
    Last Post: 2008/10/27, 11:07 AM
