Another V8 Build ?
Results 1 to 20 of 123
    Kathu
    Thanked: 2844
    Default Another V8 Build ?
    Maybe another V8 build om its way. My Ford 4.0l Super Cab decided to slip its timing chain while stationary.The wife told me on Thursday afternoon that she tried to start it, but the battery was flat. I give no thought as I was in a hurry and told her to take the DC. Try to start it on Friday but it only swing a few times before the battery run out. Put the charger on and tried again later. It did start after swinging for some time but running very rough. Tackled the job Monday night. First thought it might be the fuel pump. Measured pressure and it seems fine. Ignition timing was spot on with the motor running. My gut feeling was telling me from the start valve timing. Took of the Tappet covers today an found the right hand cam not turning. Look like a loose timing sprocket on the balance shaft,
    Now the decision, do I repair the 200k km engine or do I drop in a mildly tuned 302 V8 ? Do not know if it have bend valves which is usually the case.
    I really enjoyed this 4.0l. Feel a little sad as this is the first ever Ford engine to let me down in all the years I drove Fords.
    Guess I have to find out the prices first.
    Apr 2011
    Villierdsdorp
    What about a Lexus V8
    Another interesting thread coming up. Bou hom Christo. Bou hom
    Groetnis
    Wynand.
    2013 Ford Ranger T6, 2.2, XL, 4x2
    Nigel
    Thanked: 2290
    I think you have bent valves.
    Pull the heads.
    Overhaul them.
    Put them back.
    Jou gat jeuk net weer.
    Uniglide
    +27 zero eight 2 four 95 9252
    Jan 2011
    Thanked: 8
    Maar dit is 'n lekker jeuk...jy weet...daardie een agter jou rug waar jy net net by kom
    Modderfontein, naby Rysmierbult
    Thanked: 601
    Pull the heads.
    Overhaul them.
    Put them back.
    Lekker jeuk daardie, veral as jy klaar gekrap het
    Johan Mitchell, .... r.i.v. Swambo Marthie
    My beste kennis is diť oor my eie onkunde
    '96 Colt DC V8 ... Safari Camper ... '88 Fleetline L
    '88 Ballade 150 ... sold
    "The rule here is that there is no rule" .. MikeAG
    Kathu
    Thanked: 2844
    Sjoe julle het seker gemaak die slaggat is baie groot. So bietjie agtergrond. Die Ingeneur wat die 4.0l sohc ontwerp het het nog nooit `n spanner in sy hand gehad of Ford het opdrag gegee dat `n DIY ou nie aan die enjin mag werk nie. Sy cams word deur `n balanseer staaf gedryf. Een voor en een agter. So Henri dit is nie net vir Heads trek nie jy moet die hele enjin uit haal. Wynand jy weet mos slegs True Blue. Pieter jy weet wat maak `n leŽ enjin bay met my. Johann as ek so netjies soos Rotor kon werk het ek `n Lexus oorweeg..
    Alle grappies op `n stokkie het klaar vandag my moer gestrip. Moes omtrend `n uur lank strip om net die tappet covers te kon af haal. Ek weet ek is oudmodies maar sukkel maar om te verstaan dat `n 4.0l enjin met al die tronics net 157kw doen. Met `n ou 3.4 V6 met regte goodies kon ek `n 4.0l se gat skop met net baie basics. Ek verstaan baie goed hoe werk `n enjin maar selfs na 45 jaar kan min enjins `n BDA 1.6 TEEN 160KW klop.
    Cams en side draughs ( Henri , Wynand)toe kon ons nog tune, dees dae kan jy net chip.
    O ja en dan het die ontwerper besluit om geen tydmerke op die timing stelsel te sit nie. Jy het `n kid nodig om sy tyd te stel. Gelukkig kan ek darem dit uitwerk volgens firing order.
    Apr 2011
    Villierdsdorp
    MMM. Kom ek sien. My 1975 1600GL Escort.
    1300 Kolbenschmidt pistons om die kompressie bietjie op te jaag.
    Head en intake ge-gasflow sodat hy lekker kon asemhaal
    Groter valves.
    Lekker warm cam. Het gesukkel om te idle
    Flywheel 7kg ligter gemaak sodat hy kon rev soos 'n bike (Clutch het nie gehou nie )
    Hele masjien gebalanseer.
    Takkies met 'n free flow kezorst . Hoor nou nog daardie tik-tik-tik, soos die takke die gasse uittrek
    Weber 36 DCD Gas. (Was nie geld vir side drafts nie )
    Pancake air filter.
    Standard 30S se m%@r van robot to robot. Man by die werk het my eendag probeer haak met sy Charade Turbo. Hy het nooit weer probeer nie.
    Die goeie ou dae toe mens nog aan 'n enjin kon werk....................... Dis hoekom ek jou so beny Christo. Daai V8's kan mens nog op die ou manier toor. Kan ek maar kom spenners aangee? Sal my Kaap trippie kanselleer
    Groetnis
    Wynand.
    Thanked: 601
    @ grips, groter slaggatjie, miskien moet ons 'n klein GTG reel in Kuruman, of in Kathu die naweek, dan kan ek jou lus aanwakker .. jy sien, as daar nou met die Colt se kragbron iets verkeerd gaan kos dit net so vyf grotetjies vir 'n nuwe hart
    Kathu
    Thanked: 2844
    Quote Originally Posted by Gaitshi Gubib View Post
    Johan kom ons kyk hoe loop die dinge. Gaan jy Sondag Danielskuil GTG toe?
    Thanked: 601
    Wens ek kon, daardie tyd is ek iewers noord van Blackrock vir 'n GTG van Swambo ... ou skoolmaat van Seodin.
    Laat ons kontak hou, sal graag wil saam gesels
    .... nul sewe 2 een 04 sewe 03 nege
    Kathu
    Thanked: 2844
    Quote Originally Posted by Wynand View Post
    Groter valves.
    Pancake air filter.
    Wynand nou praat jy het `n hele krat vol carbs. Ek help graag die jong manne deesdae. Jy moes die mannetjie se gesig sien toe ek hom twee 40 side draughs skenk. Stelle van die goed raak skaars. Die kennis van enjins raak juis minder omdat dit moeliker is om aan die moderne goed te krap.
    Die manne dink chip is `n woderwerk inwerklik stel jy maar tyd en die brandstof mengsel. Ek dink die spanner aangee trippie gaan werk, jy sal eers by die regering moet verby kom.
    Kathu
    Thanked: 2844
    Gaan met jou praat.
    Kathu
    Thanked: 2844
    Kolbenschmidt wonder kry jy dit nog. In die ou dae het die handelaars go faster goodies verkoop. Hulle het jou letterlik aangemoedig om jou tjor te toor. Vandag as jy die enjinkap oop maak verloor jy jou waarborg.
    Apr 2011
    Villierdsdorp
    Kry hulle nog, maar weetnie van SA nie.
    KS Kolbenschmidt
    The KS Kolbenschmidt division develops, produces and markets gasoline and diesel engine pistons for cars and commercial vehicles and is among the foremost players in its segment. Other products include pistons for two-cycle and compressor engines as well as large pistons for stationary, marine and locomotive engines.
    Upgrading power density as well as achieving further reductions in fuel consumption and emissions have for years now been the factors driving the development of new types of pistons at KS Kolbenschmidt.
    Neckarsulm-based KS Kolbenschmidt GmbH, an international company, harnesses to maximum effect the synergies among its various units: large-bore, commercial vehicle and car pistons. Available for this purpose is the experience derived from local development departments and the development centers and production facilities in Europe, North and South America and Asia.
    For years now, many notable OEMs have been regular customers of this division. The chief markets are Europe, North and South America, and Asia.
    Groetnis
    Wynand.
    Kathu
    Thanked: 2844
    I finally made a decision. Ford 302 with alu heads ,roller cam and Holley Off Road carb will replace the 4.0L SOHC. I am not going to build a torquer motor like the 347. With a nice cam and the other goodies 260kw can be easily extracted from the 302 before it will get to cammy.
    On the gearbox side it is either a Ford AOD auto or Borg Warner T5.
    Depending on which has the best adapter kid for an NP 205 transfer case.
    The rear diff is a Gearmax copy of the Ford 8.8 inch and will be able to handle the power and torque. The front diff has to go. This was always the weakest link in the 4.0l`s drive system. It will make place for an Dana 44 IFS. Yes I am going to keep the IFS set up. My hands are starting to itch to get rid of all the fancy tronics. Just think a Ranger with manual selected free wheel hubs. Gone is the 4x4 switch. Now battling to select 4x4 when needed.
    The idea is that the Ranger will still be used as a daily driver.
    As its got a Big Brother which I have build for the serious stuff , the tyre size will not exceed 31 x 12.5.
    Now sourcing the right stuff.
    Wynand sien jy true blue.
  16. The Following User Says Thank You to grips For This Useful Post:
  17. #16
    Nigel
    Thanked: 2290
    Krap hom boetie.....
    Uniglide
  18. #17
    Jan 2009
    Hartbeespoort
    jou huidige transfer case pas presies op n Borg warner T5 ...
  19. #18
    Apr 2011
    Villierdsdorp
    Ek het al begin wonder of hierdie thread net 'n rumour is want dit was so lank stil, maar ek sien jy het jou planne in plek. Besig om huiswerk te doen en ek laaik wat ek hoor.
    Om eerlik te wees, was daardie Lexus voorstel maar net om jou bietjie te byt . Weet mos nou al teen die tyd waar jou hart le.
    Ek sien uit na die "storie"
    Groetnis
    Wynand.
  20. #19
    Kathu
    Thanked: 2844
    Ja eers lank gewik en weeg somme gemaak en kyk wat pas op wat.
    Ek gaan dit rustig vat met die een my ander Ranger het nog `n paar goedjies wat ek eers wil klaar maak.
  21. #20
    Kathu
    Thanked: 2844
    Quote Originally Posted by Rooivan View Post
    Dankie Rooivan ek weet die Ranger gebruik `n Borg Warner 1354 T-case.
    Ek wil graag wegkom van die elektriese shift motor. Die NP205 is seker een van die beste 4x4 T-Cases en dit is al die pad rat gedrewe. V8 moet nogal draai om hom te breek.
  1. Wj build any pros or cons
    By peter bee in forum Jeep
    Last Post: 2012/07/06, 02:17 PM
  2. Wj or tj build
    Last Post: 2012/06/22, 10:50 AM
  3. Grand Cherokee WJ build sheet - WTF?!?!
    By Megagustodon in forum Jeep
    Last Post: 2010/09/23, 03:25 PM
  4. Build Thread
    By ILoveMyJeep in forum Jeep
    Last Post: 2010/08/23, 10:21 AM
  5. 4x4 Project build.. What would you build?
    By Zombicon in forum General 4x4 Discussion
    Last Post: 2010/07/01, 07:15 PM
