Discovery 2: electric mirrors
Results 1 to 10 of 10
    Morpeth
    Default electric mirrors
    Hi ,
    I am not sure if the specs are the same in Africa as UK, but here goes.
    My Discovery 2 Td5 ES, 2003 facelift model has heated folding mirrors.
    and they have devolped a woble when driving at speed worse in windy
    conditions, have been told it might be a worn spring type washer,
    Has anyone had this problem and if so short of raplaceing the whole unit has anyone managed to fix the problem and if so how?
    I dont want to risk pulling mirror to bits without some idea what to do as i will probably end up with broken mirror.
    Hope someone out there can help.
    Regards Stephen
    Melkbosstrand
    Thanked: 349
    Our mirrors are the same design.
    What wobbles? Is it the whole ear or just the glass?
    If the glass, it might be dislodged. It clips in and can sometimes unclip. It will also respond poorly to adjustment in this case.
    Just remove it carefully- establish which side if the glass is loosest, then push the mirror gently towards the tighter side and it should pop out. You'll then see the clips and how they work and you can clip it in again.
    Rob
    V8 Defender 90 pickup. Lexus, Spitronics, 33" KL71, beadlocks, +2" Terrafirma, ATB's, 3.75 CW&P, 1.21 TC.
    Series IIA 88" pickup
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    MG TF160 VVC ZandF remapped
    Buell XB12R
    Morpeth
    No mores the pity, its the whole plastic housing from where it pivets, it doesnt wobble loads, but its got about half inch of play at hindge end of housing. its how the hinge assembly works or can be repaired that i need some idea on, an expolded diagram would be perfect but i doubt such a thing exsists
    Melkbosstrand
    Thanked: 349
    Not seen one wobble there.
    Have you reset the position? ie: put mirror adjustment knob to middle setting and push down and cycle the mirrors back to position.
    Rob
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Morpeth
    Default Wobble
    Yes they both fold and open fine it seems to be ware on both mirrors where they swivel from, you can move them a little with no effort before you meet any resistence, was hoping someone out there had come across this. i have heard of someone in the uk but they just replaced the full units, expensive! i hate to bin somthing with what seems a minor fault that shouldnt be to hard to fix, if i knew how to sepeate the housing from the base with out damageing it that would be half the battle,
    Feb 2012
    Thanked: 58
    Default Re: electric mirrors
    Reviving Thread.
    which models had folding mirrors and can one "activate" this function?
    Gary W
    Dec 2014
    Thanked: 1574
    I stand under correction, but the folding mirrors are for the Japanese market.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Melkbosstrand
    Thanked: 349
    I had 2 non facelift ES models, both auto. One TD5, one V8. Both had it. Very handy when you brush a bush and the mirror folds away- you just cycle it and its back in place
    Rob
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Feb 2012
    Thanked: 58
    I see the mirror button has a function that you can push it in when in centre position. apparently this how you would fold the mirrors.
    Gary W
    Oct 2015
    Romania/Hungary
    Thanked: 114
    If it has folding mirrors the switch must look like this
    if it's like the one below then no folding mirrors
    2000 Discovery Td5 ES manual, tuned
    Hawkeye v.6, Nanocom EVO,
    VDM UCANDAS, oscilloscope
    i DON'T ANSWER TO TECHNICAL QUESTIONS IN PM'S
    ALL MY ADVICES ARE BASED ON MY OWN EXPERIENCE AND MY WAY OF UNDERSTANDING THE DESCRIPTION AND OPERATION OF SYSTEMS... I'M NOT A LAND ROVER SPECIALIST JUST AN ADDICTED ENTHUSIAST
  1. electric = bad?
    By MariusFourie in forum General 4x4 Discussion
    Last Post: 2012/10/05, 09:56 AM
  2. Electric vehicle configurations
    By 0l1v3r in forum General 4x4 Discussion
    Last Post: 2012/07/05, 01:05 PM
  3. Electric Fan Conversion
    By Numbnut in forum Mitsubishi
    Last Post: 2011/03/29, 12:57 PM
  4. Electric cars might just be the answer
    By XJ Junkie in forum The 4x4 Pub
    Last Post: 2011/01/17, 08:34 AM
  5. Generators driving electric motors
    By andre plant in forum Vehicle & Technical Chat - General
    Last Post: 2008/08/24, 11:54 AM
