Results 1 to 20 of 26
    May 2008
    Talking Basecamp Tips / Questions
    Hi All,
    I am starting this thread to get a list of FAQ about what you struggle with using Basecamp.
    Please also pitch in with Basecamp functionality that you found that might be helpfull to others.
    Let me start with this:
    Do you know how to search for the intersection of two streets in Garmin Basecamp?
    Use the Find "Address" near "Suburb" containing "Street name 1 and/& Street name 2" then click search.
    Regards,
    Derick
    Toyota Hilux D4D Dual Battery, Long Range Tank, OME
    Echo 4
    Garmin 60CSx, Montana 600, Nuvi 3760LT
    GME GX300 29MHz
    Gaborone, Botswana
    Thanked: 3813
    Default Enter/Find/GoTo Coordinates.
    You have the co-ordinates - where is it on the map?
    This had me puzzled for a long time... but here it goes:
    Press 'Ctrl' + 'T'.
    The "ReCenter Map" will pop up.
    Enter your co-ordinates and click "Create Waypoint"
    Done!
    Kobus
    May 2007
    Welgelegen, Cape Town
    Thanked: 818
    Thanks, this will help so much, much appreciated.
    Toyota D4D Legend 45
    Toyota 2.4GD6 Auto Extended Cab
    Bushlapa Vlooi 652
    Feb 2012
    Default Merge/Join tracks
    You can merge/join several tracks/routes to form one.
    a) Select the tracks you want to join together by holding down the CTRL (control) key and clicking on them,
    b) Once selected, right click on them to bring up the menu,
    c) Select 'Advanced' and then 'Join selected tracks'
    This will merge/join all the selected tracks into one large track.
    May 2010
    Bergbron, Roodepoort
    Thanked: 426
    Quote Originally Posted by Kaptein Jack View Post
    Definitely
    Franz
    2003 Disco 2 ES TD5 - Big Azz Blue
    2009 Bundu Trailer
    2019 X-Trail 2.5L (SWAMBO)
    2013 Chev UTE (Workhorse)
    Thanked: 8
    Thanks Derick I really need this type of thread w.r.t. BaseCamp.
    ALBERTON
    Yes thanks, i really battle with Basecamp
    Jan 2009
    Thanked: 76
    What is the secret on sending new way points/routes to a device.
    I will plug in my Garmin, and it will show the Garmin under devices.
    I will then send a route or way point to the device.
    I will show on basecamp that it is there, but when powering up the Garmin, it is not.
    If I them plug the Garmin in again, the new way point shows in basecamp under the device.
    I will then have to repeat the process 3 or 4 times before it actually shows on the Garmin.
    Willem Louw
    Toyota Hilux D/C 3.0 D-4D 4x4, Full OME suspension, African Outback Alu-Top, Dual Battery, DIY Drawer System, National Luna 50L
    Conqueror Companion
    May 2008
    Do you properly disconnect the Garmin by clicking disconnect USB device in Windows as this should ensure that all outstanding stuff to be written is written to the device before it is disconnected.
    Echo 4
    GME GX300 29MHz
    Jan 2009
    Thanked: 76
    I did use the eject option in basecamp, but not in windows. Will try that next time.
    Sent from my iPad using Forum Runner
    Willem Louw
    Conqueror Companion
    May 2008
    Quote Originally Posted by Carl Dahms View Post
    Hi Carl,
    What do you battle with?
    Derick
    Echo 4
    GME GX300 29MHz
    Thanked: 39
    I am so glad I'm not the only one !!!! I hate it sooo much have gone back to using mapsource.
    I am due to update all my maps in 2013 I do hope that Basecamp is not obligatory !
    Paul & Lin - Adventure before Dementia
    The Lostshepards
    2007 Cruiser 100 VX TD
    2015 Lexus RX 350
    www.lostshepard.co.za
    https://photos.google.com/share/AF1Q...AtZTRrdmczVG9R
    Cape Town, Plumstead
    Thanked: 542
    Basecamp is database driven, which is why it differs so much from Mapsource. Once you have an understanding of how it organizes data it becomes easier to make use of it.
    Here is a useful explanation - http://garmin-mapsource.wikispaces.com/BC_Database
    Safe Diving - Andy
    2013 Isuzu KB6 300 DC 4X4
    http://www.flickr.com/photos/andrews_underwater_images/
    Sep 2010
    Out ibi in Terre STLATTA
    Quote Originally Posted by lostshepard;1472926[size=6
    ]i am so glad i'm not the only one !!!! I hate it sooo much have gone back to using mapsource.
    [/size]
    i am due to update all my maps in 2013 i do hope that basecamp is not obligatory !
    +100
    '96 110 TDi Offroad Cow re IAN.
    Massive 29.6 kb graphic removed.....
    You are never to old to experience a new pain or sorrow.
    Sep 2011
    Thanked: 8
    I have waypoints saved. But I need to know what the coordinates for these are? Or the co-ords for a specific point on a map on Basecamp. How do I find this? Is it possible?
    Please help.
    Chris
    1997 110 Defender 300TDi (SOLD )
    2011 Triumph Tiger 800 Xc
    4x4 Action Group
    4X4AG0090 ( AG18 )
    ZS6RI
    Sunnydale, Cape Town
    Quote Originally Posted by Derick View Post
    I tried to write an entire holiday's worth of routes to my 2460 which, according to Basecamp, worked okay, but when I disconnected the device and powered the 2460 on again, there was sometimes only one and sometimes none, routes on the device. In the end, I transferred all thirteen of them, one at a time....pain in the butt, I tell ya.
    Would not disconnecting the device properly from Windows, cause the routes to not be written and recognised?
    M - most
    I - intelligent
    C - clients
    R - realise
    O - our
    S - software
    O - only
    F - fools
    T - teenagers
    I'd rather be fishing, camping or brewing beer...
    Quote Originally Posted by chrisandian View Post
    Please help.
    Chris
    With your Waypoints panel open (as per attached image), right click on a waypoint and select "Open". A panel will open which will give you all the details of that waypoint, including the GPS coordinates.....hope that helps.
    Delmas
    Thanked: 1324
    Sjoe, ek verstaan niks!!!!
    Derrick wanneer is die volgende kursus? Witklipbank is beskikbaar.
    Elize
    en ry saam met SarelF in
    4x4 Isuzu NPS 300 met kamper
    Kyk gerus by www.blinkgatproducts.com
    Vir enige aluminium produkte,canopy's, campers kontak gerus
    Sarel 0828209413
    May 2008
    I am looking at scheduling a course for March in Gauteng. Who will be available and also supply dates that will suite you.
    Derick
    Echo 4
    GME GX300 29MHz
    May 2008
    Quote Originally Posted by StevenD View Post
    M - most
    I - intelligent
    C - clients
    R - realise
    O - our
    S - software
    O - only
    F - fools
    T - teenagers
    Hi Steven,
    I see the new release of basecamp has a fix for when basecamp would not sync with devices.
    I would give it a try. Your issue might be resolved.
    Derick
    Echo 4
    GME GX300 29MHz
  1. GWM Steed 5 questions for a newcomer
    By pgreeff in forum GWM / Haval
    Last Post: 2012/07/26, 10:19 AM
  2. Replies: 61
    Last Post: 2012/07/04, 06:42 PM
  3. Basecamp & Mapsource
    By Kaptein Jack in forum GPS & Mapping
    Last Post: 2011/12/02, 07:41 PM
  4. Replies: 1
    Last Post: 2011/01/24, 10:27 PM
  5. Botswana Trip - Odd Questions
    By Andre N in forum Botswana
    Last Post: 2009/04/20, 09:00 AM
