Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
  1. #21
    Rangeview Krugersdorp
    Thanked: 2776
    My version is 3.3.1. Updating it on my Mac just gives me pages of unreadable symbols and a message about dos?
    Can I still potter along with this version?
    Ta
    Ford Figo 2016
  2. #22
    Sunnydale, Cape Town
    Quote Originally Posted by Derick View Post
    I see the new release of basecamp has a fix for when basecamp would not sync with devices.
    I would give it a try. Your issue might be resolved.
    Derick
    Thanks Derick....I've just downloaded the new version of Basecamp and upgraded all my 2460 firmware, so I'll give it a go...
    I'd rather be fishing, camping or brewing beer...
  3. #23
    Thumbs up
    Quote Originally Posted by StevenD View Post
    Once the 2460 is powered up after transferring the "new adventure" across to the unit it takes a while (accompanied by the spinning hourglass) but after a couple of minutes all the tracks loaded are shown in the Trip Planner. It could be that the 2460 is trying to plot the routes on its internal copy of the T4A map, but I'm just happy that it works.....thanks...
  4. #24
    May 2008
    Glad it works now!
    Toyota Hilux D4D Dual Battery, Long Range Tank, OME
    Echo 4
    Garmin 60CSx, Montana 600, Nuvi 3760LT
    GME GX300 29MHz
  5. #25
    Nov 2012
    Fourways
    You can merge/join several tracks/routes to form one.
    a) Select the tracks you want to join together by holding down the CTRL (control) key and clicking on them,
    b) Once selected, right click on them to bring up the menu,
    c) Select 'Advanced' and then 'Join selected tracks'
    This will merge/join all the selected tracks into one large track.[/QUOTE]
    Hi Derick
    It took me a while to work this one out
    These track are in the side bar in the unlisted data column Highlight both as Derick mentions by holding CTL and continue as above The magenta track does not highlight Now all hell brakes loose The tracks may even return you to the starting point Double click the new track and the route table will open Delete the wrong parts ot the track and drag and drop the waypoints that were placed wrong by this stupid software into the correct place Now check again if you have the correct route and name it as you wish
    When you build a track the software tends to stop building somewhere along the way Do not despair Start a new track where the previous stopped , build again till it stops Join the as described above , until you get (eventually) to your destination
    I know It is bloody frustrating My neighbor above aske me why I was vloeking so loudly
    I trust that with practice it will become easier (practice does not always make perfect Ask Swambo)
    Pajero DID 2006
    For Big FUN Mazda MX5
    SWAMBO Audi A3
  6. #26
    May 2008
    Well done ouoomeenoog!
    Echo 4
    GME GX300 29MHz
  1. GWM Steed 5 questions for a newcomer
    By pgreeff in forum GWM / Haval
    Last Post: 2012/07/26, 10:19 AM
  2. Replies: 61
    Last Post: 2012/07/04, 06:42 PM
  3. Basecamp & Mapsource
    By Kaptein Jack in forum GPS & Mapping
    Last Post: 2011/12/02, 07:41 PM
  4. Replies: 1
    Last Post: 2011/01/24, 10:27 PM
  5. Botswana Trip - Odd Questions
    By Andre N in forum Botswana
    Last Post: 2009/04/20, 09:00 AM
