Def 110 TDI Power Loss of a different kind - Please help.
Results 1 to 10 of 10
    Sep 2010
    Muldersdrift
    Default Def 110 TDI Power Loss of a different kind - Please help.
    Hi Everyone.
    I have a Def 110 TDI 97 with about 450 000Kms on the clock, now having no power.
    History:
    2011(Botswana Maun):
    Gear box was rebuilt and a second hand casing replaced.
    Transfer box rebuilt at the same time.
    Drive back to JHB +/_ 1600kms. All systems good lot of power and everything working.
    I take vehicle to my mechanic for a vehicle check. I have work done on other components. I'e brakes, fuel pump and something else.
    Get vehicle back. It feels sluggish and no power. A week later i cant take it anymore and go back to Mech. We go on a test driver up a long hill. No power. He says he need to do some tests, Ie Injectors, Turbo and timing belt. I say okay but need the LR for a trip. Mech tells me its fine to go on trip. I do so but freak because it so slow. Get back to Mech.
    His Diagnosis:
    Possibly my gearbox is a Disco box. That's why no power. He now has to source a swap out for me.
    Question to the Community:
    I drove back from Botswana with lots of power for over a month without any problems. Can this be that I have a disco box and this will cause power loss?
    How if I had power can this happen if I have the incorrect gearbox?
    To me I would have thought the timing belt was fitted incorrectly?
    The Turbo might be faulty?
    Injectors might be dirty or need replacing?
    Please help and advise. Should I find another mech?
    Thank you.
    Jan 2009
    Thanked: 131
    Take it to a different mechanic for 2nd opinion
    Range Rover Big Body 5.0 V8 Supercharged
    Land Rover Defender 110 V8 Game viewer
    Land Rover Defender 100 PU V8
    Land Rover Freelander II SD4
    Jaguar XJS V12
    Nov 2006
    Edenglen
    Thanked: 360
    Get a second opinion. Sounds to me like the timing is set incorrectly, or the fuel pump is tired. Does it smoke a lot? Have you checked the turbo?
    Erin Bosch (082 342 1909)
    4xfagger no. GP0048
    2007 Volkswagen T5 4Motion
    Sep 2010
    Muldersdrift
    It smokes a lot on pull off. Black smoke. Thank you I will get a 2nd opinion.
    Sep 2010
    Muldersdrift
    Thank you. Yep that was I was thinking. I don't want to go through unnecessary expense.
    Nov 2006
    A factor that can be overlooked on the TDi is the tension on the accelrerator cable. Check that the last section of the cable has no slack in it. There is a knurled adjustment wheel - after battling with my TDi on a long trip , I discovered there was slack and the adjustment rejuvenated the old bus.
    Sep 2010
    Muldersdrift
    Okay didn't think about the accelerator adjuster. Will tell my mech to look into that.
    Hunters Close, Port Elizabeth
    Thanked: 78
    checkout landyworx look in the land rover section several threads about them....
    here found their info LANDYWORX - Peter and Walter 011 781 0020
    everyone raves about them definitely take it too them b4 spending more money
    Luke aka Jedi
    1954 Landy Rover Series 1 86"- Rambling Rose
    Best company slogan: Cherrybomb performance exhaust, Disturbing the peace since 1968
    Nov 2006
    Edenglen
    Thanked: 360
    Quote Originally Posted by Bushwacker View Post
    Had the same issue with mine - lots of smoke on starting and pull off, and loss of power - the timing belt was one tooth out.
    4xfagger no. GP0048
    Thanked: 491
    Hi bushwacker
    fairly close to you, you can also go to Landyonline ([email protected]), they have the Snap-on pump timing tool, which allows them to set the pump timing dynamically, which means that it will be 100% spot on.
    If that turns out ok, then the front cover must come off and the timing belt must be checked for proper fitment, i.e. cam timing ok.
    The black smoke on take off has nothing to do with the turbo, that is set by the adjustment screw under the blanking plug on top of the pump.
    Hope this helps!
    George Bosch
    Distributor for:
  1. Bigger Tyre = Power Loss = Worth it?
    By Kappie in forum Suzuki
    Last Post: 2017/06/02, 12:28 AM
  2. Overland Journal Portable 12V Fridge Review
    By ChrisH in forum Camping, Fridges, Accessories
    Last Post: 2011/11/30, 11:26 AM
  3. CPT - JHB Def 110 with crabs
    By mdickerson in forum Land Rover
    Last Post: 2010/10/02, 01:21 PM
  4. PRO'S & CON'S 110 CLUB CUB/130 TDi
    By 10135556 in forum Land Rover
    Last Post: 2009/04/17, 03:47 PM
  5. Strange noise Def. 110 TDI, Please Help??
    By brucepolks in forum Land Rover
    Last Post: 2008/12/04, 07:43 AM
