Results 1 to 8 of 8
    Oct 2007
    Thanked: 9
    Default Towbar and reverse warning sensors
    Hi all,
    I recently purchased a Disco 4 for my wife, and had a Frontrunner towbar fitted (the Disco 3/4's standard towbar is too low for the Companion in offroad conditions).
    Now, after fitment of the towbar, I had no issues with the warning sensors at the back when reversing, ie. they stay off when there is nothing behind me. However, subsequently I put a rubber cover on the towbar ball, and since then, whenever you reverse, the warning buzzers come on, even with nothing behind the vehicle. Take the cover off, and everything normal again.
    How do these sensors work, and could it be that the reflection from the black cover is causing some issues?
    Plett
    Thanked: 5599
    Default D4 sensors
    I have the complete opposite! I have to leave the black cover on.....go figure!
    2024 LC Prado 250 VXR
    2025 Tank 300 2.0 Super Lux
    2017 Chevy Trailblazer Z71
    BL Kewer 3188
    Tarpon 170, 2x70 Yammies
    Oct 2007
    Thanked: 9
    Quote Originally Posted by brucehun View Post
    i have the complete opposite! I have to leave the black cover on.....go figure!
    lol ...
    Thanked: 3486
    Jeez, mine complains without any cover so perhaps I should tray a plastic cover. It'll really be funny if that works....
    Disclaimer - All my posts on this forum is without prejudice, is based on my fair assumptions or perceptions, might not be factually correct, is in no way intended to cause harm to anyone and is acted upon at your own discretion.
    Oct 2007
    Thanked: 9
    If that's the case, I am going to return my cover as defective
    Sent from my BlackBerry 9900 using Tapatalk
    Now
    2011 Disco 4 SDV6 S
    Then
    '99 Defender 90 TDi
    2004 Discovery 2 TD5 GS
    2004 Discovery 2 TD5 GS - Yes, had two of them
    2007 Defender 110 Puma
    2008 Discovery 3 TDv6 S
    2011 Conqueror Companion
    2012 Defender 90 P/U LE
    Pta
    Hi all, Good luck I know the frustration!! I had the same issue with the Front Runner towbar , I just gave up as the wife was very unhappy about the whole towbar issue, Have a look at this towbar http://www.g4outdoor.co.za/Products/discovery_4.html It works well and so far I am very happy with it.
    FOURWAYS GARDENS
    Thanked: 464
    Quote Originally Posted by Landy_Man View Post
    Hi Landyman and others. It is so very simple. the two closest sensors to the tow hitch,just turn them slightly to scan at a slight angle. Problem solved. A spare wheel carrier is a different issue.
    Take Care
    Umkomaas
    Thanked: 1695
    Quote Originally Posted by tgwinduna View Post
    Take Care
    Only works on the 3 and not on the 4.
    This is the biggest gripe I have with Lani. At random the PDC just screams and other times no issues. Will try and remove the cover and see if it makes a difference, maybe I must try and remove the whole ball and see what happens.
    It will also be nice when the front PDC starts to be beep that the camera switches automatically to the front cameras.
    Louis Le Grange
