Tyres that work on the Amarok - Page 12
Page 12 of 17 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 221 to 240 of 326
  1. #221
    Nov 2012
    Default Re: Tyres that work on the Amarok
    Hi Guys
    I'm interested in changing my 255/60/18's for 255/70/18's has anyone fitted these, and do they touch?
    2017 VW Amarok 3.0TDi 4m
  2. #222
    Mar 2009
    Amorosa
    Quote Originally Posted by hawker View Post
    Hi Guys
    I wanted to ask this exact question, can get Yokohama Geolander G012 A/TS at a really cheap price. I do however suspect that they will be too large as the OD is increased by 51mm
    Current Tyre Proposed new tyre size
    Overall rolling diameter measurement763.20mm 814.20mm
    Sidewall height 153.00 178.50
  3. #223
    I have 265/70 r 17 which is okay in perilli but just touched with maxxis. Since your rim size is already 1inch greater and you are proposing a similar profile I would say it is unlikely to work well without some sort of lift. Just a suspicion and I would not take them unless you can try them out from lock to lock and under full articulation before paying.
  4. #224
    Oh and that extra diameter works great, but you feel it in the higher gears, especially when towing or loaded.
  5. #225
    Nov 2012
    265/70 17 = 31.5"
    255/70 18 = 32.1"
    0.6" Diameter = 0.3"radius = 7.62mm extra radius
    Going to wait to add new tires for now. But I think I have found the size I want. 32's will be good, lets hope the seikel 1" lift will aid it slightly.
  6. #226
    Dec 2011
    You might get away with the 255 because it's slightly narrower than the 265/70/17s. I have Cooper ST MAXX and they touch at full lock.I actually think a lift in the front makes it slightly worse because it moves the wheel slightly closer to the body.
  7. #227
    Nov 2012
    Quote Originally Posted by JohanRoux View Post
    I'm trying to find a used set to try out.
  8. #228
    Sep 2012
    The big question is what do you get with fuel consumption on the news tyres , i read some got better and some got worse, but its still too few to judge what consumption will be over the long period
    i have standard continental gross contact 245x65x17 and got 10.3 km per liter up to 26000 km, after 30000 km the consumption is 11.2 km per liter? maybe vehicle is now properly run in?
    i am looking to replace with Bridgestone duellers 265x65x 17
    2015 amarok 132 kw auto - 4 motion
    Any pointers
  9. #229
    Amorosa
    Quote Originally Posted by Reccepops View Post
    Any pointers
    I get around 10 with 265/65/17
    Bush Lapa Miskruier 586
    Youtube Channel: https://www.youtube.com/channel/UCFS..._as=subscriber
  10. #230
    Clearly I drive like miss daisy. I got 10.4l/100km driving down to dbn with a reasonable load and boat in tow. Expect around early 11's on the way home.
    In general I consider anything above 8,5l/100km to be on the heavy side.
    I have 265/70r 17, 90kw double cab with canopy but otherwise very standard
  11. #231
    Ps towing I will usually stick to 100-110 and slower if the speed limit specifies.
    Generally around the same sort of speeds without load.
  12. #232
    Oct 2012
    otjiwarongo
    any body fitted good year adventure tyres? any comments? I need to decide between them or pirelli scorpions?
    2017 VW Amarok BiTDi 4Motion D/Cab
    2020 VW T Cross Highline R Line
    2019 Bushlapa Miskruier 1616
  13. #233
    Aug 2011
    Glenconnor
    Quote Originally Posted by hein100 View Post
    Do not know the Good Years but have heard good reports.
    Exceptionally happy with the Pirelli Scorpions.
  14. #234
    Oct 2012
    otjiwarongo
    Quote Originally Posted by Amarok4 View Post
    I have the pirelli scorpions on my treg and so far so good. treg obvious don't do much gravel and no off road at all. I fitted the good years so will see how they go
  15. #235
    Secunda
    I have the new 2017 Amarok. According to the Sales person, the front suspension was changed in the new model. Has anyone tried fitting 265/60 R18 to the new Amarok? They come standard with the 255/60 R18, I was wondering if anyone has any experience with larger tyres in the Cooper range on a stock Double cab?
    2017 VW Amarok Bi-TDi 4Motion Auto
    2008 Toyota Rav4 VX D-4D
  16. #236
    I currently have 265/65/R17s on. Works like a charm.
  17. #237
    Scorpions without a doubt.
    Always look for reasons why things can be done
    Amarok 4motion 8 speed Auto
    Golf 7 GTi DSG 2015
  18. #238
    Secunda
    Quote Originally Posted by echochaser View Post
    Echochaser, no rubbing on inner wishbones or chassis? What year model do you have? Did spare fit in wheelwell? I see your set up will be slightly more on circumfrance variance wen compared to the 265/60 R18... thanks for the info.
  19. #239
    Mar 2017
    Okahandja
    I have 265/70/R16 on the SC and 265/65/R17 on DC and both fit. 265/60/R18 is the same diameter and should fit.
  20. #240
    Quote Originally Posted by taylorns View Post
    Hi
    Nope. All good. My friend has 18 rims with the same OD tyre.
    I have a 2011. Went offroading aswell and no rubbing at all.
    All fits great AND looks great.
  1. Offroad Tyres and Rims (Colt)
    By Sherrit in forum Tyre chat
    Last Post: 2017/06/15, 09:55 PM
  2. Jimny - Standard Tyre's Mileage
    By HLOURENS in forum Suzuki
    Last Post: 2012/09/18, 04:22 PM
  3. Amarok tyres
    By stephenplumb in forum Volkswagen
    Last Post: 2012/08/06, 07:27 PM
  4. Road Biased Tyres for a Defender (110 2005)
    By dlevett in forum Tyre chat
    Last Post: 2008/03/19, 04:03 PM
  5. Which type of tyres work for you
    By Big Hilux in forum Tyre chat
    Last Post: 2007/01/20, 01:40 PM
