Tyres that work on the Amarok - Page 9
Page 9 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 161 to 180 of 307
  1. #161
    Feb 2014
    waterfall
    Default Re: Tyres that work on the Amarok
    Hi Byroness could you post a pic of your amarok, I'm in process of acquiring new mags and tyres to and thinking of going with A line mercury mags to
  2. #162
    Witbank - MP
    I have Pirelli scorpion atr. currently no issues. Have any one done sand driving with them ( Moz )
    Volkswagen Amarok 4M 132kw
    Toaster - SWAMBO ( Hyuandi Atos)
    Jurgens XT 120
    2 Kids
    2 Cats
    1 Dog
    1 mother in law
  3. #163
    Rustenburg
    Thanked: 36
    Hi guys,
    So I got two Hankook dynapro's with 80% thread left for a steal. Unfortunately can't seem to find another pair with the same thread left. Looking to buy two new ones. My question is, with the 8spd auto and it's permanent 4wd, will it help fitting the new ones at the back without rotating them for lets say 30,000km in order to get even wear all-round, or does it wear faster in front?
  4. #164
    May 2010
    Thanked: 206
    Quote Originally Posted by Netler View Post
    Hi guys,
    The front wears faster on mine
  5. #165
    May 2010
    Thanked: 206
    Quote Originally Posted by Niek View Post
    I've done sand with them in Kaokoland and had no issues. You will be fine. Air down nicely!
  6. #166
    Rustenburg
    Thanked: 36
    Quote Originally Posted by JurgenSteyn View Post
    Thanx Jurgen, appreciate the reply
  7. #167
    JHB
    Thanked: 108
    Model: 132kW manual
    Trend-/Highline:Highline
    S/C or D/C: D/C 4Motion:
    Std or H/Duty rear:Std Rear
    Tyres Type:AT
    Make: Continental
    Rims Type:Alloy
    Make:BMW 3 series
    Diameter:16" with 34mm offset
    Width:7J
    Problems/Issues: Perfect fit, with outside of tire in the same line as a 17" with a 265.
ID:	417463   Click image for larger version.
    2012 Bi Turbo 4Motion, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and software.
  8. The Following User Says Thank You to JohnBoy For This Useful Post:
  9. #168
    Secunda
    Model: 132kW manual
    Trend-/Highline: Highline
    Std or H/Duty rear: H/Duty rear
    Tyres Type: MT
    Make: Goodyear Wrangler MT/R
    Rims Type: Alloy
    Make: VW Taruma
    Diameter: 16" with +62mm offset (62mm - 30mm spacer = +32mm)
    Width: 6.5J
    Problems/Issues: No issues, road noise not to bad. No difference in power or pull-away compared to my 265/65/R17 BFs, pull-away might even be better! Got bulk wheel studs from Tiger-Wheel (very cheap) for the spacers, which I had to cut flush to get a good interface between the wheel and spacer surfaces (a little bit of gasket maker in between). Tyres are running very smooth with no vibrations and road absorption is excellent. Thinking of getting set of road tyres in the same size 235/85/R16!
ID:	417912   Click image for larger version.
ID:	417913   Click image for larger version.
  10. #169
    Dec 2013
    Thanked: 487
    Can now also add mine to the list
    Model: 120kW manual
    Std or H/Duty rear: Std
    Tyres Type: AT
    Make: General grabber AT
    Rims Type: Alloy
    Make: VW
    Diameter:
    Width:
    Problems/Issues: None so far... but not sure what they'll do on sand with the lower profile...
  11. #170
    SECUNDA
    Hi Ouens
    Ek het mos vir my die ultimate gekoop.
    Die man kom uit met 19 duim wiele.
    Ek kan nou n stel amarok 17 duim wiele by n pel kry.
    Watse size tyres stel julle voor. Ek wil hulle op sit as ek veld toe gaan.
    Ek kyk na General se grabbers AT 265/65/17.
    Weet nie of hulle gaan skuur.
    Ek is nie n wheel spacer fan.
    Groete
  12. #171
    Vanderbijlpark
    Thanked: 703
    Ek het 265/65/17 Grabbers op, en dit skuur nerens.
    Bonus is, die bakkie ry sagter ook.
  13. #172
    Fochville
    Thanked: 46
    Quote Originally Posted by clubbie View Post
    265/70/17 werk nog beter en skuur glad nie
    Ryno Black
    Amarok V6
  14. #173
    Mar 2013
    Secunda
    Thanked: 19
    Hi julle,
    Ek het vir my 'n 2014 Amarok 4Motion Auto gekoop en hy het 255/55 R19 Pirelli Scorpion Verde (all season) tekkies. Aangesien die tekkies nog splinternuut is wil ek nou nie onnodig nuwes opsit nie en gaan nie baie 4x4 ry nie.
    Ek wil graag Desember daai sand gaan ry by Vleesbaai en wonder sommer of iemand al sand gery het met die tyres. Wat is julle opinie oor die tyres in die sand, gaan ek sukkel?
    Groete
    Bernhardt
  15. #174
    Dec 2013
    Thanked: 487
    Quote Originally Posted by Bernhardt View Post
    Hi julle,
    Groete
    Bernhardt
    Ek sit self met 19s op my bakkie... wel GB at's en die Scorpions nie... Nie seker hoeveel mense regtig vir jou direkte ondervindings raad sal kan gee van die 19s op die amarok spesifiek nie omdat meeste 17s of 18s ry en die ernstige 4x4 ouens ry verseker alaml 17s... miskien is hier iemand wat al ondervinding met die 19s het
    Ek het nog nie sand gery met myne nie. Ek het wel nou die dag 'n rustige 4x4 roete gaan ry en die 19s was glad nie 'n probleem nie...
    Ek het dieselfde probleem dat my General Grabbers nog net 1500km op het so dit voel ook bietjie onsinnig om hulle nou af te gooi en 17s te soek...
    Ek sal maar desember bietjie in die sand gaan ry en self kyk hoe hulle voel... die discos wat ook met 19s loop dink ek is baie swaarder as die amarok? nie seker hoeveel nie.
    Laat weet hoe jy die 19s ondervind in die sand as jy met hulle gaan ry het!
  16. #175
    Mar 2013
    Secunda
    Thanked: 19
    Hi Willem. Neewat jy kan maar gaan, jy sal glad nie sukkel nie. Het al met n disco gegaan met generals op. Het by laaste duin war lang duin is het ons net afgeblaas 1 bar toe en opgery sonder issues.
    My probleem en dis hoekom ek vra is, die Scorpion Verde is n 80/20 band. So is nie n AT nie. Is n ongelooflike lekker band op teer en grondpad shape hy ook. Maar ek wonder oor sand?
  17. #176
    Dec 2013
    Thanked: 487
    Ah ek sien, so die vraag is meer band gerig as grootte...
    Ek moet se ek was aangenaam veras met die generals op die trail laas naweek, die goed grip BAIE beter as die Destinations wat ek op die Isuzu gehad het...
    Sien uit na bietjie sand ry...
    Ek sien net wel dat rocksliders maar 'n belangrike byvoeging op die amarok is...
  18. #177
    Jan 2016
    Groot Gat
    Thanked: 29
    Hi julle,
    Groete
    Bernhardt
    Hallo Bernhardt
    Was in Aug saam n Auto Rok met die selfde bande op as joune by duine en hy kon saam ry waar ons ry,het partykeer 2 keer probeer maar dis pad bande aan die einde van die dag.
    Het net op n stadium afgevat na 0.5 bar vir n duin maar geen probleme en het ook glad nie afgeklim nie.
    Vir Vleesbaai met daai bande kan jy maar laat waai,sak net bietjie meer vir laaste duin,wat ek sou doen.
    Groete
    '10 Vw Amarok 2.0 BiTdi D/C 4trek
    Mikem Suspension Lift
  19. #178
    Mar 2013
    Secunda
    Thanked: 19
    Stephan, Dis awesome nuus. Dankie vir die info. Gaan 1 baar ry tot laaste duin en dan sal ek ook 0.5 gaan. Sal julle laat weet hoe dit was
  20. #179
    Amorosa
    Thanked: 355
    Quote Originally Posted by WillemT View Post
    Rock Sliders is ook nie alles nie. Nou op my 2de Amarok in 5 jaar. Nog nooit geskuur nie. Was op n trail waar ander geskuur het. Net my lyn verander en geen probleem nie. Het wel die Seikel lift op albei gehad.
    Bush Lapa Miskruier 586
  21. #180
    Vanderbijlpark
    Thanked: 703
    Quote Originally Posted by Bogaards View Post
    Dis die verskil.
    Vandat ek die Mikem lift in het, het my rock sliders amper nog nooit weer gewerk nie. Daai 35mm maak 'n groot verskil.
    As ek nou moet kies, doen ek eerder die lift as die rock sliders.
  1. Offroad Tyres and Rims (Colt)
    By Sherrit in forum Tyre chat
    Last Post: 2017/06/15, 09:55 PM
  2. Jimny - Standard Tyre's Mileage
    By HLOURENS in forum Suzuki
    Last Post: 2012/09/18, 04:22 PM
  3. Amarok tyres
    By stephenplumb in forum Volkswagen
    Last Post: 2012/08/06, 07:27 PM
  4. Road Biased Tyres for a Defender (110 2005)
    By dlevett in forum Tyre chat
    Last Post: 2008/03/19, 04:03 PM
  5. Which type of tyres work for you
    By Big Hilux in forum Tyre chat
    Last Post: 2007/01/20, 01:40 PM
