Tyres that work on the Amarok - Page 8
Page 8 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 141 to 160 of 307
  1. #141
    Mar 2013
    Thanked: 42
    Hi Ryno
    Dit klink na 'n lekker size band. Watse maak is dit wat jy in daai groote kry?
    2008 Toyota Hilux D/C 3.0 D-4D (Overlander) SOLD
    2013 Toyota Hilux 3.0 D4D Auto
    2013 Jeep Wrangler 3.6 Auto
  2. #142
    Fochville
    Thanked: 46
    Quote Originally Posted by Sidestep View Post
    Hi Ryno
    Michelins, maar dit gaan maar sukkel om te kry
    TW&T het Hankook ook in daai size
    Mitchelins gee goeie kilo's is n stil band
    Ryno Black
    Amarok V6
  3. #143
    Mar 2013
    Thanked: 42
    Dankie Ryno.
    So jy het 33" op jou Amarok. Vang hy nie erens nie?
  4. #144
    Fochville
    Thanked: 46
    Dankie Ryno.
    So bietjie, maar ek het daai rubbers laat stel (dink hulle noem dit bump stop)
    Nou is my draai sirkel van lock tot lock net n klein bietjie kleiner.
    En pasop jy ry nou baie makliker oor jou eie mudflaps in die veld
    Ryno Black
    Amarok V6
  5. #145
    May 2012
    Thanx guys for the feedback
    Currently do not own a 4x4, driving a sedan
    Ex: 2013 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2012 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2013 Ford Ranger 2.2 XLS 2WD manual
    Ex: 2009 Mazda BT50 3.0 CRDi double cab manual
  6. #146
    Vanderbijlpark
    Thanked: 705
    Quote Originally Posted by RynoB View Post
    Kan jy 'n foto post van hoe dit lyk?
  7. #147
    JHB
    Thanked: 108
    I have 285/70/17's on my rok.
    The rims i am running are A-Line with a +38mm offset. Also have the MAD 35mm suspension lift installed with standard shocks.
    I had minor rubbing up front, so needed to remove my front mudflaps to stop rubbing, now it cleares everything even at full lock.
    Ps, on the standard rims you cannot go wider than 265 without interference with the upper ball joint.
    2012 Bi Turbo 4Motion, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and software.
  8. #148
    JHB
    Thanked: 108
    Another pic, here you can see the new rubber mudflaps that i have mounted on my rocksliders
  9. #149
    Thanked: 11
    Quote Originally Posted by The TRANSPORTER View Post
    Or Riaans was 265/75/17's??
    70's
    Personally will not go bigger than that.
    2014 AutoAmaRock
    RSI Signature Canopy
    Pirelli Scorpion ATR 265/70 R17
  10. #150
    Vanderbijlpark
    Thanked: 705
    Quote Originally Posted by JohnBoy View Post
    Daai lyk nou mooi.
  11. #151
    JHB
    Thanked: 108
    Thanks Clubbie.
    If I had to do it all over again, I would not go with 33's again. Or if I could find a 245 or 265 wide 33" I would go with this over the 285.
    But I must agree with Riaan, I find that running the 265/70/17 for everyday use to be ideal.
  12. #152
    Thanked: 8
    Default Re: Tyres that work on the Amarok
    Quote Originally Posted by Byroness View Post
    Amarok
    Model: 90kW
    Trend-/Highline:Trendline
    S/C or D/C: S/C
    4Motion:
    Std or H/Duty rear:Std Rear
    Tyres
    Type:A/T
    Make:MAXXIS Bravo 700
    Rims
    Type:Alloy
    Make:A-line Mercury
    Diameter:8J with 30mm offset
    Width:17"
    Problems/Issues: No problems , Clears perfectly and minimum Road noise
    Model: 90kW
    S/C or D/C: S/C
    4Motion:
    Tyres
    Type:M/T
    Make:MAXXIS Bighorn 764
    Rims
    Type:Alloy
    Make:A-line Mercury
    Width:17"
    Problems/Issues: Clears perfectly without any lift , quite a bit of road noise although I expected it to be noisier .
  13. #153
    Jan 2016
    Boksburg
    Thanked: 128
    I'm busy doing some new stuff to my 'Rok, part of which is changing rims and tyres. Currently I'm running the 18's on 265/65's BFG AT's, and looking to change to 16's on BFG KO2 AT 265/75. OD is pretty much exactly the same, but with a heck of a lot more rubber to absorb the terrain. Anyone run this combo? Would appreciate any feedback as to how they performed on and off the beaten trail. Thanks!
    Sent from my iPhone using Tapatalk
  14. #154
    Addo
    Model: 120kW
    Trend-/Highline:Highline
    S/C or D/C: D/C 4Motion:
    Tyres Type:AT
    Make:BF Goodrich KO2
    Rims Type:Alloy
    Make:A-line Magnum
    Diameter:8J with 45mm offset
    Width:16"
    Problems/Issues: Clears perfectly without any lift, ride is considerably softer then my OE 18' tyres
  15. #155
    Jan 2016
    Boksburg
    Thanked: 128
    Quote Originally Posted by jdhvisser View Post
    Model: 120kW
    Tyres Type:AT
    Rims Type:Alloy
    Make:A-line Magnum
    Width:16"
    Thanks.
  16. #156
    Mar 2012
    Thanked: 17
    Hi Hendrik
    Sorry for the late reply, missed your question. I didnt like the BFG's in sand at all. They did not deflate nicely to allow for better traction. When I let them down too much they debeaded the rim. I changed to an auto last year - running the 17" rims with Goodyear 265 65 17 A/T
    Quote Originally Posted by Hendrik van Emmenis View Post
    I have the same on my D/C.
    How well does these tyres perform in sandy conditions?
    2017 VW Amarok V6 DC 4 Motion Auto
    ex 2015 VW Amarok 132kw DC 4 Motion Auto
    ex 2012 VW Amarok 132kw DC 4 Motion
    ex 2010 Toyota Fortuner D4D 4x4
    ex 2007 Toyota Hilux DC 4.0 v6 4x4
    ex 2003 Colt Rodeo DC 3.0 v6 4x4
  17. #157
    May 2007
    Parys
    Quote Originally Posted by Gerhardstru View Post
    Just fitted the General Grabber AT in a 265/70 16. Havent done any riding yet but they look better than the 245/70. Will post pics later.
    So far no complaints, no rubbing etc. Will check and comment once I have done a obstacle or 2
    How have these General Grabbers done ?
  18. #158
    Weltevreden Park
    Quote Originally Posted by wad View Post
    Great tires will fit them again in a heart beat
  19. #159
    May 2007
    Parys
    How would you rate the sidewall compared to BF AT Ko2 I want to put some steel 16 in rims on my DC auto , currently have BFG mudterrain on the standard rims but the shlep of changing the tyres when I do a trip is getting to me. I do a lot of onroad driving and prefer the standard tyres for this. My 17 in muds and all terrains might be for sale soon.
  20. #160
    Weltevreden Park
    I honestly can't comment. I did around 40 k km on mine before I sold the car. Varied terrain on trails but mostly tar. Had a cut on a side wall,spinning tires on a rock ledge but tire held up
    I never had a flat with these
  21. The Following User Says Thank You to Gerhardstru For This Useful Post:
    wad
  1. Offroad Tyres and Rims (Colt)
    By Sherrit in forum Tyre chat
    Last Post: 2017/06/15, 09:55 PM
  2. Jimny - Standard Tyre's Mileage
    By HLOURENS in forum Suzuki
    Last Post: 2012/09/18, 04:22 PM
  3. Amarok tyres
    By stephenplumb in forum Volkswagen
    Last Post: 2012/08/06, 07:27 PM
  4. Road Biased Tyres for a Defender (110 2005)
    By dlevett in forum Tyre chat
    Last Post: 2008/03/19, 04:03 PM
  5. Which type of tyres work for you
    By Big Hilux in forum Tyre chat
    Last Post: 2007/01/20, 01:40 PM
