Tyres that work on the Amarok - Page 5
Page 5 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 81 to 100 of 307
  1. #81
    Dec 2013
    Hi Amawolf, geen warranty issues met VW ?
  2. #82
    Thanked: 30
    Ek het 'n tyre upgrade gereel via die VW dealer van 245/65R17 na 265/65R17. Ek dink die verskil is klein genoeg tussen die twee tyres
    Jacques
    2013 Amarok BiTDi DC 4Motion
    2018 Bushlapa Ratel 4 Military Edition - BL1402
    Sold - 2011 Conqueror Comfort
    Sold - 2004 Isuzu KB300 DC (was only 4x2 but a happy 240000km and 9 years)
  3. #83
    Bellville
    Ek het een van laas jaar se Spirit of Afrika bakkies. Die fabriek het hom self opgesit.
    Sent from my iPhone using Tapatalk
    2012 Amarok BiTDI
  4. #84
    Bellville
    As ek jou goeie raad kan gee sit die Deuler A/T 265/70/16 op. Uitstekende band all round.
    2012 Amarok BiTDI
  5. #85
    Thanked: 43
    Amarok
    Model: TDi400 120KW
    Trend-/Highline: Highline
    S/C or D/C: D/C
    4Motion: Selectable 4Motion
    Std or H/Duty rear: STD (Comfort Suspension)
    Tyres OME
    Type: Pirelli Scorpio
    Make: Pirelli
    Problems/Issues:
    No problems or issues. They were really great, lasted 110 000 km and had fewer punctures in the bush than I expected. They took some very bad pot hole knocks without much damage and were very quiet on the road. The only reasons I did not use them again is because I wanted to try a more off road oriented tyre to see the difference. I decided on the BF's. Goodyear Wrangler was option 2 on the list.
  6. #86
    Thanked: 43
    Amarok
    Model: TDi400 120KW
    S/C or D/C: D/C
    Tyres OME
    Make: Pirelli
    Tyres Now
    Type: AT
    Make: BF Goodridge
    The Rok is on 125 000 km, the BF's on 15 000 km. They still look new.
    Problems/Issues: I'm not going to lie, the BF's make the super quiet Amarok (as it was running on Pirelli's) much less quiet. It seems to be getting a little better with time, or perhaps I'm getting more used to it. I DO miss the Pirellis for that reason. Also, according to my calcs and adjusting for different speed and distance readings, I gave up roughly 0.5 l/100 km in fuel consumption. All this is probably worth while, as the truck now really looks like a truck and many people comment on it. So far no sekelbos punctures. I think they are a little better in sand than the more road orientated Pirellis and I do expect them to be better in mud. Happy so far.
  7. #87
    May 2010
    Kathu
    Amarok
    Model:2012 90kw
    Trend-/Highline: Trend
    S/C or D/C: DC
    4Motion: 4Motion
    Std or H/Duty rear: Seikel Field and Forest
    Tyres
    Type:Goodyear
    Make:Wrangler HP
    Rims
    Type:Alloy
    Make: VW Alastaro
    Diameter:19"
    Width: 8j
    2012 Amarok TDI 4motion
    1973 Beetle
  8. #88
    Jan 2014
    Nigel
    I fitted my S/C amarok with Cooper Discoverer ATR 245/75/R17 and they are great. Gained about 50mm ride height.
  9. #89
    Thanked: 11
    Quote Originally Posted by RiaanR View Post
    Amarok
    Model: BITDI
    S/C or D/C: D/C
    4Motion: Yes baby!
    Std or H/Duty rear: Std
    Tyres
    Type: AT
    Make: Pirelli Scorpion
    Rims
    Type: Std mags, Aldo I think
    Make: VW
    Diameter: 17Inch
    Width: ?
    Problems/Issues: None, but could be better in Mud
    Nice all rounder tyres, perfect for daily use! Done 38K on them now. Gained 13mm ground clearance when fully inflated.
    Bakkie have been traded in. Done about 75k over 32months on the tyres, and they really performed well. I think they look quite well for the abuse they took, between somewhat off-roading and driving it like I stole it. Did get two punctures on them on 70k due to nails. About +- 4mm tread left of about 10mm (if I measured correctly). Now went for the Cooper At3 on the new bakkie as it seems they are a bit more off road friendly.
ID:	264586   Click image for larger version.
ID:	264587   Click image for larger version.
ID:	264588   Click image for larger version.
    2014 AutoAmaRock
    RSI Signature Canopy
    Pirelli Scorpion ATR 265/70 R17
  10. #90
    Mokopane
    Thanked: 174
    Quote Originally Posted by JohnBart View Post
    Model: 2012 120kW
    S/C or D/C: D/C
    4Motion: YES
    Std or H/Duty rear: H/Duty
    Tyres: General Grabber
    Type: A/T
    Make: General
    Rims
    Type: 18" Durban
    Make: VW
    Diameter: R18
    Width: 255
    Already done about 5000km with them, Tar, Soft sand and Gravel - so far so good. Look good and I like the tread (much better than the std tyre it originally came with). Very quiet on the tar and no performance or fuel usage change. I tried the bigger BFG 265/65, but it looked as though it would 'rub' against inner wishbone so decided against it, no real regrets yet. GPS and speedo a bit off, speedo about 5-10km/hr slower than GPS.
    Looks great, thanks, now I know what to get.
    Die reŽn is 'n dag nader as gister.
  11. #91
    Pongola
    Thanked: 7
    I put on Cooper AT3, mainly due to the info from this forum, which i could not fault, as i have run BFG for a long time with no issues (1 puncture in 300k) except wet roads holding is not the best. And i have been happy so far with the Cooper's......on road. On gravel, plantation and farm roads, i have now had 2 punctures in 25k, one of them was bad enough to need vulcanising. So now i am a bit concerned, the damaged tyre is only good enough for a spare.
    2013 Amarok 132kw 4 motion auto with alterations
    2010 Mitsubishi PajeroSport with alterations to keep Swambo safe
  12. #92
    Thanked: 100
    Amarok
    Model: 2011
    S/C or D/C: D/C
    4Motion: Yes
    Tyres
    Type: Pirelli
    Make: Scorpion ATR
    Rims
    Type: Steelies
    Make: OEM Transporter
    Diameter: 16"
    Width: 6.5J
    Problems/Issues: Not so great on wet raods and the 205 profile is a little small so will go to 235/70/16 minimum at some stage. Seemed to work OK on the muddy farm roads but have not done any serious offroading as yet so yet to test properly
    Darryn Van Rooyen
    2014 D/C Amarok 4Motion H/L Auto - 76mm Decat Downpipe and Revo Stage 1 Tune
    Current: 1987 Citi Sport 1.6
  13. #93
    Jun 2013
    Umtentweni
    Amarok
    Model:2010 120kw
    Trend-/Highline:highline
    S/C or D/C: DC
    4Motion: 4Motion
    Std or H/Duty rear:STD
    Tyres
    Type:Yokohama
    Make:Geolander G012
    Rims
    Type:Alloy
    Make: VW Stad
    Diameter:17"
    Width:
    Problems/Issues: None, only done about 2000k. A lot quieter than the previous BFG ATs, not quite as good looking tho
  14. #94
    Fochville
    Thanked: 46
    Ek het my nuwe Rok gekoop met 265/75/17.
    Op n lelike pad ruk hy my steering lekker rond is dit normal?
    Ryno Black
    Amarok V6
  15. #95
    Thanked: 11
    Quote Originally Posted by RynoB View Post
    Huh! 265/70/17 loop mooi, selfs tot op toesluit spoed!
    2014 AutoAmaRock
  16. #96
    Fochville
    Thanked: 46
    Riaan dan moet daar fout wees ek voel elke duik in die pad.
    Ek het hulle al afgeblaas na 2.1 toe maar die gevoel bly dieselfde
    Maar onthou dit is 265/75 dit is 13 mm verskil op die sidewall of anners 7%
    Die OD op die 265/70 is 802.8 mm actual sidewall height is 185.5 mm
    Die OD op 265/75 is 829.3 mm actual sidewall height is 198.75 mm
    Ryno Black
    Amarok V6
  17. #97
    Thanked: 11
    Ek ry tot 2.5 bar met n smile!
    2014 AutoAmaRock
  18. #98
    Thanked: 11
    Loop hy nie sagter hoe groter die sidewall is nie?
    2014 AutoAmaRock
  19. #99
    Thanked: 97
    ek sou ook so dink. kan nie wees dat dit die computer deurmekaar gooi nie want daar is manne met groter bande
    D23 Navara LE Auto 4x4
    Jeep Wrangler Sahara Unlimited 75th Anniversary Edition in Sargent Green (sad to have sold it)
    Jeep Wrangler Sahara 3.6 2dr (sold)
    Jurgens XT140 (sold)
    ex VW Amarok 4motion (X3)
  20. #100
    Fochville
    Thanked: 46
    dis is ook my gedagte, maar in die geval nee.
    Ek vat hom die naweek TW&T toe.
    Sal julle laat weet
    Ryno Black
    Amarok V6
  1. Offroad Tyres and Rims (Colt)
    By Sherrit in forum Tyre chat
    Last Post: 2017/06/15, 09:55 PM
  2. Jimny - Standard Tyre's Mileage
    By HLOURENS in forum Suzuki
    Last Post: 2012/09/18, 04:22 PM
  3. Amarok tyres
    By stephenplumb in forum Volkswagen
    Last Post: 2012/08/06, 07:27 PM
  4. Road Biased Tyres for a Defender (110 2005)
    By dlevett in forum Tyre chat
    Last Post: 2008/03/19, 04:03 PM
  5. Which type of tyres work for you
    By Big Hilux in forum Tyre chat
    Last Post: 2007/01/20, 01:40 PM
