Tyres that work on the Amarok - Page 2
Page 2 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 21 to 40 of 307
  1. #21
    Apr 2011
    Ghanzi, Botswana
    Thanked: 835
    Amarok
    Model:2011 120kW
    Trend-/Highline: YES
    S/C or D/C: D/C
    4Motion: YES
    Std or H/Duty rear: H/Duty
    Tyres
    Type: A/T
    Make: Goodyear Wrangler
    Rims
    Type: 18" Durban
    Make: VW
    Diameter: R18
    Width: 255
    Problems/Issues: I want to change to 265/65/18 BF Goodrich All Terrain but I having trouble finding them...Help find a dealer...around JHB or NW
    2011
    VW AMAROK BITURBO TDI 4MOTION
  2. #22
    Apr 2011
    Perthfontein
    Cool
    Amarok
    Model: TDi400 120KW
    Trend-/Highline: Highline
    S/C or D/C: D/C
    4Motion: Selectable 4Motion
    Std or H/Duty rear: STD (Comfort Suspension)
    Tyres OME
    Type: Dueler H/P Sport
    Make: Bridgestone
    Tyres Now
    Type: LTX M/S2
    Make: Michelin
    Rims
    Type: Durban
    Make: VW OME
    Diameter: 7.5J
    Width: 18
    Problems/Issues:
    The Bridgestone Duelers were great but a bit too biased towards tar. No problems encountered on dirt roads or sand. Gave me 55 000 happy kilos. Very good on dry and wet tar. No punctures.
    The Michelin's is however in a class of its own. Ground clearance is up to 230mm again and nothing is touching or rubbing. The wheel arch fill is perfect. With OME tyres the speedo was over reading...100km/h but only doing around 94km/h with the GPS. The calibration is now almost perfect. Rev counter is lower so saving on fuel too as the tyres are much bigger.
    These are LT construction but so quite I can hardly believe it. The only noise now is wind noise from my roof racks. Even better in the sand...had a quick go at my favourite track and just had to select rear diff lock and on we went...at 2.5 bar pressure...with the Bridgestone's...I would have had to let the air out and then re-inflate and...it's almost too easy now. I will have to find a more difficult track. 8)
  3. #23
    Apr 2011
    Ghanzi, Botswana
    Thanked: 835
    Hie..How is the performance of the Michelins on SAND and MUD...if u have tested them on that....
    [QUOTE=
    Problems/Issues:
    These are LT construction but so quite I can hardly believe it. The only noise now is wind noise from my roof racks. Even better in the sand...had a quick go at my favourite track and just had to select rear diff lock and on we went...at 2.5 bar pressure...with the Bridgestone's...I would have had to let the air out and then re-inflate and...it's almost too easy now. I will have to find a more difficult track. 8)[/QUOTE]
    2011
  4. #24
    Apr 2011
    Perthfontein
    Quote Originally Posted by PAT n WOLF View Post
    I'm in Perthfontein Australia...no mud for miles...or is that a few thousand miles...lots of sand and like I said...better that the Dueler's...going to a very difficult track this weekend...will report back and post a pic or 2...
  5. #25
    Nov 2012
    Is ek die enigste een hier met 'n Single Cab?
    Amarok 4 motion 120kw
    Toyota Auris (las kar)
  6. #26
    Fochville
    Thanked: 47
    Quote Originally Posted by CK4 View Post
    Nee die double en single staan in my erf.
    Single is net n 90 Kw
    Ryno Black
    Amarok V6
  7. #27
    Thanked: 21
    Oom Sarel het ook een - die Blinkgat Skilpad!
    Bite off more than you can chew - then chew!
  8. #28
    Sep 2012
    robertson
    Default Tyres on VW Amarok
    I have a 2011 Amarok 2.0 Bitdi 4x4. Bought it with 255/60/18 Continental Crosscontact on
    and the ride was smooth. I've just put on 255/60/18 Pirelli Scorpions A/T and now the ride is very bumpy. I'm even running the tyres at 1.8 bar but it still is very bumpy even on tar. Is there anything I can do to make the ride smoother?
  9. #29
    Klerksdorp
    Quote Originally Posted by jakes 89396 View Post
    Same problem with Cooper ATR's. Another problem with the Coopers are sand - no traction, even at 0.6 Bar. I you try to turn in, the nose just keep sliding.
    Excellent on gravel, rocks and mud.
    2013 Audi Q3 2.o Tdi Quattro
    2007 Seat Altea Tdi DSG
  10. #30
    Dec 2012
    CENTURION
    Amarok
    Model:2.0BiTDi 132kw
    Trend-/Highline:Highline
    S/C or D/C/C
    4Motion:4motion
    Std or H/Duty rear:STD
    Tyres
    Type:BF goodridge
    Make:A/T
    Rims
    Typeurban
    Make:vw
    Diameter:18
    Width:265/65/18
    Problems/Issues: None so far. Do 90% tar. Fuel consumption a bit up.
    2012 VW AMAROK 2.0BiTDi 132KW 4MOTION D/C
    Pain is weakness leaving the body.
  11. #31
    Apr 2011
    Ghanzi, Botswana
    Thanked: 835
    Finally I have changed my tyres to the 265/65/18 BF Goodrich All Terrain. I have driven only a 1000 km and um happy with them..Fuel consumption hasnt change much on tarred road. I havent done any off-roading but I will be testing them in coming weeks. Some pics there....
ID:	190853   Click image for larger version.
ID:	190854   Click image for larger version.
ID:	190855   Click image for larger version.
    2011
  12. #32
    May 2007
    Thanked: 18
    Amarok
    Model: 2013 Auto
    S/C or D/C: D/C
    4Motion: Yes
    Std or H/Duty rear: Std
    Tyres
    Type: AT
    Make: Michelin LTX AT2
    Rims
    Type: Std VW
    Make: VW
    Diameter: 17"
    Width:
    Problems/Issues: None. Very low noise with good overall performance on both tar and gravel.
ID:	200334   Click image for larger version.
ID:	200335   Click image for larger version.
  13. #33
    Oct 2007
    Thanked: 41
    Quote Originally Posted by 949BFN View Post
    Amarok
    Model: 2013 Auto
    S/C or D/C: D/C
    4Motion: Yes
    Tyres
    Type: AT
    Rims
    Type: Std VW
    Make: VW
    Diameter: 17"
    Width:
    Pics Please !
    Sent from my iPad, using Tapatalk HD
    2013 Land Rover Discovery 4 3.0 SDV6 HSE (14 Julie 2017)
    2013 VW Amarok DC 2.0 BTDi 8-Speed Auto (1 Maart 2013 - 16 Julie 2017)
    2009 Mercedes C220 CDi
    2006 Desert Wolf Leo
    2004 Mitsubishi Colt 2.8TDi DC 4x4 Rodeo (Junie 2004 - Febr 2013)
    2004 VW Polo 1.4 TDi (Verkoop)
  14. #34
    Apr 2012
    Sedgefield South Africa
    Quote Originally Posted by Attie Bedeker View Post
    Pics Please !
    Attie as daar nie n foto by is nie bestaan dit nie. Ons wil sien.
    Mario
    VW Amarok Btdi 4Motion
    VW Beetle
    Jeep Unlimited Rubicon
    Jeep Diesel, Tupperware Short-Wheel-Base (not pink anymore)
    Merc SLK
  15. #35
    Oct 2007
    Thanked: 41
    Ek sal môre 'n foto neem van die bakkie met sy nuwe Metalian Aluminium kappie op (wat ek Saterdag laat opsit het) en dit hierop plaas.
Name:	ImageUploadedByTapatalk HD1363034294.702420.jpg
ID:	200058   Click image for larger version.
Name:	ImageUploadedByTapatalk HD1363034319.476215.jpg
  16. #36
    Oct 2007
    Thanked: 41
    En van die nuwe Pirelli Scorpion ATR's wat ek op die 18" rims laat sit het.
  17. #37
    Oct 2007
    Thanked: 41
    Die Pirelli Scorpion ATR op die 18" rim.
    Ek die fotos van die kappie op die ander draad geplaas.
Name:	ImageUploadedByTapatalk HD1363211925.789106.jpg
ID:	200695   Click image for larger version.
Name:	ImageUploadedByTapatalk HD1363211970.650044.jpg
  18. #38
    Weltevreden Park
    Just fitted the General Grabber AT in a 265/70 16. Havent done any riding yet but they look better than the 245/70. Will post pics later.
    So far no complaints, no rubbing etc. Will check and comment once I have done a obstacle or 2
  19. #39
    May 2013
    Default Experience with Hankook 19' tyres
    Amarok
    Model: 2011
    S/C or D/C: D/C
    4Motion: Yes
    Tyres
    Typeynapro ATM
    Make:Hankook
    Rims
    Type: Alastaro
    Make:VW
    Diameter:19'
    Width:255
    Problems/ Issues: None. I recently replaced the original Conti SportContact tyres after 68,000km with the Hankook's. After 4,000km these tyres really impress me. Little road noise and good grip, particularly in sand. Interestingly on open road driving I am getting 70-100km more per tank without change in driving style. Standard pressure 2 bar, loaded, up to 3 bar.
    I took out the tyre insurenace at TWT and already claimed 2 tyres after hitting a kerb at speed when avoiding a pedestrian. Well worth th extera money.
    In my view no other compareable tyre in 19'
  20. #40
    Thanked: 30
    Amarok
    Model: 2013 Manual
    S/C or D/C: D/C
    4Motion: Yes
    Std or H/Duty rear: Std with Seikel Dakar
    Tyres
    Type: AT
    Make: Continental CrossContact
    Rims
    Type: Std VW
    Make: VW
    Diameter: 17"
    Width:
    Problems/Issues: None so far. Have only done 650km on them so far only on tar .
    Jacques
    2013 Amarok BiTDi DC 4Motion
    2018 Bushlapa Ratel 4 Military Edition - BL1402
    Sold - 2011 Conqueror Comfort
    Sold - 2004 Isuzu KB300 DC (was only 4x2 but a happy 240000km and 9 years)
  1. Offroad Tyres and Rims (Colt)
    By Sherrit in forum Tyre chat
    Last Post: 2017/06/15, 09:55 PM
  2. Jimny - Standard Tyre's Mileage
    By HLOURENS in forum Suzuki
    Last Post: 2012/09/18, 04:22 PM
  3. Amarok tyres
    By stephenplumb in forum Volkswagen
    Last Post: 2012/08/06, 07:27 PM
  4. Road Biased Tyres for a Defender (110 2005)
    By dlevett in forum Tyre chat
    Last Post: 2008/03/19, 04:03 PM
  5. Which type of tyres work for you
    By Big Hilux in forum Tyre chat
    Last Post: 2007/01/20, 01:40 PM
