Electronic 4WD reset Procedure - Page 2
Results 21 to 40 of 60
  1. #21
    Apr 2011
    Mossel Bay
    Is no.1 on the attached diagram the one I should check?
  2. #22
    Dec 2006
    Thanked: 862
    It's number 1, and I don't know if it's "Normally open" or "Normally closed"
    You putting into gear, and it then works will tell you that's where the problem is.
    Also check where the switch is for checking the clutch. It could be either.
    Sakkie Coetzee
  3. #23
    Apr 2011
    Mossel Bay
    I think the clutch switch is at the pedal.
    I will check the switches and check if they state NO or NC in the manual.
    Thanks for the reply, I will let you know if it works.
  4. #24
    Apr 2011
    Mossel Bay
    OK, I unplugged the Neutral Switch connector on the gearbox and tried 4L, did not work.
    I then used a paperclip to short the 2 connector pins (not very scientific, but I did not have a multimeter) and tried 4L again, but still no success.
  5. #25
    Dec 2006
    Thanked: 862
    Be careful, I don't know in this case, but some of these are not just simple switches, they switch between two different resistors, so it might NOT be just pure on or off.
    Measure the gearbox side for connectivity and/or resistance. Get somebody to change between in gear and neutral and measure the change. If there is change, then the switch works, if there are no change.....
    Sakkie Coetzee
  6. #26
    Apr 2011
    Mossel Bay
    I will try that.
    I saw that the insulation is damaged where the switch wire goes into the switch body, but the wire seems ok.
    I will check the resistance next.
  7. #27
    Sep 2010
    Sasolburg
    Thanked: 112
    The park neutral switch circuit is normally closed.
    The reverse light switch is normally open.
    I wa supplied with a reverse switch instead of a park neutral.
    A looot of searching before I realised the mistake.
    Check that
  8. #28
    Sep 2010
    Sasolburg
    Thanked: 112
    Just a note.
    Make sure that the washer thickness on the switch is correct.
    I destroyed one with a washer being too thin.
    Cant remember the thickness though.
  9. #29
    Apr 2011
    Mossel Bay
    I uplugged the neutral switch and tried it, and also shorted the wires at the connector and tried it, so I dont think it's the switch. I also checked the clutch switch with a multimeter and it's also working. Still no low range.
  10. #30
    Dec 2006
    Thanked: 862
    Have you tried switching from 2H to 4L ? Does the t/case react?
    Sakkie Coetzee
  11. #31
    Apr 2011
    Mossel Bay
    I've tried 2H to 4L, 4H to 4L, moving, stationary, clutch in, clutch out, in gear, in neutral, and combinations of the above, bit still it won't even start the switching sequence.
  12. #32
    Dec 2006
    Thanked: 862
    You said it DOES engage 4H? That excludes the front diff actuator from being the problem. It's starting to sound like your control unit is the problem. It's under the driver seat, under the floor mat.
    Sakkie Coetzee
  13. #33
    Apr 2011
    Mossel Bay
    I suppose the only option remaining is to take it to the dealers so they can test the control unit. (if they can)
    I have heard that the 4x4 system is not connected to the ecu/bcu, so it would not register a fault code.
  14. #34
    Dec 2006
    Thanked: 862
    Your best bet is to take it to a dealer.....
    Sakkie Coetzee
  15. #35
    Apr 2011
    Mossel Bay
    Ok, I think I'm closer to a solution now.
    The "backup fuse" (reverse light fuse) was blown, and it blows as soon as I replace it.
    I spoke to a mechanic at an Isuzu dealership and he thinks that the backup and neutral switches might have been swapped.
    Does anyone know if the neutral switch (the one on top of the gearbox) is NO or NC?
  16. #36
    Sep 2010
    Sasolburg
    Thanked: 112
    The neutral switch is normally closed
  17. #37
    Apr 2011
    Mossel Bay
    If the neutral switch is NC, I might have a reverse light switch in its place. I took out the reverse light switch and tested it, and it seems to be NO, just to be sure I swapped it with the neutral switch and the fuse did not blow and the reverse lights worked, but as soon as I put the bakkie in 1st, it blows the fuse, so it seems that both switches are reverse light switches. Very strange.
  18. #38
    Sep 2010
    Sasolburg
    Thanked: 112
    Talking Switch
    Quote Originally Posted by Flee View Post
    Check that
    Quote Originally Posted by adri76 View Post
    A little reading may have saved you some trouble
  19. #39
    Apr 2011
    Mossel Bay
    I was not sure if the switch needed to be NO or NC, and as I got the bakkie like that and I was not told that there was any work done or switches changed, it did not occur to me that it might be a reverse light switch.
    I will try to get hold of a neutral switch and hopefully it will sort out the problem.
    Thanks everyone for the input.
    I will keep you posted.
  20. #40
    Mar 2014
    Elarduspark
    Thanked: 7
    Where can one get switches like that for a decent price? My neutral switch wires are also broken off and it seems you can get it only at the dealers.
  1. Triton - 2.5 Di-D vs. 3.2 Di-D
    By dewalds in forum Mitsubishi
    Last Post: 2014/04/01, 03:07 PM
  2. Isuzu electronic 4wd system
    By Reality in forum Isuzu
    Last Post: 2013/09/17, 02:07 PM
  3. Unit Standards Registered
    By 4x4offroad in forum 4x4 Training / Certifications
    Last Post: 2009/01/10, 12:02 PM
  4. 4WD Glossary
    By 4ePajero in forum Vehicle & Technical Chat - General
    Last Post: 2008/10/31, 02:57 PM
  5. Laser eye surgery
    By Graham in forum The 4x4 Pub
    Last Post: 2008/01/31, 09:23 PM
