Results 1 to 20 of 85
Thread: GWM Problems!
    Thanked: 115
    Default GWM Problems!
    This thread serves at a database of all problems experienced by GWM owners. This will give potential buyers or owners of this specific make a database they can go through to see what problems their vehicle could possibly develop.
    To ensure this thread contains only information related to vehicle problems and to keep it easy to read and understand, there are a few very specific rules:
    -Copy the list below in bold into your thread and only provide the information asked for, no more, no less.
    -One list per problem. More than one problem can be posted in the same post, but use seperate lists.
    -No discussions will be allowed in this thread. If you want to discuss a specific problem, contact the poster directly or start a new thread in the relevant section. Copy the post across to the new thread if need be.
    -ANY comments, or posts not conforming to the list below, will be deleted.
    -Only post problems you personally experienced, please no friends' stories or hearsay's.
    Please help to keep this neat and factual.
    Thanks!
    Model:
    Year:
    Mileage:
    Problem:
    Cause of problem(if known):
    Specifics of repair work carried out:
    Cost of repair:
    Who did the repair:
    Vehicle under warranty, Y/N:
    Was damage covered by warranty:
    Brackenfell
    STOKMAN-WP
    Model: 2.5dti DC 4X4
    Year: 2012
    Mileage: 10114km
    Problem: Oil leak from dipstik
    Cause of problem(if known): Rubber on dipstik hard
    Specifics of repair work carried out: Replace dipstik
    Cost of repair: R96.00
    Who did the repair: Novel Auto (Goodwood)
    Vehicle under warranty, Y/N YES
    Was damage covered by warranty: NO
    Despatch
    Model: Steed 2.8 d/c
    Year: 2008
    Mileage: 118000
    Problem: vibration under dash at 2000rpm.
    Cause of problem(if known): heater box casing rubbing against firewall
    Specifics of repair work carried out: I found when I applied pressure on two heater pipes running through firewall the vibration goes away. I loosen all nuts under dash on heater box (10mm scanner) . Applied silicon in gap from firewall side and leave overnight to dry. Re-tighten nuts.
    Cost of repair: quoted by dealer R3600. actual cost R15(price of silicon)
    Who did the repair: myself
    Vehicle under warranty, Y/N: Y(mechanical )
    Was damage covered by warranty: No
    Deon
    2008 GWM Steed 2,8 D/C 4X4
  4. The Following User Says Thank You to DeonvdC For This Useful Post:
    Oct 2012
    Potchefstroom
    Model:Workhorse 2.2mpi
    Year:2010
    Mileage:16479
    Problem:rough idleling
    Cause of problem(if known):throtle positioning sensor
    Specifics of repair work carried out:replace sensor
    Cost of repair:700
    Who did the repair:myself
    Vehicle under warranty, Y/N:n
    Was damage covered by warranty:yes if under warranty
    Boksburg
    Thanked: 16
    Model:Steed5 2.5 TCi 4x4
    Year:2012
    Mileage:20500
    Problem:turbo pipe burst
    Cause of problem(if known):heavy foot?
    Specifics of repair work carried out:turbo pipe replaced
    Cost of repair:warranty
    Who did the repair:GWM Boksburg
    Vehicle under warranty, Y/N:y
    Was damage covered by warranty:[/QUOTE]yes
  7. The Following User Says Thank You to Shell For This Useful Post:
    Thanked: 187
    Model:Steed 5 2.5tci
    Year:2012
    Mileage:14000km
    Problem:blown turbo pipe( at 4000km)
    Cause of problem(if known):Cheap chinese pipe
    Specifics of repair work carried out:new high quality pipe that GWM say all dealers have as they are aware of this problem
    Cost of repair:Warranty paid for tow and repair
    Who did the repair:GWM Fourways, GWM roadside did tow
    Was damage covered by warranty:Y
  9. The Following User Says Thank You to Willis For This Useful Post:
  10. #7
    Dec 2012
    Talking Gwm steed 2.2
    Model:2.2
    Year:2012
    Mileage:5000
    Problem: Rough Iddle
    Cause of problem(if known): Throttle Box Seal Leaking Air
    Specifics of repair work carried out:Replacement Seal
    Cost of repair:Nil
    Vehicle under warranty, Y/N:Y
  11. #8
    Jun 2012
    DURBAN
    Exclamation Warped front brake discs
    Model: steed 5 2.4mpi
    Year:2012
    Mileage:12500
    Problem: Warped brake discs
    Cause of problem(if known): apparent water on hot discs warps it!!
    Specifics of repair work carried out: Skimmed discs
    Cost of repair: R640
    Who did the repair: GWM Pinetown
    Was damage covered by warranty: NO!
  12. #9
    Port ELizabeth
    Model: steed 2.4mpi
    Year:2010
    Mileage:22297
    Problem: Brake Shudder / Warped Brake discs
    Specifics of repair work carried out: Skimmed discs plus replaced front pads.
    Cost of repair: R842
    Who did the repair: Ferro Brake
    2020 Isuzu 2.5 X-rider D/C
  13. #10
    Despatch
    Model: Steed D/C 2.8 4x4
    Year: 2008
    Mileage: 122 000
    Problem: klunk sound whe pulling away and change to 2nd .
    Cause of problem(if known): universal joint on steering arm
    Specifics of repair work carried out: replace bottom universal joint on steering arm . The one between rag joint and steering rack .
    Cost of repair: R114,00
    Who did the repair: I did.
    Was damage covered by warranty: N (nobody could find fault)
    Deon
  14. #11
    Mar 2012
    heidelberg g
    Thanked: 66
    Model:Steed 2.8tci
    Year:2008
    Mileage:37000km
    Problem: vehicle goes into limp mode. launch said it was reading is over the upper limit.
    Cause of problem(if known):feul pressure reading was less then what it needed to be, and not over.
    Specifics of repair work carried out: tank dropped, found feul line pintched in bracket securing tank.
    feul pipe eventually returned to round shape.
    also diesel filter replaced.
    reading on pressure returned to normal
    Cost of repair:R 600.00 for diesel filter
    Who did the repair: DIY
    Was damage covered by warranty:N
  15. #12
    Nov 2012
    Impala Park Boksburg
    Model: 2.8Tdi 4x4 Lux
    Year: 2009
    Mileage: 42300
    Problem: RFW indicator kept flashing; 4-wheel drive would not engage
    Cause of problem(if known): Rusted servo motor in front hub selector would not turn. Breather pipe had come off unit and it had sucked in muddy water. Grommit on wiring into unit was also torn and this may have let water in as well.
    Specifics of repair work carried out: Removed entire front hub selector unit (realised later I only really needed to remove servo motor cover and motor). Cleaned out water and mud from unit; sprayed motor with Tool-in-a-can and manually turned it to release the rust build-up. Tested the motor on a spare battery. Re-assembled the unit and greased up the moving bits. Sealed the grommit with Marine Silicon. Made sure breather pipe was securely fitted.
    Note: If you remove the entire unit as I did, when re-assembling, ensure selector fork is closest to the motor unit otherwise it is difficult to re-engage the front hub gears and line up the bolt holes.
    Cost of repair: Nil - I had the necessary tools etc
    Who did the repair: My brother and me
    Was damage covered by warranty: N/A
    GP0169
    Kevin
    2009 GWM 2.8 Tdi D/C Lux 4x4 "Spin en Stof"
  16. #13
    Nov 2012
    Thanked: 12
    Default Gwm steed 5
    Model: GWM Steed 5 2.0 VGT 4x4 Double cab
    Year: 2013
    Mileage: 3900 km
    Problem: Oil leaking slowly from right front side under engine
    Cause of Problem: Seal leak front differential electric motor
    Specifics of repair carried out: Reseal front diff electric motor
    Cost of repair: R 0
    Who did the repair: Hennie at GWM Centurion (Atlantis Motors)
    Vehicle under warranty: Yes - however Hennie stated that the repair was so small that they did not bother to put it through as a warranty repair.
    Was damage covered by warranty: Yes
  17. #14
    Okahandja, Windhoek
    Thanked: 2172
    Model:2.2 SC
    Year: 2009
    Mileage:130 000
    Problem: gearbox stuffed, body falling apart, exhaust manifold stuffed,rough idling
    Cause of problem(if known): dust cover on gearbox not good, body too soft, manifold cracked.
    Specifics of repair work carried out: gearbox done at 80k km,
    Cost of repair: not sure
    Who did the repair: agents and other workshops
    Vehicle under warranty, Y/N: not any more
    Was damage covered by warranty:no
    Bought to compare with Japanese models on site. But I think its safe to say we will stick to Japanese make
    Johan Kriel
  18. #15
    Boksburg
    Thanked: 16
    Default Turbo pipe blown
    [QUOTE=Shell;1389688]Model:Steed5 2.5 TCi 4x4
    Year:2012
    Mileage:29200 (32500)
    Cause of problem(if known):heavy foot?(cheap chinese rubber pipes with 1 layer of fibre reinforcing)
    Specifics of repair work carried out:will see tomorrow (All pipes replaced with 5 layer reinforced silicone pipes, and steel pipes inbetween)
    Cost of repair: R1400-00
    Was damage covered by warranty:Y (after waiting 3 weeks for the pipes) had an aftermarket pipe on for the 3 weeks at a cost of R500, not claimable under warranty. Cheaper than letting the vehicle stand for 3 weeks....
  19. The Following User Says Thank You to Shell For This Useful Post:
  20. #16
    Boksburg
    Thanked: 16
  21. #17
    Angry G"WHAT"M Positively UN-driven
    Model : Hover 2.5 tci
    Year: 2010
    Milage: 45000
    Problems: Turbo shaft sheared/ Engine management light on,vehicle "chipped"by dealer.
    [B]Cause of problem(if known)Dealer says - "unknown". Suspect chipping interfered with normal operating parameters.
    Specifics of repair work carried out: Non local dealer to replace turbo.
    Cost of repair:Vehicle under warranty-FREE .BUT towing and rental vehicle-R7000 from being stranded in ther middle of nowhere...
    Who did repair: Nearest dealer to breakdown
    Service recieved from dealer where vehicle was bought-
    Willys CJ6, SFA Isuzu 2.8TD, Galv chassis
    S/S fuel tank, accumulator, EFS, 33" Dynapro M/T
  22. #18
    Nov 2012
    Richards Bay
    Model; Steed 2.5 Dc 4x4
    Year; 2012
    Milage; 42000
    Problems; Burst turbo pipe 7 times, even with upgraded factory pipe, Broken intercooler 2 times, Was stranded in the middle of nowhere more than 22 times with problems ranging from Ingnition to corroded battery terminals ( At 2690 Km on clock) Rust was found at 5000 Km, Clutch overall at 7000 km ( Cost R 7989.00)
    Every brakedown I had to tow the vehicle at my own expense back to Richards Bay! only once did I receive a loan vehicle
    The vehicle was standing more at GWM as in my own yard
    Service received by GWM- None! What service
    When I asked why the clutch was shot at 7000 km the reply was they know I tow a offroad Trailer!- We towed it once to Ponta! And the vehicle was not capable!
    Vehicle cost us new R211000.00 Extras R70000.00 When we got fed up and wanted to trade it in at GWM on a Hilux we were told we sell the ! We don't buy them back!
    We then Traded it in on a Hilux at Toyota Centurion which gave us the best trade in on R142000.00 That was a loss of R139000 in 7 months and doing 42000km After phoning every dealer in the country and being told we don't trade GWM in!
  23. #19
    Mar 2011
    Default Dead horse
    Year: 2009
    Mileage: 65000
    Problem: have no power. When going on an uphill I can't get more thatn40km/hr. 4h and 4l indicator lights come on and stays on when starting up and driving.
    Cause of problem(if known): Unknown
    Specifics of repair work carried out: Please help
    Cost of repair: ?
    Who did the repair: I want to do it myself if possible
    Vehicle under warranty, Y/N No
  24. #20
    Mar 2011
    Default Piston...
    Model:2.5TCI 4x4
    Year:2012
    Mileage:27000
    Problem:Hole through piston
    Cause of problem(if known):Unknown
    Specifics of repair work carried out:Engine Replacement
    Cost of repair:47k
    Who did the repair:GWM Pinetown
    GWM Steed 5 2.5 TCI 4x4
  1. Ford/Mazda Problems!
    By Barto in forum Ford & Mazda
    Last Post: 2024/12/25, 10:21 PM
  2. Prado problems? What Prado problems?
    By LewiesF in forum Toyota
    Last Post: 2016/04/04, 06:28 PM
  3. Discovery 3 CD and Cruise Control problems (incl. bad experience with dealer)
    By ReadySteadyGo in forum Land Rover
    Last Post: 2011/11/09, 07:40 AM
  4. Land rover discovery 1 problems
    By Adriaanvn28 in forum Vehicle & Technical Chat - General
    Last Post: 2011/03/28, 06:48 PM
  5. Fortuner -NO handling problems
    By ArrieMeyer in forum Toyota
    Last Post: 2009/03/09, 06:15 PM
