Sprinter down on power
Results 1 to 11 of 11
    JHB
    Thanked: 25
    Default Sprinter down on power
    Hi,
    SWAMBO has a sprinter bus at work, it is probably about 5 years old and diesel - cant tell you any other details motor wise.
    Now the problem is that it revs fine, but has no power. I know just enough about how a petrol motor works to be dangerous and even less about diesel. My first thought is that it probably has something to do with the turbo, maybe a broken boost pipe, I don't know.
    Any ideas?
    The bus is currently at Sandown Commercial, off Main Reef rd JHB. I am not looking for a DIY fix, but rather to be armed with some knowledge.
    Kyalami
    erm... Take it to a merc dealer, will cost you R650 to know exactly whats wrong with it + a quote to fix it. (you get the R650 back if you fix it with them)
    It can literally be many things, blown off boost pipe, maf sensor, fuel filter, pump, clogged particulate filter etc...
    --Kar
    JHB
    Thanked: 25
    Yup is at merc dealership- just trying to avoid a "wool over eyes" scenario.
    Thanked: 86
    Quote Originally Posted by Mambo View Post
    Hi,
    Any ideas?
    Call Dirk (Dirk Wenzel Mobile Service) @ 083 665 3311. He is a MB specialist.
    Ps 16:5
    Jan 2011
    South of the Lentil Curtain
    Is there any smoking and what colour is it?
    hope its not a huge problem i love my Sprinter but they can cost you if they break major parts.
    JHB
    Thanked: 25
    Chris, thanks for the contact - I'll get SWAMBO to keep it handy.
    So the diagnosis does not seem to fit the symptoms as explained by the driver - Merc garage says it is the clutch and gearbox that are the problem - with a quote for just over R20K for repairs (I am not sure on the details on of the necessary repairs).
    Ouch R20k! i think you need and independent to look at it, that is alot unless bulk of it is parts ?
    JHB
    Thanked: 25
    Quote Originally Posted by sohail1 View Post
    The parts come to around R15.5K and R2.2K for labour plus VAT......
    SWAMBO is going to contact Dirk as suggested by Chris B above.
    Looking at the quote, the various parts do not seem unreasonably priced, it is just that there are a few big ticket items.
    Jun 2012
    Thanked: 578
    A friend's sprinter developed similar symptoms while towing back from PE last year, fault was eventually traced to a blocked cat. Quick way to check is to simply disconnect the exhaust knuckle just before the cat and take it for a spin.
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
    Koblenz
    Hi,
    Any ideas?
    906 Sprinter (new shape) or 903/904 Sprinter?
    315/518? 313/416 Sprinter?
    it makes a difference!
    Never fear if Frank is near!
  1. Solar doesn't make sense
    By Uys in forum Alternative Energy Solutions
    Last Post: 2017/02/05, 11:40 AM
  2. Two way radio - trnsmitting power modification 5w
    By RaAmonKhan in forum Camping, Fridges, Accessories
    Last Post: 2011/03/12, 03:28 PM
  3. dual battery colt
    By Deeps in forum Mitsubishi
    Last Post: 2011/02/09, 08:03 PM
  4. Watts to amps conversion query
    By Trevor in forum Volkswagen
    Last Post: 2009/08/27, 12:42 PM
  5. To supply power or not to supply power
    By jakes001 in forum Camping, Fridges, Accessories
    Last Post: 2008/08/12, 10:00 AM
