Pathfinder Radio startup volume
Results 1 to 15 of 15
    Timbavati Game Reserve
    Default Pathfinder Radio startup volume
    Hi All
    No matter how I try to set the startup volume on the radio in my 2005 Pathfinder, it starts on a very loud 9.
    I set it to 3 switch off remove the key and then insert key and switch on volume is back to 9
    The manual is no help. I have tried to set the "Speed Volume" and the "Beep" but neither seems to work
    Any help will be most welcome, yes I know I should replace with an updated CD Nav system, but Air lift, Nudge bar and spots have taken that part of my budget.
    Dave Jackaman
    Ham Call Sign ZR6DG
    Timbavati PNR
    Nissan Pathfinder 2.5d
    A bunch of LR Tdi & Td5
    Default ???
    Hi Seems like I am the only one with this problem. Anyone got an idea who I cam contact for a solution ?
    Any advice welcome
    Regards from a cold and wet Timbavati
    Dave
    Dave Jackaman
    Ham Call Sign ZR6DG
    Timbavati PNR
    Jan 2009
    Thanked: 41
    Maybe try the Nissan section. I think this "radios" would rather refer to UHV/VHF etc radios
    Willem Louw
    Toyota Hilux D/C 3.0 D-4D 4x4, Full OME suspension, African Outback Alu-Top, Dual Battery, DIY Drawer System, National Luna 50L
    Venter Offroader Trailer
    Default Posted under NISSAN
    Thanks Willem I have re-posted it under Nissan
    Dave Jackaman
    Ham Call Sign ZR6DG
    Timbavati PNR
    Bellville
    Thanked: 1771
    disconnect from battery - hard reset of the electronics (?)
    Hi Chris
    I will try that, makes good sense. Although fitting wires onto the battery on Friday everything had to be reset and the radio still did the same thing yesterday. I know because I was stopped watching 5 Lions who had just missed a Impala kill and were fascinated by the new vehicle and the front wheels turning, the young male came up close to look (I was free wheeling very slowly) as I turned the ignition on the radio blasted out the news on "Jacaranda" I think I had left it on 0 or 1.
    Well the Lion did not like Jacaranda and got one hell of a fright, so did I again !!
    From a cold, wet and quickly greening Timbavati
    Dave Jackaman
    Ham Call Sign ZR6DG
    Timbavati PNR
    May 2010
    Default Nissan Radio...
    Hi, it must be a nissan thing? because I have a Navara and it does exactly the same thing!
    Very frustrating! I get into the car in the morning still melow and the moment I turn the key it screams at me!!!
    I also tried various options...also disconnecting the battery, etc...nothing helps?
    Oct 2007
    East Rand
    If I recall from long ago in one of my dad's cars there was a setting in the sound system where you set the "start-up" volume of the radio. Where that is, is beyond my memory recall. Maybe play around in the menus, and see if you find something.
    Nov 2011
    I think I may have made a discovery this morning. A while back I turned on the Traffic Announcements feature which works well on Classic FM. At that point the same issue started happening. I get out the bakkie and volume was at 6. I get back in later and it blares away... I am busy testing the theory after having turned TA off again. Looks like it fixed it. Weirdest thing...
    Hi Morg
    Tried this and it had no affect on my radio. Still restarts at volume 9
    Dave Jackaman
    Ham Call Sign ZR6DG
    Timbavati PNR
    Rangeview Krugersdorp
    Thanked: 982
    Have you Googled the problem ? There are similar problems there.
    Sent from my GT-I9300 using Tapatalk 2
    Chev Aveo and Atos and Polo.
    Hi All
    Tried Google to no avail.
    If you have found some info on this problem please let me know. All I get are sites that want me to log in, give all my details and charge me for an answer.
    Dave (full of "kreef" in Paternoster, what a lekker feast)
    Dave Jackaman
    Ham Call Sign ZR6DG
    Timbavati PNR
    Kimberley
    What is Nissans reply? My Pathy I think has a setting. But does not do it.
    2013 Nissan Pathy 2.5TDi Outo
    2012 Amarok BiT SC
    Thanked: 982
    Quote Originally Posted by davejackaman View Post
    Hi All
    Sadly Dave, after your comment involving kreef and me living in GP, I have decided not to offer you anymore assistance......
    Talking
    OK, OK...... Kreef finished for now and heading North up the West Coast, just hope I do not find more kreef. I bought some Bokkoms just in case we run out of food in between all these magic little coastel towns.
    Any one know how to turn the wind down a bit? ??
    Dave Jackaman
    Ham Call Sign ZR6DG
    Timbavati PNR
  1. Everything you must know about RADIOS !
    By JDeV in forum Vehicle & Technical Chat - General
    Last Post: 2015/12/28, 10:10 PM
  2. KJ Radio upgrade/iPod setup
    By Johnny Bravo in forum Jeep
    Last Post: 2013/03/17, 10:21 PM
  3. ORRA letter - part 2
    By Elders in forum Camping, Fridges, Accessories
    Last Post: 2012/03/30, 05:38 PM
  4. Radio protocol
    By SimonB in forum The 4x4 Pub
    Last Post: 2008/11/19, 02:25 AM
