Defender TD5 crank position sensor: Where is it mounted?
Results 1 to 18 of 18
    Thanked: 48
    Default TD5 crank position sensor: Where is it mounted?
    The pic in the Rave manual does not show clearly where it is....
    I think mine is acting up. Have a new one I want to try.
    Best regards
    Philip
    LR: '11 Rangie 5.0 S/C & '01 Disco 2 XS 4.6 V8
    Ford: '19 Ranger 3.2 XLS Manual SuperCab 4x4 (XLT was horrible)
    Chevrolet: '70 C10 350ci / 700R4 (4-sp Overdrive) & '59 Apache (Stepside)
    Springs
    Thanked: 280
    on top of the bellhousing at the 1 o clock position as seen from the rear of the vehicle. it is approx 50mm behind the cylinder head.
    on the Defender it is easy to get to once you get that thick rubber pipe out of the way.
    just for interest sake the V8 D2 sensors sits at the 8 o clock position on the face of the bellhousing
    Thanked: 48
    Disappointing...
    Fitted the new one (Britpart NSC10090) this afternoon. 3min job. Engine starts but as soon as I try to rev it up it goes "grk", dies.
    Replaced old one.
    Best regards
    Philip
    Springs
    Thanked: 280
    did you ensure that it is fully home?
    sometimes the o ring snags and she does not seat properly
    even if marginally high, it loses signal and dies
    Thanked: 24
    Is it true that if the crank sensor fails totally, the defender won`t start at all? Thus always keeping a spare crank sensor if traveling?
    Thanked: 48
    Quote Originally Posted by ReynierSnyman View Post
    Absolutely. This part is critical.
    Best regards
    Philip
    Thanked: 48
    Quote Originally Posted by Landyluvver View Post
    OK, I could feel that I was tightening the bolt against pressure coming back from the O-ring so perhaps it was not seating well. Weird though that it would idle but not run. Will try again tomorrow.
    Best regards
    Philip
    Springs
    Thanked: 280
    apply a little vaseline or red rubber grease to the stem before inserting.
    have seen a couple that will start and rev to 2000 and then start stuttering and die.
    Wuxi, China
    What does a crank sensor looks like? Any pics?
    camelman
    Gauteng
    Thanked: 12
    I need to learn how to replace this part. Almost left me stranded on the way back from Kruger.
    landyluvver any chance on a step by step approach to replacing this on a Disco 2 TD5?
    2013 Suzuki Grand Vitara Summit Auto
    Ex: 2004 Land Rovery Discovery 2 TD5
    Ex: 1996 Suzuki Samurai
    Nov 2006
    Herewith pic requested :
  12. The Following User Says Thank You to pretdave For This Useful Post:
    Thanked: 48
    Quote Originally Posted by Sammy'96 View Post
    Its really a very simple job, 2nd time round took me 3 minutes.
    1. Remove the pipe that connects the air intake to the air filter
    2. Remove the crank position sensor (7mm 1/4" socket works best)
    3. Disconnect the plug (I found its easier to remove the CPS first, then remove the connector.
    4. Install reverse above.
    Best regards
    Philip
    Nov 2006
    Manual diagram
  15. #14
    Wuxi, China
    Quote Originally Posted by LRwit View Post
    I'm confused now Why would you want to remove the air intake pipe, which is located on the left side of the engine when looking from behind, when the CPS is located at 1 o'clock, which means the right side of the engine?
    camelman
  16. #15
    Witfield, Boksburg
    Thanked: 64
    Quote Originally Posted by camelman View Post
    I think LRwit is refering to a defender where the plumbing is a bit different
    Chris
    "Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing" Helen Keller
    1996 Range Rover P38 4,6 HSE
    1977 LandRover Series III 109" Project
  17. #16
    Thanked: 48
    OK, ja on my bakkie there is a thick pipe that routes air from the intake behind the RF wheel on the fender to the air cleaner mounted on the bulkhead slightly on the passenger side. This pipe blocks the view to the CPS.
    Best regards
    Philip
  18. #17
    Oct 2007
    Uitenhage
    Thanked: 575
    Default Re: TD5 crank position sensor: Where is it mounted?
    Could the CPS cause the vehicle to struggle to start and then vibrate like an old Lister for a few seconds before it settles on a cold day?
    2004 Land Rover Discovery 2 Td5 ES
  19. #18
    Aug 2017
    Thanked: 293
    Not glow pugs?
  1. Discovery 2: Buying and running a Disco II (Td5)
    By Craigb in forum Land Rover
    Last Post: 2017/09/07, 09:05 AM
  2. Defender Defender TD5 vs Disco TD5
    By janfloris in forum Land Rover
    Last Post: 2012/01/24, 10:33 AM
  3. TD5 crank pulley damper
    By NewLandy in forum Land Rover
    Last Post: 2011/11/03, 09:40 AM
  4. Fitting crank shaft sensor - TD5
    Last Post: 2011/05/17, 10:39 AM
  5. OPSOEK: Crank pully for Disco 2 TD5 2000
    By LANDY.BEAN in forum Land Rover
    Last Post: 2010/09/06, 01:38 PM
